SMBJ15A
SMBJ15A
    JINGYANG(晶扬电子)
    SMB(DO-214AA)
    IT1(mA)
SMBJ15A 数据手册
SMBJ SERIES SMBJ SERIES Surface Mount Unidirectional and Bidirectional Transient Voltage Suppressors Features  Voltage Range 5.0V - 440V  600W Peak Pulse Power Dissipation  For surface mounted applications  Reliable low cost construction utilizing molded plastic technique  Response Time is Typically < 1 ns  Uni-direction, less than 5.0ns for Bi-direction, form 0 Volts to BV min  ESD Rating of above 16 kV per Human Body Model  ESD Rating of above 30 kV (Contact Discharge) per IEC61000−4−2   EFT (Electrical Fast Transients) Rating of 40 A per IEC61000−4−4  Plastic material has UL flammability classification 94V-0  Typical IR less than 1uA above 10V  Meets MSL 1 Requirements Complies with the following standards  Solid-state silicon avalanche technology  IEC 61000-4-2 level 4: 30 kV (air discharge)   30 kV (contact discharge)  IEC 61000-4-5 SMB 4kW (8/20μs)Peak Pulse Power Dissipation per IEC61000-4-5 Ordering Information Device SMBJxxA(CA)  MIL STD 883G, method 3015-7: class 3B Qty per Reel Reel Size  Resin meets UL 94, V0 3000 13Inch  ROHS compliant “xx” =Working Peak Reverse Voltage Maximum Ratings and Electrical Characteristics Characteristics Symbols Value Unit Peak Power Dissipation At Tj = 25℃, Tp = 1ms (Note 1,2 ) PPK 600 W Peak Forward Surge Current 8.3ms single half sine-wave super IFSM 100 A Lead Soldering Temperature TL 260 (10 sec.) 0 Operating Temperature Range TJ -55 to +155 0 C -55 to +175 0 C Storage Temperature Range TSTG C Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect device reliability. 1. Non-repetitive current pulse, per fig. 4 and derated above TA= 25 C per fig.1. 2. Thermal Resistance junction to Lead 3. 8.3ms single half-sine wave duty cycle= 4 pulses maximum per minute (unidirectional units only). 4.Ratings at 25℃ ambient temperature unless otherwise specified. 5.Single phase, half wave, 60Hz, resistive or inductive load. 6. For Capacitive Load, Derate Current By 20% REV :D1 1 of 5  service@jy-electronics.com.cn  www.jy-electronics.com.cn SMBJ SERIES Electrical Characteristics ( Tamb=25℃ Unless Otherwise Specified) SMBJ MARKING IR @ VRWM PART NUMBER VBR @ IT (V) IT CODE VC(Max) IPP(Max) VRWM Uni-polar Bi-polar Uni Bi (V) Min Max (mA) (uA) (V) (A) SMBJ5.0A SMBJ5.0CA KE AE 5 6.38 7.35 10 800 9.2 65.3 SMBJ6.0A SMBJ6.0CA KG AG 6 6.67 7.89 10 800 10.3 58.3 SMBJ6.5A SMBJ6.5CA KK AK 6.5 7.22 8.3 10 500 11.2 53.6 SMBJ7.0A SMBJ7.0CA KM AM 7 7.78 8.95 10 200 12 50 SMBJ7.5A SMBJ7.5CA KP AP 7.5 8.33 9.58 1 100 12.9 46.5 SMBJ8.0A SMBJ8.0CA KR AR 8 8.89 10.23 1 50 13.6 44.1 SMBJ8.5A SMBJ8.5CA KT AT 8.5 9.44 10.82 1 20 14.4 41.7 SMBJ9.0A SMBJ9.0CA KV AV 9 10 11.5 1 10 15.4 39 SMBJ10A SMBJ10CA KX AX 10 11.1 12.8 1 5 17 35.3 SMBJ11A SMBJ11CA KZ AZ 11 12.2 14 1 5 18.2 33 SMBJ12A SMBJ12CA LE BE 12 13.3 15.3 1 5 19.9 30.2 SMBJ13A SMBJ13CA LG BG 13 14.4 16.5 1 5 21.5 27.9 SMBJ14A SMBJ14CA LK BK 14 15.6 17.9 1 5 23.2 25.9 SMBJ15A SMBJ15CA LM BM 15 16.7 19.2 1 5 24.4 24.6 SMBJ16A SMBJ16CA LP BP 16 17.8 20.5 1 5 26 23.1 SMBJ17A SMBJ17CA LR BR 17 18.9 21.7 1 5 27.6 21.7 SMBJ18A SMBJ18CA LT BT 18 20 23.3 1 5 29.2 20.5 SMBJ20A SMBJ20CA LV BV 20 22.2 25.5 1 5 32.4 18.5 SMBJ22A SMBJ22CA LX BX 22 24.4 28 1 5 35.5 16.9 SMBJ24A SMBJ24CA LZ BZ 24 26.7 30.7 1 5 38.9 15.4 SMBJ26A SMBJ26CA ME CE 26 28.9 33.2 1 5 42.1 14.3 SMBJ28A SMBJ28CA MG CG 28 31.1 35.8 1 5 45.4 13.2 SMBJ30A SMBJ30CA MK CK 30 33.3 38.3 1 5 48.4 12.4 SMBJ33A SMBJ33CA MM CM 33 36.7 42.2 1 5 53.3 11.3 SMBJ36A SMBJ36CA MP CP 36 40 46 1 5 58.1 10.3 SMBJ40A SMBJ40CA MR CR 40 44.4 51.1 1 5 64.5 9.3 SMBJ43A SMBJ43CA MT CT 43 47.8 54.9 1 5 69.4 8.6 SMBJ45A SMBJ45CA MV CV 45 50 57.5 1 5 72.7 8.3 SMBJ48A SMBJ48CA MX CX 48 53.3 61.3 1 5 77.4 7.8 SMBJ51A SMBJ51CA MZ CZ 51 56.7 65.2 1 5 82.4 7.3 SMBJ54A SMBJ54CA NE DE 54 60 69 1 5 87.1 6.9 SMBJ58A SMBJ58CA NG DG 58 64.4 74.1 1 5 93.6 6.4 SMBJ60A SMBJ60CA NK DK 60 66.7 76.7 1 5 96.8 6.2 SMBJ64A SMBJ64CA NM DM 64 71.1 81.8 1 5 103 5.8 SMBJ70A SMBJ70CA NP DP 70 77.8 89.5 1 5 113 5.3 SMBJ75A SMBJ75CA NR DR 75 83 95.8 1 5 121 5 SMBJ78A SMBJ78CA NT DT 78 86 99.7 1 5 126 4.8 SMBJ85A SMBJ85CA NV DV 85 94 108.2 1 5 137 4.4 SMBJ90A SMBJ90CA NX DX 90 100 115.5 1 5 146 4.1 REV :D1 2 of 5  service@jy-electronics.com.cn  www.jy-electronics.com.cn SMBJ SERIES Electrical Characteristics ( Tamb=25℃ Unless Otherwise Specified) SMBJ MARKING IR @ VRWM PART NUMBER VBR @ IT (V) IT CODE VC(Max) IPP(Max) VRWM Uni-polar Bi-polar Uni Bi (V) Min Max (mA) (uA) (V) (A) SMBJ100A SMBJ100CA NZ DZ 100 111 128 1 5 162 3.7 SMBJ110A SMBJ110CA PE EE 110 122 140.5 1 5 177 3.4 SMBJ120A SMBJ120CA PG EG 120 133 153 1 5 193 3.1 SMBJ130A SMBJ130CA PK EK 130 144 165.5 1 5 209 2.9 SMBJ150A SMBJ150CA PM EM 150 167 192.5 1 5 243 2.5 SMBJ160A SMBJ160CA PP EP 160 178 205 1 5 259 2.3 SMBJ170A SMBJ170CA PR ER 170 189 217.5 1 5 275 2.2 SMBJ180A SMBJ180CA PT ET 180 200 230.4 1 5 290 2.1 SMBJ190A SMBJ190CA PV EV 190 211 243.2 1 5 306 2 SMBJ200A SMBJ200CA PX EX 200 222 256 1 5 322 1.9 SMBJ210A SMBJ210CA PZ EZ 210 233 268.8 1 5 339 1.8 SMBJ220A SMBJ220CA QE FE 220 244 281.6 1 5 355 1.7 SMBJ250A SMBJ250CA QG FG 250 278 309 1 5 403 1.5 SMBJ300A SMBJ300CA QK FK 300 333 371 1 5 484 1.2 SMBJ350A SMBJ350CA QM FM 350 389 432 1 5 565 1.1 SMBJ400A SMBJ400CA QP FP 400 444 494 1 5 645 0.9 SMBJ440A SMBJ440CA QR FR 440 489 543 1 5 710 0.8 I Symbol VRWM Parameter VF Working Peak Reverse Voltage VBR Breakdown Voltage @ IT VC Clamping Voltage @ IPP IT Test Current IR Leakage current at VRWM IPP Peak pulse current VC VBR VRWM IR IT IF V IPP Typical Protection Circuit zin Vin LOAD REV :D1 3 of 5 VL  service@jy-electronics.com.cn  www.jy-electronics.com.cn SMBJ SERIES Typical Electrical Characteristics Applications Rating and Characteristics Curves 120 100 Peak Forw Ard Surge Current, Amperes 100 Peak Pulse Derating In % Of Peak Power Or Current 75 50 25 10 X 1000 Waveform Defined By R.E.A 10 XAs1000 Waveform as defined by REA 80 60 40 20 0 1 0 0 25 50 75 100 125 150 l Pulse W idth 8.3ms Single Half-Sine-Wave (JEDEC METHOD) 175 200 2 5 10 20 50 100 Number Of Cycles At 60hz Ta, Ambient Temperature (° C) Fig.2 Maximum Non-Repetitive Surge Current Fig. 1 Pulse Derating Curve 100 Uni-directional Peak Value Ipp 1000 Capacitance ,(Pf) Ip, Peak Pulse Current (%Ipp) 10000 Half Value Ipp/2 50 TJ = 25 C Bi-directional 100 10 tp 10 X 1000 1 Waveform 0 0 1 2 10 1 3 Tp ,Pulse Width(us) Fig.4 Pm(Av) Steady State Power Dissipation (W) 100 Pp, Peak Power ( Kw ) TA=25 C Non-Repetitive Pulse Waveform Shown In Fig 3. 1 5.0mm Lead Areas 0.1 0.1 1 10 100 1000 Tand-Off Voltage, Volts Fig.3 Pulse Rating Curve 10 100 1000 Typical Junction Capacitance 5 4 3 2 1 0 60Hz Resistive or Inductive Load 25 50 75 100 125 150 175 200 10000 Tl, Lead Temperature Tp, Pulse Width Fig.6 Steady State Power Derating Curve Fig.5 Pulse Rating Curve REV :D1 4 of 5  service@jy-electronics.com.cn  www.jy-electronics.com.cn SMBJ SERIES Package information SMB SMB Mechanical Data  Case: SMB  Case Material: Molded Plastic. UL Flammability  Classification Rating 94V-0  Polarity Indicator: Cathode Band (Note: Bi-directional devices have no polarity indicator.)  Weight: 0.003 ounces, 0.096 gram C Millimeters Inches B A DIM G G D F E B Min Nom Max Min Nom Max A 3.30 3.62 3.94 0.130 0.142 0.155 B 1.95 2.08 2.20 0.077 0.082 0.087 C 4.06 4.40 4.57 0.160 0.173 0.180 D 0.125 0.20 0.305 0.005 0.008 0.012 E 0.76 1.14 1.52 0.030 0.045 0.06 F 4.95 5.40 5.59 0.194 0.213 0.22 G 2.05 2.30 2.50 0.080 0.090 0.098 SMB SMB Reel Dim E P0 K P2 D T W F D1 A0 B0 B1 K0 P1 A0 B0 B1 D D1 E F K0 T W P0 P1 P2 4.0 5.9 6.1 1.5 1.5 1.75 5.5 3.0 0.50 12.0 4.0 8.0 2.0 Dimension is in mm Leader and Trailer Direction of Feed Tape Leader No Components 30 components in length Components Tape Trailer (Connected To Reel Hub) No Components 50 components in length The LEADER is a minimum of 30 components in length and it consists of empty cavities with sealed cover tape The TRAILER is a minimum of 50 components in length and it consists of empty cavities with sealed cover tape. REV :D1 5 of 5  service@jy-electronics.com.cn  www.jy-electronics.com.cn
SMBJ15A 价格&库存
很抱歉,暂时无法提供与“SMBJ15A”相匹配的价格&库存,您可以联系我们找货
