1.0SMBJ24CA
1.0SMBJ24CA
    PAKER(派克微)
    SMB(DO-214AA)
1.0SMBJ24CA 数据手册
1000W Surface Mount Transinet Voltage Suppression 1.0SMBJ Series Features SMB Peak power disspation 1000W@10 x 1000 us Pluse Low incremental surge resistance Excellent clamping capability Glass passivated junction Fast response time Typical IR less than 1uA above 10V Halogen free and RoHS compliant Mechanical Data CASE: SMBJ(DO-214AA) Molded Plastic Polarity: By cathode band denites uni-directional decice, none cathode band denotes bi-directional device Mounting Position:Any Symbol Making Code & information Package 1.0SMBJ XXX A SMB 1.0SMBJ XXX Packing Description Packing Quantity Tape/Reel,13" reel 3000 C A 1.0SMBJ 5% VBR Voltage Tolerance XXX CA Bidirectional VRWM Voltage Series Code Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Peak Pulse Power Dissipation on 10/1000 us Waveform (Note 1, 2, FIG.1) Power Dissipation on Infinite Heat Sink at TL=50°C Peak Pulse Current of on 10/1000us Waveform (Note 1, FIG.3) Peak Forward Surge Current, 8.3ms Single Half Sine-Wave (Note 2. 3) Operating Junction Temperature Range Storage Temperature Range Symbol Value Units PPPM Min1000 W PD 5 W IPPM See Table 1 A IFSM 100 A TJ -55 to 150 °C TSTG -55 to 150 °C Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2. 2 2. Mounted on 5.0x5.0mm (0.03mm thick) Copper Pads to each terminal. 3. Measured on 8.3ms single half sine-wave, or equivalent square wave, for Unidirectional device only. Rev 1: Feb 2018 派克微电子(深圳)有限公司 www.pakermicro.com Page 1 of 3 1.0SMBJ Series 1000W Surface Mount Transinet Voltage Suppression Electrical Characteristics ( Ratings at 25℃ ambient temperature unless otherwise specified). Type Number (Uni) (Bi) Reverse Stand-Off Voltage VRMW(V) Breakdown Voltage Min. @IT VBR MIN(V) Breakdown Voltage Max. @ I T Test Current VBR MAX(V) Maximum Clamping Voltage @IPP Peak Reverse Pulse Leakage @VRMW Current IPP(A) IR(uA) IT (mA) VC(V) 1.0SMBJ5.0A 1.0SMBJ6.0A 1.0SMBJ6.5A 1.0SMBJ7.0A 1.0SMBJ5.0CA 1.0SMBJ6.0CA 1.0SMBJ6.5CA 1.0SMBJ7.0CA 5 6 6.5 7 6.4 6.67 7.22 7.78 7 7.37 7.98 8.6 10 10 10 10 9.2 10.3 11.2 12 1.0SMBJ7.5A 1.0SMBJ7.5CA 7.5 8.33 9.21 1 12.9 1.0SMBJ8.0A 1.0SMBJ8.5A 1.0SMBJ8.0CA 1.0SMBJ8.5CA 8 8.5 8.89 9.44 9.83 10.4 1 1 13.6 14.4 108.7 97.1 89.3 83.3 77.5 73.5 69.4 1.0SMBJ9.0A 1.0SMBJ10A 1.0SMBJ9.0CA 1.0SMBJ10CA 9 10 10 11.1 11.1 12.3 1 1 15.4 17 64.9 58.8 10 5 1.0SMBJ11A 1.0SMBJ12A 1.0SMBJ13A 1.0SMBJ14A 1.0SMBJ15A 1.0SMBJ16A 1.0SMBJ17A 1.0SMBJ18A 1.0SMBJ20A 1.0SMBJ11CA 1.0SMBJ12CA 1.0SMBJ13CA 1.0SMBJ14CA 1.0SMBJ15CA 1.0SMBJ16CA 1.0SMBJ17CA 1.0SMBJ18CA 1.0SMBJ20CA 11 12 13 14 15 16 17 18 20 12.2 13.3 14.4 15.6 16.7 17.8 18.9 20 22.2 13.5 14.7 15.9 17.2 18.5 19.7 20.9 22.1 24.5 1 1 1 1 1 1 1 1 1 18.2 19.9 21.5 23.2 24.4 26 27.6 29.2 32.4 54.9 50.3 46.5 43.1 41.0 38.5 36.2 34.2 30.9 1 1 1 1 1 1 1 1 1 1.0SMBJ22A 1.0SMBJ24A 1.0SMBJ26A 1.0SMBJ28A 1.0SMBJ30A 1.0SMBJ33A 1.0SMBJ36A 1.0SMBJ40A 1.0SMBJ22CA 1.0SMBJ24CA 1.0SMBJ26CA 1.0SMBJ28CA 1.0SMBJ30CA 1.0SMBJ33CA 1.0SMBJ36CA 1.0SMBJ40CA 22 24 26 28 30 33 36 40 24.4 26.7 28.9 31.1 33.3 36.7 40 44.4 26.9 29.5 31.9 34.4 36.8 40.6 44.2 49.1 1 1 1 1 1 1 1 1 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 28.2 25.7 23.8 22.0 20.7 18.8 17.2 15.5 1 1 1 1 1 1 1 1 1.0SMBJ43A 1.0SMBJ45A 1.0SMBJ48A 1.0SMBJ51A 1.0SMBJ54A 1.0SMBJ58A 1.0SMBJ60A 1.0SMBJ43CA 1.0SMBJ45CA 1.0SMBJ48CA 1.0SMBJ51CA 1.0SMBJ54CA 1.0SMBJ58CA 1.0SMBJ60CA 43 45 48 51 54 58 60 47.8 50 53.3 56.7 60 64.4 66.7 52.8 55.3 58.9 62.7 66.3 71.2 73.7 1 1 1 1 1 1 1 69.4 72.7 77.4 82.4 87.1 93.6 96.8 14.4 13.8 12.9 12.1 11.5 10.7 10.3 1 1 1 1 1 1 1 1.0SMBJ64A 1.0SMBJ70A 1.0SMBJ75A 1.0SMBJ64CA 1.0SMBJ70CA 1.0SMBJ75CA 64 70 75 71.1 77.8 83.3 78.6 86 92.1 1 1 1 103 113 121 9.7 8.8 8.3 1 1 1 1.0SMBJ78A 1.0SMBJ78CA 78 85 90 100 95.8 104 111 123 1 1 1 1 137 146 162 7.9 7.3 6.8 6.2 1 1.0SMBJ85CA 1.0SMBJ90CA 1.0SMBJ100CA 86.7 94.4 100 111 126 1.0SMBJ85A 1.0SMBJ90A 1.0SMBJ100A 1 1 1 1.0SMBJ110A 1.0SMBJ120A 1.0SMBJ130A 1.0SMBJ150A 1.0SMBJ160A 1.0SMBJ170A 1.0SMBJ180A 1.0SMBJ190A 1.0SMBJ200A 1.0SMBJ110CA 1.0SMBJ120CA 1.0SMBJ130CA 1.0SMBJ150CA 1.0SMBJ160CA 1.0SMBJ170CA 1.0SMBJ180CA 1.0SMBJ190CA 1.0SMBJ200CA 110 120 130 150 160 170 180 190 200 122 133 144 167 178 189 201 211 224 135 147 159 185 197 209 222 234 247 1 1 1 1 1 1 1 1 1 177 193 209 243 259 275 292 307 324 5.6 5.2 4.8 4.1 3.9 3.6 3.5 3.3 3.1 1 1 1 1 1 1 1 1 1 500 500 300 200 100 50 20 . IR limit is double. Notes: For Bi-directional type having VRWM. of 10 Volts. and less, the For parts without A, the VBR is ± 10% and VC is 5% higher than with A parts. Rev 1: Feb 2018 派克微电子(深圳)有限公司 www.pakermicro.com Page 2 of 3 1.0SMBJ Series 1000W Surface Mount Transinet Voltage Suppression Ratings and Characteristic Curves ( Ratings at 25℃ ambient temperature unless otherwise specified). Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.1 0.001 0.01 0.1 80 60 40 20 0 1 0 TA - Ambient Temperature (℃) Fig.1 - Peak Pulse Power Rating Fig.2 - Pulse Derating Cure TJ=25℃ f=1.0MHz Vsig=50mVp-p 10000 100 1000 CJ (pF) IPP - Peak Pulse Current, % IRSM 150 100 50 td - Pulse Width (ms) 50 100 Uni V=0V 10 Bi V=0V Uni V=VR Bi V=VR 0 tr 1 td 1 100 10 VBR - Reverse Breakdown Voltage (V) t - Time (us) Fig.3 – Pulse Waveform Fig.4 - Typical Junction Capacitance Package Outline Dimensions: SMB(DO-214AA) Dim T Rev 1: Feb 2018 Millimeters Inches Min Max Min Max L 4.4 4.6 0.173 0.181 D 3.5 3.7 0.138 0.146 D1 1.9 2.1 0.075 0.083 T 5.1 5.48 0.201 0.216 T1 1.0 1.6 0.039 0.063 d - 0.2 - 0.008 H 2.2 2.45 0.087 0.096 H1 2.15 2.35 0.085 0.093 派克微电子(深圳)有限公司 www.pakermicro.com Page 3 of 3
1.0SMBJ24CA 价格&库存
很抱歉,暂时无法提供与“1.0SMBJ24CA”相匹配的价格&库存,您可以联系我们找货
