TVS Diodes
1.0SMB Series
Description
The 1.0SMB series is designed specifically to protect sensitive electronic equipment from voltage transients induced
by lightning and other transient voltage events. For surface mounted applications in order to optimize board space.
Features
Halogen free and RoHS compliant
Low profile package
Built-in strain relief design
Low inductance
Excellent clamping capability
1000W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V devices
Peak 260℃ high temperature Reflow Soldering withstanding
Meet MSL level1, per J-STD-020
IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)
Unit Weight: 0.10g
Applications
TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in telecom,
computer, Industrial and consumer electronic applications.
Maximum Ratings and Characteristics (TA=25℃)
Rating
Symbol
Value
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
1000W
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table(A)
PM(AV)
5.0W
Maximum Instantaneous Forward Voltage at 50A for Unidirectional Only
VF
3.5V
Peak forward surge current, 8.3ms single half sine-wave superimposed on
rated load, (JEDEC Method) (Note3, Fig.6)
IFSM
100A
TJ,TSTG
-55℃ to +150℃
Typical thermal resistance junction to lead
RθJL
20℃/W
Typical thermal resistance junction to ambient
RθJA
100℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Operating junction and Storage Temperature Ranges
Notes:1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2.
2. Each terminal is surface Mounted on the 5.0mm×5.0mm (0.03mm thick) copper pads.
3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum.
www.liownsemi.com
掌握芯技术Core Technology
(V3)
TVS Diodes
1.0SMB Series
Electrical Characteristics (TA=25℃)
Device
Marking
Code
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni.
Bi.
Uni.
Bi.
VR(V)
VB MIn.(V)
VB Max.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
1.0SMB6.8A
1.0SMB6.8CA
6V8A·
6V8C·
5.80
6.45
7.14
10
10.5
96.8
1000
1.0SMB7.5A
1.0SMB7.5CA
7V5A·
7V5C·
6.40
7.13
7.88
10
11.3
90.0
500
1.0SMB8.2A
1.0SMB8.2CA
8V2A·
8V2C·
7.02
7.79
8.61
10
12.1
84.0
200
1.0SMB9.1A
1.0SMB9.1CA
9V1A·
9V1C·
7.78
8.65
9.55
1
13.4
75.8
50
1.0SMB10A
1.0SMB10CA
10A·
10C·
8.55
9.50
10.50
1
14.5
70.2
10
1.0SMB11A
1.0SMB11CA
11A·
11C·
9.40
10.50
11.60
1
15.6
65.2
5
1.0SMB12A
1.0SMB12CA
12A·
12C·
10.20
11.40
12.60
1
16.7
60.8
5
1.0SMB13A
1.0SMB13CA
13A·
13C·
11.10
12.40
13.70
1
18.2
55.8
1
1.0SMB15A
1.0SMB15CA
15A·
15C·
12.80
14.30
15.80
1
21.2
48.0
1
1.0SMB16A
1.0SMB16CA
16A·
16C·
13.60
15.20
16.80
1
22.5
45.2
1
1.0SMB18A
1.0SMB18CA
18A·
18C·
15.30
17.10
18.90
1
25.2
40.3
1
1.0SMB20A
1.0SMB20CA
20A·
20C·
17.10
19.00
21.00
1
27.7
36.7
1
1.0SMB22A
1.0SMB22CA
22A·
22C·
18.80
20.90
23.10
1
30.6
33.2
1
1.0SMB24A
1.0SMB24CA
24A·
24C·
20.50
22.80
25.20
1
33.2
30.7
1
1.0SMB27A
1.0SMB27CA
27A·
27C·
23.10
25.70
28.40
1
37.5
27.2
1
1.0SMB30A
1.0SMB30CA
30A·
30C·
25.60
28.50
31.50
1
41.4
24.5
1
1.0SMB33A
1.0SMB33CA
33A·
33C·
28.20
31.40
34.70
1
45.7
22.2
1
1.0SMB36A
1.0SMB36CA
36A·
36C·
30.80
34.20
37.80
1
49.9
20.3
1
1.0SMB39A
1.0SMB39CA
39A·
39C·
33.30
37.10
41.00
1
53.9
18.8
1
1.0SMB43A
1.0SMB43CA
43A·
43C·
36.80
40.90
45.20
1
59.3
17.2
1
1.0SMB47A
1.0SMB47CA
47A·
47C·
40.20
44.70
49.40
1
64.8
15.7
1
1.0SMB51A
1.0SMB51CA
51A·
51C·
43.60
48.50
53.60
1
70.1
14.5
1
1.0SMB56A
1.0SMB56CA
56A·
56C·
47.80
53.20
58.80
1
77.0
13.2
1
1.0SMB62A
1.0SMB62CA
62A·
62C·
53.00
58.90
65.10
1
85.0
12.0
1
1.0SMB68A
1.0SMB68CA
68A·
68C·
58.10
64.60
71.40
1
92.0
11.0
1
www.liownsemi.com
(V3)
TVS Diodes
1.0SMB Series
Ratings and Characteristic Curves (TA=25℃)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Figure 3. Pulse Waveform
Figure 4. Typical Junction Capacitance
150
tr=10µs
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
50
10/1000µs Waveform
as defined by R.E.A
td
2.0
Time (ms)
3.0
4.0
Figure 5. Steady State Power Dissipation Derating
Curve
Figure 6. Maximum Non-Repetitive Forward Surge
Current Uni-Directional Only
7
6
5
4
3
TJmax=150℃
2
1
50
75
100
125
150
175
TA-Ambient Temperature (℃)
www.liownsemi.com
(V3)
TVS Diodes
1.0SMB Series
Soldering Parameters
Reflow Soldering
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) ( tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
www.liownsemi.com
20-40 seconds
8 minutes max.
(V3)
TVS Diodes
1.0SMB Series
Part Number Code and Marking Code
Dimensions (SMB/DO-214AA)
Symbol
www.liownsemi.com
Millimeters
Inches
Min.
Max.
Min.
Max.
A
1.930
2.200
0.076
0.086
B
4.060
4.750
0.160
0.187
C
3.300
3.940
0.130
0.155
D
2.160
2.650
0.085
0.104
E
0.760
1.520
0.030
0.060
F
0.203
0.008
G
5.210
5.590
0.205
0.220
H
0.152
0.305
0.006
0.012
I
2.260
0.089
J
2.160
0.085
K
2.740
0.107
(V3)
TVS Diodes
1.0SMB Series
Packaging Specification
Tape
For Uni-Devices
13 Inches Reel
Quantity:3000pcs/reel
www.liownsemi.com
(V3)
很抱歉,暂时无法提供与“1.0SMB18CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52054
- 50+0.41466
- 150+0.36165
- 500+0.32200
- 3000+0.29018
- 6000+0.27430
