SMBJ7.5CA
SMBJ7.5CA
    YINT(音特电子)
    SMB(DO-214AA)
    双向TVS 7.5V截止 峰值浪涌电流:46.6A
SMBJ7.5CA 数据手册
Transient Voltage Suppression Diodes SMBJ Series Trustworthy electronic circuit protection expert SMBJ Transient Voltage Suppressor Diode Series General Information The SMB series is designed to protect voltage sensitive components from high voltage, high energy transients. They have excellent clamping capability, high surge capability, low zener impedance and fast response time. The SMB series is supplied in YINT Semiconductor’s exclusive, cost-effective, highly reliable and is ideally suited for use in communication systems, automotive, numerical controls, process controls, medical equipment, business machines, power supplies and many other Molded plastic industrial/consumer Applications. glass passivated junction. Features Applications  Case: DO-214AA/SMB TVS devices are ideal for  For surface mounted applications in order to optimize board space. protection of I/O Interfaces, VCC bus  Polarity: Color band denoted positive end (cathode) except Bidirectional. and other vulnerable circuits used in  Typical failure mode is short from over-specified voltage or current Telecom,  High Temperature soldering:260°C/10 seconds at terminals. Consumer electronic applications.  Terminal: Solder plated, solderable per MIL-STD-750,Method 2026. Computer, Industrial the and Electrical Characteristics (@ TA = 25℃ Unless Otherwise Noted) Parameter Minimum Peak Pulse Power Dissipation (T = 1 ms) (note1 note 2) Symbol Value Unit PPK 600 Watts IFSM 100 Amps PM(AV) 5.0 Watts VF 3.5/5 Volts TJ -55 to +150 °C TSTG -55 to +150 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) (Note 3) Steady State Power Dissipation @ TL = 75 °C Maximum Instantaneous Forward Voltage @ I PP = 50 A (For Unidirectional Units Only)(note4 note 5) Operating Temperature Range Storage Temperature Range NOTES: 1. Non-repetitive current pulse, per Pulse Waveform graph and derated above TA = 25 °C per Pulse Derating Curve. 2. Thermal Resistance Junction to Lead. 3. 8.3 ms Single Half-Sine Wave duty cycle = 4 pulses maximum per minute (unidirectional units only). 4. Single Phase, Half Wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20 %. 5. VF
SMBJ7.5CA 价格&库存
很抱歉,暂时无法提供与“SMBJ7.5CA”相匹配的价格&库存,您可以联系我们找货
