1000W Surface Mount Transinet Voltage Suppression
1.0SMBJ Series
Features
SMB
Peak power disspation 1000W@10 x 1000 us Pluse
Low incremental surge resistance
Excellent clamping capability
Glass passivated junction
Fast response time
Typical IR less than 1uA above 10V
Halogen free and RoHS compliant
Mechanical Data
CASE: SMBJ(DO-214AA) Molded Plastic
Polarity: By cathode band denites uni-directional decice,
none cathode band denotes bi-directional device
Mounting Position:Any
Symbol
Making Code & information
Package
1.0SMBJ
XXX A
SMB
1.0SMBJ
XXX
Packing Description
Packing Quantity
Tape/Reel,13" reel
3000
C A
1.0SMBJ
5% VBR Voltage Tolerance
XXX CA
Bidirectional
VRWM Voltage
Series Code
Maximum Ratings & Thermal Characteristics
(Ratings at 25℃ ambient temperature unless otherwise specified.)
Parameter
Peak Pulse Power Dissipation on 10/1000 us Waveform
(Note 1, 2, FIG.1)
Power Dissipation on Infinite Heat Sink at TL=50°C
Peak Pulse Current of on 10/1000us Waveform
(Note 1, FIG.3)
Peak Forward Surge Current, 8.3ms Single Half Sine-Wave (Note 2. 3)
Operating Junction Temperature Range
Storage Temperature Range
Symbol
Value
Units
PPPM
Min1000
W
PD
5
W
IPPM
See Table 1
A
IFSM
100
A
TJ
-55 to 150
°C
TSTG
-55 to 150
°C
Notes:
1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2.
2
2. Mounted on 5.0x5.0mm (0.03mm thick) Copper Pads to each terminal.
3. Measured on 8.3ms single half sine-wave, or equivalent square wave, for Unidirectional device only.
Rev 1: Feb 2018
派克微电子(深圳)有限公司
www.pakermicro.com
Page 1 of 3
1.0SMBJ Series
Electrical Characteristics
( Ratings at 25℃ ambient temperature unless otherwise specified).
Type Number
(Uni)
(Bi)
Reverse
Stand-Off
Voltage
VRMW(V)
Breakdown
Voltage Min.
@IT
VBR MIN(V)
Breakdown
Voltage
Max. @ I T
Test
Current
VBR MAX(V)
Maximum
Clamping
Voltage
@IPP
Peak
Reverse
Pulse Leakage
@VRMW
Current
IPP(A)
IR(uA)
IT (mA)
VC(V)
1.0SMBJ5.0A
1.0SMBJ6.0A
1.0SMBJ6.5A
1.0SMBJ7.0A
1.0SMBJ5.0CA
1.0SMBJ6.0CA
1.0SMBJ6.5CA
1.0SMBJ7.0CA
5
6
6.5
7
6.4
6.67
7.22
7.78
7
7.37
7.98
8.6
10
10
10
10
9.2
10.3
11.2
12
1.0SMBJ7.5A
1.0SMBJ7.5CA
7.5
8.33
9.21
1
12.9
1.0SMBJ8.0A
1.0SMBJ8.5A
1.0SMBJ8.0CA
1.0SMBJ8.5CA
8
8.5
8.89
9.44
9.83
10.4
1
1
13.6
14.4
108.7
97.1
89.3
83.3
77.5
73.5
69.4
1.0SMBJ9.0A
1.0SMBJ10A
1.0SMBJ9.0CA
1.0SMBJ10CA
9
10
10
11.1
11.1
12.3
1
1
15.4
17
64.9
58.8
10
5
1.0SMBJ11A
1.0SMBJ12A
1.0SMBJ13A
1.0SMBJ14A
1.0SMBJ15A
1.0SMBJ16A
1.0SMBJ17A
1.0SMBJ18A
1.0SMBJ20A
1.0SMBJ11CA
1.0SMBJ12CA
1.0SMBJ13CA
1.0SMBJ14CA
1.0SMBJ15CA
1.0SMBJ16CA
1.0SMBJ17CA
1.0SMBJ18CA
1.0SMBJ20CA
11
12
13
14
15
16
17
18
13.3
14.4
15.6
16.7
17.8
18.9
13.5
14.7
15.9
17.2
18.5
19.7
20.9
22.1
24.5
1
1
1
1
1
1
1
1
1
18.2
19.9
21.5
23.2
24.4
26
27.6
29.2
32.4
54.9
50.3
46.5
43.1
41.0
38.5
36.2
34.2
30.9
1
1
1
1
1
1
1
1
1
1.0SMBJ22A
1.0SMBJ24A
1.0SMBJ26A
1.0SMBJ28A
1.0SMBJ30A
1.0SMBJ33A
1.0SMBJ36A
1.0SMBJ40A
1.0SMBJ22CA
1.0SMBJ24CA
1.0SMBJ26CA
1.0SMBJ28CA
1.0SMBJ30CA
1.0SMBJ33CA
1.0SMBJ36CA
1.0SMBJ40CA
22
24
26
28
30
33
36
40
24.4
26.7
28.9
31.1
33.3
36.7
40
44.4
26.9
29.5
31.9
34.4
36.8
40.6
44.2
49.1
1
1
1
1
1
1
1
1
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
28.2
25.7
23.8
22.0
20.7
18.8
17.2
15.5
1
1
1
1
1
1
1
1
1.0SMBJ43A
1.0SMBJ45A
1.0SMBJ48A
1.0SMBJ51A
1.0SMBJ54A
1.0SMBJ58A
1.0SMBJ60A
1.0SMBJ43CA
1.0SMBJ45CA
1.0SMBJ48CA
1.0SMBJ51CA
1.0SMBJ54CA
1.0SMBJ58CA
1.0SMBJ60CA
43
45
48
51
54
58
60
47.8
50
53.3
56.7
60
64.4
66.7
52.8
55.3
58.9
62.7
66.3
71.2
73.7
1
1
1
1
1
1
1
69.4
72.7
77.4
82.4
87.1
93.6
96.8
14.4
13.8
12.9
12.1
11.5
10.7
10.3
1
1
1
1
1
1
1
1.0SMBJ64A
1.0SMBJ70A
1.0SMBJ75A
1.0SMBJ64CA
1.0SMBJ70CA
1.0SMBJ75CA
64
70
75
71.1
77.8
83.3
78.6
86
92.1
1
1
1
103
113
121
9.7
8.8
8.3
1
1
1
1.0SMBJ78A
1.0SMBJ78CA
78
85
90
100
95.8
104
111
123
1
1
1
1
137
146
162
7.9
7.3
6.8
6.2
1
1.0SMBJ85CA
1.0SMBJ90CA
1.0SMBJ100CA
86.7
94.4
100
111
126
1.0SMBJ85A
1.0SMBJ90A
1.0SMBJ100A
1
1
1
1.0SMBJ110A
1.0SMBJ120A
1.0SMBJ130A
1.0SMBJ150A
1.0SMBJ160A
1.0SMBJ170A
1.0SMBJ180A
1.0SMBJ190A
1.0SMBJ200A
1.0SMBJ110CA
1.0SMBJ120CA
1.0SMBJ130CA
1.0SMBJ150CA
1.0SMBJ160CA
1.0SMBJ170CA
1.0SMBJ180CA
1.0SMBJ190CA
1.0SMBJ200CA
110
120
130
150
160
170
180
190
200
122
133
144
167
178
189
201
211
224
135
147
159
185
197
209
222
234
247
1
1
1
1
1
1
1
1
1
177
193
209
243
259
275
292
307
324
5.6
5.2
4.8
4.1
3.9
3.6
3.5
3.3
3.1
1
1
1
1
1
1
1
1
1
500
500
300
200
100
50
. IR limit is double.
Notes: For Bi-directional type having VRWM. of 10 Volts. and less, the
For parts without A, the VBR is ± 10% and VC is 5% higher than with A parts.
Rev 1: Feb 2018
派克微电子(深圳)有限公司
www.pakermicro.com
Page 2 of 3
1.0SMBJ Series
Ratings and Characteristic Curves
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
100
10
1
0.1
0.001
0.01
0.1
80
60
40
TA - Ambient Temperature (℃)
Fig.1 - Peak Pulse Power Rating
Fig.2 - Pulse Derating Cure
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
10000
100
1000
CJ (pF)
IPP - Peak Pulse Current, % IRSM
150
100
50
td - Pulse Width (ms)
50
100
Uni V=0V
10
Bi V=0V
Uni V=VR
Bi V=VR
tr
1
td
1
100
10
VBR - Reverse Breakdown Voltage (V)
t - Time (us)
Fig.3 – Pulse Waveform
Fig.4 - Typical Junction Capacitance
Package Outline Dimensions: SMB(DO-214AA)
Dim
T
Rev 1: Feb 2018
Millimeters
Inches
Min
Max
Min
Max
L
4.4
4.6
0.173
0.181
D
3.5
3.7
0.138
0.146
D1
1.9
2.1
0.075
0.083
T
5.1
5.48
0.201
0.216
T1
1.0
1.6
0.039
0.063
d
0.2
0.008
H
2.2
2.45
0.087
0.096
H1
2.15
2.35
0.085
0.093
派克微电子(深圳)有限公司
www.pakermicro.com
Page 3 of 3
很抱歉,暂时无法提供与“1.0SMBJ20A”相匹配的价格&库存,您可以联系我们找货
