3.0SMBJ58CAS
3.0SMBJ58CAS
    PAKER(派克微)
    SMB(DO-214AA)
3.0SMBJ58CAS 数据手册
3000W Surface Mount Transinet Voltage Suppression 3.0SMBJ58CAS Features SMB Peak power disspation 3000W@10 x 1000 us Pluse Low incremental surge resistance Excellent clamping capability Glass passivated junction Fast response time Typical IR less than 1uA Halogen free and RoHS compliant Mechanical Data CASE: SMBJ(DO-214AA) Molded Plastic Polarity: By cathode band denites uni-directional decice, none cathode band denotes bi-directional device Mounting Position:Any Symbol Making Code & information Package Packing Description Packing Quantity Tape/Reel,13" reel 3000 SMB 3.0SMBJ 58CAS 3.0SMDJ 58 C A S CSR Tech 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Peak Pulse Power Dissipation on 10/1000 us Waveform (Note 1, 2, FIG.1) Power Dissipation on Infinite Heat Sink at TL=50°C Peak Pulse Voltage on 10/700 us Waveform (Note 1, FIG.3) Peak Pulse Current of on 10/1000us Waveform (Note 1, FIG.3) Peak Forward Surge Current, 8.3ms Single Half Sine-Wave (Note 2. 3) Operating Junction Temperature Range Storage Temperature Range Symbol Value Units PPPM Min 3000 W PD 6.5 W V PPM 4000 V IPPM 32.1 A IFSM 300 A TJ -55 to 150 °C TSTG -55 to 150 °C Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2. 2 2. Mounted on 5.0x5.0mm (0.03mm thick) Copper Pads to each terminal. 3. Measured on 8.3ms single half sine-wave, or equivalent square wave, for Unidirectional device only. Rev 1: Sep 2020 派克微电子(深圳)有限公司 www.pakermicro.com Page 1 of 3 3.0SMBJ58CAS 3000W Surface Mount Transinet Voltage Suppression Electrical Characteristics ( Ratings at 25℃ ambient temperature unless otherwise specified). Type Number Marking 3.0SMBJ58CAS 3.0SMBJ 58CAS Reverse Stand-Off Voltage Breakdown Breakdown Voltage Voltage Min. @IT Max. @ IT Test Current Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @VRMW VC(V) IPP(A) IR(uA) 32.1 2 VRMW(V) VBR MIN(V) VBR MAX(V) IT (mA) 58 64.4 71.2 1.0 48(min) 60(typ) 93(max) I - V Curve Characteristics Parameter Definition CJ Junction Capacitance - typical capacitance measured with 0V or VR bias IPP Peak Pulse Current - maximum rated peak impulse current VC Clamping Voltage - Peak voltage measured across the suppressor at a specified Ippm (peak impulse current) VBR Breakdown Voltage - Maximum voltage that flows though the TVS at a specified test current (IT) IR Leakage Current - maximum peak off-state current measured at VR VR Peak Off-state Voltage - maximum voltage that can be applied while maintaining off state Ratings and Characteristic Curves ( Ratings at 25℃ ambient temperature unless otherwise specified). 100 Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.1 0.001 0.01 0.1 1 td - Pulse Width (ms) 60 40 20 0 0 50 100 150 TA - Ambient Temperature (℃) Fig.1 - Peak Pulse Power Rating Rev 1: Sep 2020 80 派克微电子(深圳)有限公司 www.pakermicro.com Fig.2 - Pulse Derating Curve Page 2 of 3 3.0SMBJ58CAS 3000W Surface Mount Transinet Voltage Suppression Ratings and Characteristic Curves 100 TJ=25℃ f=1.0MHz Vsig=50mVp-p 10000 1000 CJ (pF) IPP - Peak Pulse Current, % IRSM ( Ratings at 25℃ ambient temperature unless otherwise specified). 50 100 Uni V=0V 10 Bi V=0V Uni V=VR Bi V=VR 0 tr 1 td 1 10 100 VBR - Reverse Breakdown Voltage (V) t - Time (us) Fig.3 - Pulse Waveform Fig.4 - Typical Junction Capacitance Package Outline Dimensions: SMB(DO-214AA) Dim T Rev 1: Sep 2020 Millimeters Inches Min Max Min Max L 4.4 4.6 0.173 0.181 D 3.5 3.7 0.138 0.146 D1 1.9 2.1 0.075 0.083 T 5.1 5.48 0.201 0.216 T1 1.0 1.6 0.039 0.063 d - 0.2 - 0.008 H 2.2 2.45 0.087 0.096 H1 2.15 2.35 0.085 0.093 派克微电子(深圳)有限公司 www.pakermicro.com Page 3 of 3
3.0SMBJ58CAS 价格&库存
很抱歉,暂时无法提供与“3.0SMBJ58CAS”相匹配的价格&库存,您可以联系我们找货
