SMBJ18CA
SMBJ18CA
    SET(赛尔特)
    SMB(DO-214AA)
    双向TVS 18V截止 峰值浪涌电流:1A@10/1000US
SMBJ18CA 数据手册
瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes ● 低浪涌电阻 ● 优异的箝位性能 ● 小型化紧凑封装,内部结构去应力设计 ● 12 V 以上电压规格对应漏电典型值低于1.0 μA ● 重复率0.01% 的10/1000 μS 波形对应峰值脉冲功率 600 W ● 表贴应用,节约空间 ● 典型的故障模式为电压或电流超过额定而导致的短路 ● IEC 61000-4-2 ESD 30 kV (空气),30 kV (接触) ● 数据线EFT保护符合IEC 61000-4-4 ● 快速响应时间 瞬态抑制二极管 (TVS) 是一种电路保护元件,它可以削 ● 玻璃钝化保护 弱或过滤突增的瞬态电压(过压),在浪涌到来瞬间几纳 ● 回流焊高温保证:260 °C/30 s 秒时间内发生雪崩击穿,将浪涌电流引至接地端,并将 ● 温度系数典型值0.1% 电压箝位在安全范围内,从而实现了高效能的电压保 ● 密封材料阻燃等级V-0 护。 ● 湿度敏感等级符合MSL 等级1 TVS 概述 Description ● 引脚镀锡 Transient Voltage Suppressor (TVS) is a circuit ● 无卤素,符合RoHS要求 protection component that either attenuates (reduces) ● or filters a transient voltage spike (overvoltage), TVS 无铅E3:二级互连引线无铅,端子镀锡(Sn) (IPC/JEDEC J-STD609A.01) diodes provide critical protection by going into ● Low incremental surge resistance avalanche breakdown within no more than a few ● Excellent clamping capability nanoseconds after a strike, clamping the transient ● Low profile package with built-in strain relief for surface mounted voltage, and routing its current to the ground. 应用 Applications applications ● Typical IR less than 1.0 μA above 12 V ● 600 W peak pulse power capability with a 10/1000 μS Waveform, repetition rate (duty cycle): 0.01% ● For surface mounted applications to optimize board space ● Low profile package,Built-in strain relief ● 通信设备 Communication Equipment ● 安防 Security & Protection ● 工控设备 Industrial Control Equipment ● Typical failure mode is short from over-specified voltage or current ● 电源 Power Supply ● IEC 61000-4-2 ESD 30 kV (Air), 30 kV (Contact) ● 汽车电子 Automotive Electronics ● EFT protection of data lines in accordance with IEC 61000-4-4 ● 新能源设备 New Energy ● Very fast response time ● 防雷保护 Lightning Protection ● Glass passivated chip junction ● High temperature to reflow soldering guaranteed: 260 °C/30sec 功能图 Functional Diagram ● (αT:Temperature Coefficient, typical value is 0.1%) ● 负极 Cathode 正极 Anode 单向 Uni-Directional 双向 Bi-Directional +86 592-571-5838 www.SETsafe.com www.SETfuse.com VBR @ TJ= VBR@25 °C x (1+αT x (TJ - 25)) Plastic package is flammability rated V-0 per Underwriters Laboratories ● Meet MSL level1, per J-STD-020 ● Matte tin lead–free plated ● Halogen free and RoHS compliant ● Pb-free E3 means 2nd level interconnect is Pb-free and the terminal finish material is tin(Sn) (IPC/JEDEC J-STD-609A.01) 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 1 TVS 特性 Features 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 封装尺寸 Package Outline Dimensions (DO-214AA) W1 W L H D T L2 TVS L1 A E B 安装布局 (Mounting Pad Layout) +86 592-571-5838 www.SETsafe.com C www.SETfuse.com Symbol 英制(英寸) Inches Min. Max. Min. Max. L 4.060 4.750 0.160 0.187 W 3.300 3.940 0.130 0.155 W1 1.930 2.200 0.076 0.086 H 1.990 2.610 0.078 0.103 T 0.152 0.305 0.006 0.012 L1 5.210 5.590 0.205 0.220 L2 0.760 1.520 0.030 0.060 D - 0.203 - 0.008 A - 2.740 - 0.107 B 2.160 - 0.085 - C 2.160 - 0.085 - E 2.260 - 0.089 - 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 2 TVS 公制(毫米) Millimeters 符号 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 额定参数与特性 Maximum Ratings and Characteristics 参数 Parameter 符号 Symbol 值 Value 单位 Unit PPPM 600 W 10/1000 μS波形(1)(2)(图4)的峰值脉冲功耗(图2)(注1)、(注2)-双芯片器件(5) Peak Power Dissipation (Fig2) with a 10/1000 μS waveform(1)(2)(Fig.4)-Stacked Die Parts(5) PPPM 800 W 峰值功耗 ,无限散热,TL=50 °C Peak Power Dissipation on Infinite Heat Sink at TL=50 °C PD 5.0 W IFSM 100 A 正向瞬态峰值电压 @ IF=50 A ,仅适用于单向产品 Maximum Instantaneous Forward Voltage at 50 A for Unidirectional Only(4) VF 3.5/5.0 V 工作温度范围 Operating Temperature Range TJ -65 to 150 °C 存储温度范围 Storage Temperature Range TSTG -65 to 175 °C 热阻(结至引线) Typical Thermal Resistance Junction to Lead RθJL 20 °C/W 热阻(结至环境) Typical Thermal Resistance Junction to Ambient RθJA 100 °C/W 10/1000 μS脉冲波形(1)(2)(图4)下,峰值脉冲功耗 (图2)-单芯片器件 Peak Power Dissipation(Fig.2)- with a 10/1000 μS waveform(1)(2)(Fig.4)-Single Die Parts TVS 正向脉冲电流峰值(3),额定负载叠加8.3 ms 单半正弦波测得(JEDEC方法) Peak Forward Surge Current,8.3ms single half sinewave superimposed on rated load (JEDEC Method)(3) 注释 Notes 1. 2. 3. 4. 5. 参照图4非重复性脉冲电流波形,初始结温25 °C 以图3所示曲线降额(环境温度TA=25 ℃ )。 Non-repetitive current pulse, per Fig. 4 and derated above TJ (initial)=25 °C per Fig. 测试安装于5.0 mm 2 焊盘。 Mounted on 5.0 mm 2 land areas. 叠加波形为8.3 ms单个半周期正弦波或等幅方波 , 最长周期4次/min。 Measured of 8.3 ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minute 单芯片VF< 3.5 V,叠层芯片VF< 5.0 V。 VF < 3.5 V for single die parts and VF< 5.0 V for stacked-die parts. 双芯片产品的详细信息,请参阅电气特性中以*标示的部件编号。 For stacked die component details, please refer to models marked with * in electrical characteristics table. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 3 TVS (除另有注释,默认TA=25 ℃ Ratings at 25 °C ambient temperature unless otherwise specified.) 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 型号规则 Part Numbering System SMBJ XX C A 产品系列 Product Series 反向关断电压 Reverse Stand-off Voltage C: 双向 Bi-directional None: 单向 uni-direction TVS TVS 5% VBR 电压容差 5% VBR Voltage tolerance 标记 Marking 阴极线 Cathode Band SET SET XXX YMXXX YMXXX 商标 Trademark +86 592-571-5838 XXX 日期代码 Data Code 标记代码 Marking Code 商标 Trademark 日期代码 Data Code Y-年 Year Y-年 Year M-月 Month M-月 Month XXX-批次号 Lot code XXX-批次号 Lot code www.SETsafe.com www.SETfuse.com 标记代码 Marking Code 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 4 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 术语 Glossary 项目 Item 描述 Description 箝位电压 Clamping Voltage VC TVS在低差阻区域内的电压,用于限制设备两端的电压。 Voltage across TVS in a region of low differential resistance that serves to limit the voltage across the device terminals. TVS VR TVS 在没有导通状态下最高电压。 Maximum voltage that can be applied to the TVS without operation. 注:也用VWM(最高直流工作电压)表示,也称为截止电压(Vso)。 NOTE : It is also shown as VWM (maximum working voltage (maximum d.c. voltage)) and known as rated standoff voltage (Vso). 反向漏电流 Reverse Leakage Current IR 量测VR的电流。 Current measured at VR. 注:也用ID 待机电流表示。 NOTE : Also shown as ID for stand-by current. 击穿电压 Breakdown Voltage VBR 在击穿区以指定电流IT (测试电流)通过TVS的电压。 Voltage across TVS at a specified current IT (test current) in the breakdown region. 额定随机重复峰值脉冲电流 Rated Random Recurring Peak Impulse Current IPPM 施加在设备上的随机重复峰值脉冲电流的最大额定值。 Maximum-rated value of random recurring peak impulse current that may be applied to a device. 额定平均功率 Rated Average Power Dissipation PM(AV) 所有电源(包括瞬态电流和待机电流)在短时间内平均产生的最大额定功耗。 Maximum-rated value of power dissipation resulting from all sources, including transients and standby current, averaged over a short period of time. 额定随机重复峰值脉冲功率 Rated Random Recurring Peak Impulse Power Dissipation PPPM 额定随机重复峰值脉冲电流(IPPM) 和规定的最大箝位电压(VC)乘积的最大额定值。 Maximum-rated value of the product of rated random recurring peak impulse current (IPPM) multiplies by specified maximum clamping voltage (VC). 电容 Capacitance CJ 在规定的频率和电压下所测量的TVS电容。 Capacitance across the TVS measured at a specified frequencyx and voltage. —(GB-T 18802.321 / IEC 61643-321 / JESD210A) +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 5 TVS 反向关断电压 Reverse Stand-off Voltage 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 项目 Item 描述 Description 正向浪涌峰值电压 Peak Forward Surge Voltage VFS 在指定的正向浪涌电流(IFS)和持续时间下,通过TVS的峰值电压。 Peak voltage across TVS for a specified forward surge current (IFS) and time duration. 注:也用VF 表示。 NOTE : Also shown as VF. 正向浪涌电流 Forward Surge Current 在正向导通区域通过TVS的脉冲电流。 Pulsed current through TVS in the forward conducting region. 注:也用IF表示。 NOTE : Also shown as IF. 击穿电压温度系数 Temperature Coefficient of Breakdown Voltage αV(BR) 击穿电压的变化与温度变化的比值。 The change of breakdown voltage divided by the change of temperature. 峰值脉冲电流 Peak pulse Current IPP 施加在TVS上的峰值脉冲电流,以确定箝位电压VC 的特定波形。 Peak pulse current value applied across the TVS to determine the clamping voltage VC for a specified wave shape. 脉冲直流测试电流 Pulsed D.C. Test Current IT 测量击穿电压VBR的试测试电流。该电流值由制造商确定,通常以脉冲持续时间小于40 ms的毫安级电流给出。 Test current for measurement of the breakdown voltage VBR. This is defined by the manufacturer and usually given in milliamperes with a pulse duration of less than 40 ms. 注:也用IBR表示。 NOTE : Also shown as IBR . —(GB-T 18802.321 / IEC 61643-321 / JESD210A) +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 6 TVS TVS IFS 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 型号 Part Number 标记代码 Device Marking Code 击穿电压 Breakdown Voltage VBR@IT TVS Min Uni Bi Uni Bi SMBJ5.0A SMBJ5.0CA KE AE 6.4 SMBJ6.0A SMBJ6.0CA KG AG SMBJ6.5A SMBJ6.5CA KK SMBJ7.0A SMBJ7.0CA SMBJ7.5A Max 反向关断 最大反向 最大峰值 最大箝位 电流 电压 Test Reverse Current Stand-off IT Voltage VR 漏电流 Max. Reverse Leakage IR@VR 脉冲电流 Max. Peak Pulse Current IPP 电压 Max. Clamping Voltage VC@IPP (mA) (V) (μA) (A) (V) 7 10 5 800 65.3 9.2 6.67 7.37 10 6 800 58.3 10.3 AK 7.22 7.98 10 6.5 500 53.6 11.2 KM AM 7.78 8.6 10 7 200 50 12 SMBJ7.5CA KP AP 8.33 9.21 1 7.5 100 46.6 12.9 SMBJ8.0A SMBJ8.0CA KR AR 8.89 9.83 1 8 50 44.2 13.6 SMBJ8.5A SMBJ8.5CA KT AT 9.44 10.4 1 8.5 20 41.7 14.4 SMBJ9.0A SMBJ9.0CA KV AV 10 11.1 1 9 10 39 15.4 SMBJ10A SMBJ10CA KX AX 11.1 12.3 1 10 5 35.3 17 SMBJ11A SMBJ11CA KZ AZ 12.2 13.5 1 11 1 33 18.2 SMBJ12A SMBJ12CA LE BE 13.3 14.7 1 12 1 30.2 19.9 SMBJ13A SMBJ13CA LG BG 14.4 15.9 1 13 1 28 21.5 SMBJ14A SMBJ14CA LK BK 15.6 17.2 1 14 1 25.9 23.2 SMBJ15A SMBJ15CA LM BM 16.7 18.5 1 15 1 24.6 24.4 SMBJ16A SMBJ16CA LP BP 17.8 19.7 1 16 1 23.1 26 SMBJ17A SMBJ17CA LR BR 18.9 20.9 1 17 1 21.8 27.6 SMBJ18A SMBJ18CA LT BT 20 22.1 1 18 1 20.6 29.2 SMBJ20A SMBJ20CA LV BV 22.2 24.5 1 20 1 18.6 32.4 SMBJ22A SMBJ22CA LX BX 24.4 26.9 1 22 1 16.9 35.5 SMBJ24A SMBJ24CA LZ BZ 26.7 29.5 1 24 1 15.5 38.9 SMBJ26A SMBJ26CA ME CE 28.9 31.9 1 26 1 14.3 42.1 SMBJ28A SMBJ28CA MG CG 31.1 34.4 1 28 1 13.3 45.4 SMBJ30A SMBJ30CA MK CK 33.3 36.8 1 30 1 12.4 48.4 SMBJ33A SMBJ33CA MM CM 36.7 40.6 1 33 1 11.3 53.3 SMBJ36A SMBJ36CA MP CP 40 44.2 1 36 1 10.4 58.1 SMBJ40A SMBJ40CA MR CR 44.4 49.1 1 40 1 9.3 64.5 SMBJ43A SMBJ43CA MT CT 47.8 52.8 1 43 1 8.7 69.4 SMBJ45A SMBJ45CA MV CV 50 55.3 1 45 1 8.3 72.7 SMBJ48A SMBJ48CA MX CX 53.3 58.9 1 48 1 7.8 77.4 +86 592-571-5838 www.SETsafe.com www.SETfuse.com (V) 测试 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 7 TVS 电气特性 ( 除另有注释,默认TA=25 ℃ ) Electrical Characteristics (TA=25 °C unless otherwise noted )Table 1 瞬态抑制二极管 TVS Diodes 型号 Part Number 标记代码 Device Marking Code 击穿电压 Breakdown Voltage VBR@IT TVS Min Uni Bi Uni Bi SMBJ51A SMBJ51CA MZ CZ 56.7 SMBJ54A SMBJ54CA NE DE SMBJ58A SMBJ58CA NG SMBJ60A SMBJ60CA SMBJ64A Max (V) 测试 反向关断 最大反向 最大峰值 最大箝位 电流 电压 Test Reverse Current Stand-off IT Voltage VR 漏电流 Max. Reverse Leakage IR@VR 脉冲电流 Max. Peak Pulse Current IPP 电压 Max. Clamping Voltage VC@IPP (mA) (V) (μA) (A) (V) 62.7 1 51 1 7.3 82.4 60 66.3 1 54 1 6.9 87.1 DG 64.4 71.2 1 58 1 6.5 93.6 NK DK 66.7 73.7 1 60 1 6.2 96.8 SMBJ64CA NM DM 71.1 78.6 1 64 1 5.9 103 SMBJ70A SMBJ70CA NP DP 77.8 86 1 70 1 5.3 113 SMBJ75A SMBJ75CA NR DR 83.3 92.1 1 75 1 5 121 SMBJ78A SMBJ78CA NT DT 86.7 95.8 1 78 1 4.8 126 SMBJ85A SMBJ85CA NV DV 94.4 104 1 85 1 4.4 137 SMBJ90A SMBJ90CA NX DX 100 111 1 90 1 4.1 146 SMBJ100A SMBJ100CA NZ DZ 111 123 1 100 1 3.7 162 SMBJ110A SMBJ110CA PE EE 122 135 1 110 1 3.4 177 SMBJ120A SMBJ120CA PG EG 133 147 1 120 1 3.1 193 SMBJ130A SMBJ130CA PK EK 144 159 1 130 1 2.9 209 SMBJ150A SMBJ150CA PM EM 167 185 1 150 1 2.5 243 SMBJ160A SMBJ160CA PP EP 178 197 1 160 1 2.3 259 SMBJ170A SMBJ170CA PR ER 189 209 1 170 1 2.2 275 SMBJ180A SMBJ180CA PT ET 201 222 1 180 1 2.1 292 SMBJ188A SMBJ188CA PB EB 209 231 1 188 1 2 304 SMBJ200A SMBJ200CA PV EV 224 247 1 200 1 1.9 324 SMBJ220A SMBJ220CA PX EX 246 272 1 220 1 1.7 356 SMBJ250A SMBJ250CA PZ EZ 279 309 1 250 1 1.5 405 SMBJ300A* SMBJ300CA* QE FE 335 371 1 300 1 1.7 486 SMBJ350A* SMBJ350CA* QG FG 391 432 1 350 1 1.5 567 SMBJ400A* SMBJ400CA* QK FK 447 494 1 400 1 1.3 648 SMBJ440A* SMBJ440CA* QM FM 492 543 1 440 1 1.1 713 注释 Notes: 1.对于VR为10 V及更低的双向产品,IR值需乘以两倍。 For bidirectional type having VR of 10 volts and less, the IR should be doubled. 2.对于没有A的产品,VBR范围为±10%且VC也比有A的产品高5%,当前不推荐没有A的产品用于新设计,带A的产品推荐优先选用。 For parts without A in the PN, the VBR tolerance is ± 10% and VC is 5% higher than parts with A. The parts without A are currently available, but not recommended for new designs. The parts with A are preferred. 3.双芯片产品的详细信息,请参阅电气特性中以*标示的部件编号 。 For stacked die component details, please refer to models marked with * in electrical characteristics table. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 8 TVS SMBJ Series Transient Voltage Suppression Diodes 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 伏安特性曲线 I-V Curve Characteristics IF 单向 Uni-directional VC 双向 Bi-directional VBR VWM VC VBR VWM ID VF IT IPP IT ID ID IT IPP 脉冲峰值功率 PPPM - Peak Pulse Power (KW) 电压/电流 Voltage or Current Voltage Transient Voltage Across TVS Current Through TVS Time 100 TJ (initial)=Tamb Stacked die,800W At 10×1000µs,25 °C 10 Signal die,600W At 10×1000µs,25 °C 1.0 0.1 60 40 20 0 0 25 50 75 100 120 150 175 0.1 1 10 td – 脉宽 Pulse Width (ms) FIGURE 2 峰值脉冲功率额定曲线 Peak Pulse Power Rating Curve IPPM - 峰值脉冲电流 Peak Pulse Current, % IRSM 80 0.01 0.001 FIGURE 1 TVS瞬态箝位波形 TVS Transients Clamping Waveform 100 TVS 参考性能曲线(除有另外注释,默认TA=25 ℃ ) Performance Curve for Reference(TA=25 °C unless otherwise noted) 降额百分比 Peak Pulse Power (PPP) or Current (IPPM) Derating in Percentage, % TVS IPP VWM VBR VC TJ –初始结温 Initial Junction Temperature (°C ) 150 Tr=10μs TJ = 25 °C Pulse Width (td) is defined as the Point where the Peak Current decays to 50 % of IPPM Peak Value IPPM 100 Half Value IPPM/2 10/1000 μs Waveform as defined by R.E.A. 50 td 0 0 1.0 2.0 3.0 4.0 t –时间 Time (ms) FIGURE 3 峰值脉冲功率降额曲线 Peak Pulse Power Derating Curve +86 592-571-5838 www.SETsafe.com www.SETfuse.com FIGURE 4 脉冲波形 Pulse Waveform 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 9 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes Uni-direction at Zero-bias 1000 电容 CJ –(pF) Bi-direction at Zero-bias 100 Bi/Uni direction at 10 VR-bias 1 TVS 1 10 100 1000 100 10 1 0.1 0.01 0.001 0.01 0.1 VBR – 反向击穿电压 Reverse Breakdown Voltage (V) 10 100 1000 TP – 脉宽 Pulse Duration (s) FIGURE 5 典型结电容 Typical Junction Capacitance FIGURE 6 典型瞬态热阻 Typical Transient Thermal Impedance 120 100.0 IF– 正向峰值电流 Peak Forward Current (A) IFSM - 正向浪涌峰值电流 Peak Forward Surge Current (A) 1 TVS 瞬态热阻 Transient Thermal Impedance (°C /W) 10000 100 80 60 40 20 0 1 10 100 Single die Stacked die 10.0 1.0 0.1 0.0 1.0 2.0 60 Hz周波数 Number of Cycles at 60 Hz 3.0 4.0 5.0 6.0 7.0 8.0 9.0 VF– 正向峰值电压 Peak Forward Voltage (V) FIGURE 7 最大非重复正向浪涌电流(单向型) FIGURE 8 峰值正向电压及电流(典型值) Maximum Non-Repetitive Forward Surge Current Peak Forward Drop vs Peak Forward Current (Typical Values) Uni-Directional only 环境特性 Environmental Specifications 物理特性 Physical Specifications 高温存储 High Temp. Storage JESD22-A103 高温反偏 HTRB JESD22-A108 温度循环 Temperature Cycling JESD22-A104 湿度敏感性等级 MSL JESDEC-J-STD-020, Level 1 高温高湿反偏 H3TRB JESD22-A101 耐焊接热 RSH JESD22-A111 +86 592-571-5838 www.SETsafe.com www.SETfuse.com 重量 Weight 0.003 ounce,0.093 grams 封装 Case JESD22DO214AA. Molded plastic body 极性 Polarity Color band denotes positive end 端子 Terminal Matte Tin-plated leads, Solderability per over glass passivated junction (cathode) except Bidirectional JESD22-B102 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 10 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 焊接参数 Soldering Parameters tP TP Ramp-up tL TS (max) TS (min) Ramp-down tS Preheat TVS 温度 Temperature (T) TL TVS Critical Zone TL to TP 25°C t 25°C to Peak 时间 Time (t) 回流焊条件 Reflowing Condition 回流焊接参数 Reflow Soldering Parameters 预热 Pre-heat 无铅组装 Lead-Free Assembly 最低温(TS (min)) Temperature Min (TS (min)) 150 °C 最高温(TS (max)) Temperature Max (TS (max)) 200 °C 升温时长(tS) Time (min to max) (tS) 60 ~ 120 seconds 平均升温速率(液相温度(TL)至峰值温度(TP)) 3 °C / second max. Average Ramp-up Rate ( Liquidus Temp (TL) to Peak Temp (TP)) TS (max) 到TL升温速率 3 °C / second max. TS (max) to TL Ramp-up Rate 温度 Temperature (TL) (Liquidus) 回流 Reflow 时长 Time (min to max) (tL) 实际峰值温度 (tP) 5 °C 以内的时间 Time of within 5 °C of Actual Peak Temperature (tP) 降温速率 Ramp-down Rate 8 Minutes max. 260 °C 极限温度 Do Not Exceed www.SETfuse.com 20 ~ 40 seconds 6 °C / second max. 25 °C 至峰值温度时长 Time from 25 °C to Peak Temperature www.SETsafe.com 60 ~ 150 seconds 260+0/-5 °C 峰值温度 Peak Temperature (TP) +86 592-571-5838 217 °C 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 11 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 编带 Tape P2 P0 T B0 W F E D0 TVS D1 A0 符号 Symbol 尺寸 Dimension (mm) W 12.00+0.30/-0.10 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.05 D0 1.55±0.05 D1 1.55±0.05 E 1.75±0.1 F 5.50±0.05 A0 3.78±0.10 B0 5.65±0.15 K0 2.70±0.10 T 0.30±0.05 P1 K0 卷盘尺寸 Reel Size 13寸卷盘 13” Reel A A 330 mm C 13.2 mm W1 12.5 mm C Arbor hole Dia. Direction of Feed W1 型号 Part Number 封装 Package 卷盘数量QTY (Reel) 包装选项 Packaging Option 包装规格 Packaging Specification SMBJ××× DO-214AA 3000 PCS Tape & Reel – 12 mm tape/13” reel EIA STD RS-481 +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 12 TVS 包装信息 Packaging Information 瞬态抑制二极管 TVS Diodes SMBJ Series TVS TVS Transient Voltage Suppression Diodes 注意 ATTENTION 使用方法 Usage 1. 2. 3. 请在规定的温度范围内使用TVS。 TVS must be operated in the specified ambient temp. 请勿使用强极性溶剂清洗TVS以免破坏封装层。 Do not clean the TVS with strong polar solvent such as ketone, esters, benzene and halogenated hydrocarbon, to avoid damaging the encapsulating layer. 请勿对TVS施加剧烈的振动,冲击或压力,以避免元件开裂。 Please do not apply severe vibration, shock or pressure to TVS, to avoid element cracking. 更换 Replacement 1. 2. 若TVS出现可视化损伤,请将其更换。 If TVS is visually damaged, please replace it. TVS为非修理型产品,安全起见,请更换同等规格的TVS。 TVS is a non-repairable product. For safety sake, please use equivalent TVS for replacement. 存储 Storage 1. 存储温度范围。 Storage Temp. Range: (-55 to 150) °C. 2. 请勿将TVS存放于高温高湿或腐蚀性气体环境中,已避免影响引脚的焊接性能,请于收货后一年内进行使用 。 Do not store the TVS at the high temp., high humidity or corrosive gas environment, to avoid influencing the solder-ability of the lead wires. The product shall be used up within 1 year after receiving the goods. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 13 瞬态抑制二极管 TVS Diodes SMBJ Series Transient Voltage Suppression Diodes 环境条件 Environmental Conditions 1. 2. 3. 请勿暴露于室外阳光直射环境。 TVS should not be exposed to the open air, nor direct sunshine. 请避免雨水,水汽等高温高湿环境。 TVS should avoid rain, water vapor or other condition of high temp. and high humidity. 请避免沙尘,盐雾等有害环境。 TVS should avoid sand dust, salt mist, or other harmful gases. TVS最大典型结电容 Max. Typical Capacitance of TVS 高频线路应用中请参照规格书中所给出的典型电容曲线。 The typical capacitance of TVS is listed in the specifications. Designers may refer to it when designing TVS in high frequency circuit. 1. 安装TVS时请避免敲击,防止物理损伤。 TVS TVS 安装机械应力 Installation Mechanical Stress Do not knock TVS when installing, to avoid mechanical damage. 2. 请不要对 TVS 施加剧烈的振动、冲击或压力,以免表面树脂或元件破裂。 Please do not apply severe vibration, shock or pressure to TVS, to avoid surface resin or element cracking. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 14
SMBJ18CA 价格&库存
很抱歉,暂时无法提供与“SMBJ18CA”相匹配的价格&库存,您可以联系我们找货
