SMBJ18CA
SMBJ18CA
    PTTC(聚鼎)
    SMB(DO-214AA)
    双向TVS 18V截止 峰值浪涌电流:20.6A@10/1000US
SMBJ18CA 数据手册
T VS Diode – SMBJ Series Features          Plastic package, excellent insulation strength. Glass passivated chip junction in SMB package. Excellent voltage clamping capability. Low Zener impedance. 600W peak pulse power capability on 10/1000s waveform. Typical leakage current less than 1A above 13V. Very fast response time, typically less than 1.0ps from 0 volt to VBR minimum. High temperature soldering guaranteed: 265°C/10 sec. MSL: JEDEC-J-STD-020, Level 1 Applications     I/O interface, VCC bus Telecom Industrial and consumer electronic applications. Relay and electromagnetic valve surge absorption. Agency Approval  UL file no.: E474915 Mechanical and Physical Data   Case: JEDEC SMB molded plastic. Axial leaded, solderable per MIL-STD-750, Method 2026  Polarity: Color band denoted cathode except bidirectional. Maximum Ratings and Thermal Characteristics Parameter Peak Pulse Power Dissipation on 10/1000s waveform (Note 1, Fig.1). Peak Pulse Current of 10/1000s waveform (Note 1, Fig.3). Steady State Power Dissipation at TL = 75°C, Lead lengths 0.375”, (9.5mm) (Fig.5). Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated Load (Note 2, Fig.6). Operating Junction and Storage Temperature Range. Symbol Value Unit PPPM Min 600 Watt IPPM See Table Amp PM(AV) 5.0 Watt IFSM 100 Amp TJ, TSTG -55~150 °C Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig.2. 2. 8.3ms single half sine wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. Part Number Code SMBJ □□□ C A - □□□ Packaging Code (T13: Tape with 13” Reel; T7: Tape with 7”) VBR Voltage tolerance (A: 5%; Blank: 10%) C: Bi-directional; Blank: Uni-directional Reverse Stand-Off Voltage or Typical Breakdown Voltage SMBJ Series (600W) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 6 2016/12/1 Rev: A T VS Diode – SMBJ Series I-V Curve Characteristics PPPM Peak Pulse Power Dissipation – Maximum power dissipation VR Stand-off Voltage – Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage – Maximum voltage that flows through the TVS at a specified test current (IT) VC Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (Peak Impulse Current) IR Reverse Leakage Current – Current measured at VR VF Forward Voltage Drop for Uni-directional Electrical Characteristics Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR UL Uni Bi Uni Bi SMBJ5.0A SMBJ5.0CA KE AE 5.0 6.40 7.00 10 9.2 65.3 800  SMBJ6.0A SMBJ6.0CA KG AG 6.0 6.67 7.37 10 10.3 58.3 800  SMBJ6.5A SMBJ6.5CA KK AK 6.5 7.22 7.98 10 11.2 53.6 500  SMBJ7.0A SMBJ7.0CA KM AM 7.0 7.78 8.60 10 12.0 50.0 200  SMBJ7.5A SMBJ7.5CA KP AP 7.5 8.33 9.21 1 12.9 46.6 100  SMBJ8.0A SMBJ8.0CA KR AR 8.0 8.89 9.83 1 13.6 44.2 50  SMBJ8.5A SMBJ8.5CA KT AT 8.5 9.44 10.4 1 14.4 41.7 20  SMBJ9.0A SMBJ9.0CA KV AV 9.0 10.0 11.1 1 15.4 39.0 10  SMBJ10A SMBJ10CA KX AX 10.0 11.1 12.3 1 17.0 35.3 5  SMBJ11A SMBJ11CA KZ AZ 11.0 12.2 13.5 1 18.2 33.0 1  SMBJ12A SMBJ12CA LE BE 12.0 13.3 14.7 1 19.9 30.2 1  SMBJ13A SMBJ13CA LG BG 13.0 14.4 15.9 1 21.5 28.0 1  SMBJ14A SMBJ14CA LK BK 14.0 15.6 17.2 1 23.2 25.9 1  SMBJ15A SMBJ15CA LM BM 15.0 16.7 18.5 1 24.4 24.6 1  SMBJ16A SMBJ16CA LP BP 16.0 17.8 19.7 1 26.0 23.1 1  SMBJ17A SMBJ17CA LR BR 17.0 18.9 20.9 1 27.6 21.8 1  SMBJ18A SMBJ18CA LT BT 18.0 20.0 22.1 1 29.2 20.6 1  新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 6 2016/12/1 Rev: A T VS Diode – SMBJ Series Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR UL Uni Bi Uni Bi SMBJ20A SMBJ20CA LV BV 20.0 22.2 24.5 1 32.4 18.6 1  SMBJ22A SMBJ22CA LX BX 22.0 24.4 26.9 1 35.5 16.9 1  SMBJ24A SMBJ24CA LZ BZ 24.0 26.7 29.5 1 38.9 15.5 1  SMBJ26A SMBJ26CA ME CE 26.0 28.9 31.9 1 42.1 14.3 1  SMBJ28A SMBJ28CA MG CG 28.0 31.1 34.4 1 45.4 13.3 1  SMBJ30A SMBJ30CA MK CK 30.0 33.3 36.8 1 48.4 12.4 1  SMBJ33A SMBJ33CA MM CM 33.0 36.7 40.6 1 53.3 11.3 1  SMBJ36A SMBJ36CA MP CP 36.0 40.0 44.2 1 58.1 10.4 1  SMBJ40A SMBJ40CA MR CR 40.0 44.4 49.1 1 64.5 9.3 1  SMBJ43A SMBJ43CA MT CT 43.0 47.8 52.8 1 69.4 8.7 1 Pending SMBJ45A SMBJ45CA MV CV 45.0 50.0 55.3 1 72.7 8.3 1 Pending SMBJ48A SMBJ48CA MX CX 48.0 53.3 58.9 1 77.4 7.8 1 Pending SMBJ51A SMBJ51CA MZ CZ 51.0 56.7 62.7 1 82.4 7.3 1 Pending SMBJ54A SMBJ54CA NE DE 54.0 60.0 66.3 1 87.1 6.9 1 Pending SMBJ58A SMBJ58CA NG DG 58.0 64.4 71.2 1 93.6 6.5 1 Pending SMBJ60A SMBJ60CA NK DK 60.0 66.7 73.7 1 96.8 6.2 1 Pending SMBJ64A SMBJ64CA NM DM 64.0 71.1 78.6 1 103.0 5.9 1 Pending SMBJ70A SMBJ70CA NP DP 70.0 77.8 86.0 1 113.0 5.3 1 Pending SMBJ75A SMBJ75CA NR DR 75.0 83.3 92.1 1 121.0 5.0 1 Pending SMBJ78A SMBJ78CA NT DT 78.0 86.7 95.8 1 126.0 4.8 1 Pending SMBJ85A SMBJ85CA NV DV 85.0 94.4 104.0 1 137.0 4.4 1 Pending SMBJ90A SMBJ90CA NX DX 90.0 100.0 111.0 1 146.0 4.1 1 Pending SMBJ100A SMBJ100CA NZ DZ 100.0 111.0 123.0 1 162.0 3.7 1 Pending SMBJ110A SMBJ110CA PE EE 110.0 122.0 135.0 1 177.0 3.4 1 Pending SMBJ120A SMBJ120CA PG EG 120.0 133.0 147.0 1 193.0 3.1 1 Pending SMBJ130A SMBJ130CA PK EK 130.0 144.0 159.0 1 209.0 2.9 1 Pending SMBJ150A SMBJ150CA PM EM 150.0 167.0 185.0 1 243.0 2.5 1 Pending SMBJ160A SMBJ160CA PP EP 160.0 178.0 197.0 1 259.0 2.3 1 Pending SMBJ170A SMBJ170CA PR ER 170.0 189.0 209.0 1 275.0 2.2 1 Pending SMBJ180A SMBJ180CA PT ET 180.0 201.0 222.0 1 292.0 2.1 1 Pending SMBJ190A SMBJ190CA PA EC 190.0 209.0 243.0 1 308.0 2.0 1 Pending SMBJ200A SMBJ200CA PV EV 200.0 224.0 247.0 1 324.0 1.9 1 Pending SMBJ220A SMBJ220CA PX EX 220.0 246.0 272.0 1 356.0 1.7 1 Pending SMBJ250A SMBJ250CA PZ EZ 250.0 279.0 309.0 1 405.0 1.5 1 Pending SMBJ300A SMBJ300CA QE FE 300.0 335.0 371.0 1 486.0 1.3 1 Pending SMBJ350A SMBJ350CA QG FG 350.0 391.0 432.0 1 567.0 1.1 1 Pending SMBJ400A SMBJ400CA QK FK 400.0 447.0 494.0 1 648.0 0.9 1 Pending SMBJ440A SMBJ440CA QM FM 440.0 492.0 543.0 1 713.0 0.9 1 Pending Note: 1. For bi-directional type having VR of 10 volts and less, the IR limit is double. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 6 2016/12/1 Rev: A T VS Diode – SMBJ Series Ratings and Characteristic Curves Fig 1 - Peak Pulse Power Rating Curve Fig 2 - Pulse Derating Curve Fig 3 - Pulse Waveform Fig 4 – Typical Junction Capacitance Fig 5 – Steady State Power Dissipation Derating Curve Fig 6 – Maximum Non-Repetitive Forward Surge Current (Uni-directional Only) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 6 2016/12/1 Rev: A T VS Diode – SMBJ Series Marking Definitions PolyTrans Trade mark Lot No Marking Code Cathode Band (For Uni-directional product only) Physical Dimensions Dimension A B C D E F G H I J K L Millimeters Inches Min Max Min Max 1.90 4.06 3.30 1.95 0.76 5.21 0.15 2.26 2.16 2.16 2.20 4.70 3.94 2.44 1.52 0.20 5.59 0.31 2.74 - 0.077 0.160 0.130 0.084 0.030 0.205 0.006 0.089 0.085 0.085 0.086 0.180 0.155 0.096 0.060 0.008 0.220 0.012 0.107 - Lead Free Reflow Soldering Recommendations Preheat - Temperature Min (Ts_min) - Temperature Max (Ts_max) - Time (Ts_min to Ts_max) - Average Ramp-Up Rate 150ºC 200ºC 60-180 seconds 1~3ºC/second Peak Temperature 260ºC max. Time within 5ºC of actual Peak Temperature (tp) 40 seconds max. Ramp-Down Rate 6 ºC /second max. Note: If the soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 6 2016/12/1 Rev: A T VS Diode – SMBJ Series Packaging Information Part Number Packaging Code Component Package Quantity SMBJ Series SMBJ Series T13 T7 DO-214AA DO-214AA 3000 500 Packaging Option Tape & Reel – 12mm tape/13” reel Tape & Reel – 12mm tape/7” reel Packaging Specification EIA STD RS-481 EIA STD RS-481 Tape and Reel Specifications 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 6 2016/12/1 Rev: A
SMBJ18CA 价格&库存
很抱歉,暂时无法提供与“SMBJ18CA”相匹配的价格&库存,您可以联系我们找货
