SMBJ36A
SMBJ36A
    AGERTECH(艾吉芯)
    SMB(DO-214AA)
    SMB系列旨在保护电压敏感元件免受高压、高能瞬变的影响。它们具有出色的钳位能力、高浪涌能力、低齐纳阻抗和快速响应时间。SMB系列非常适合用于通信系统、汽车、数控、过程控制、医疗设备、商用机器、电源和许...
SMBJ36A 数据手册
SMBJ Series SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS Power Dissipaton-600W Stand-off Voltage-5.0V to 440V General information The SMB series is designed to protect voltage sensitive components from high voltage, high energy transients. They have excellent clamping capability, high surge capability, low zener impedance and fast response time. The SMB series is supplied in AT Semiconductor’s exclusive, cost-effective, highly reliable and is ideally suited for use in communication systems, automotive, numerical controls, process Molded plastic controls, medical equipment, business machines, power supplies and many other glass passivated junction. industrial/consumer Applications. Features  Case: DO-214AA/SMB Applications  For surface mounted applications in order to optimize board space. TVS  Polarity: Color band denoted positive end (cathode) except Bidirectional. protection of I/O Interfaces, VCC bus  Typical failure mode is short from over-specified voltage or current and other vulnerable circuits used in  High Temperature soldering:260°C/10 seconds at terminals. Telecom, Computer, Industrial  Terminal: Solder plated, solderable per MIL-STD-750,Method 2026. Consumer electronic applications. devices are ideal for the and Absolute maximum ratings (Ta=25℃ unless otherwise noted) Parameter Minimum Peak Pulse Power Dissipation (T = 1 ms) (note1 note 2) Symbol Value Unit PPK 600 Watts IFSM 100 Amps PM(AV) 5.0 Watts VF 3.5/5 Volts TJ -55 to +150 °C TSTG -55 to +150 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) (Note 3) Steady State Power Dissipation @ TL = 75 °C Maximum Instantaneous Forward Voltage @ I PP = 50 A (For Unidirectional Units Only)(note4 note 5) Operating Temperature Range Storage Temperature Range NOTES: 1. Non-repetitive current pulse, per Pulse Waveform graph and derated above TA = 25 °C per Pulse Derating Curve. 2. Thermal Resistance Junction to Lead. 3. 8.3 ms Single Half-Sine Wave duty cycle = 4 pulses maximum per minute (unidirectional units only). 4. Single Phase, Half Wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20 %. 5. VF
