SMBJ58A
SMBJ58A
    JF(晶发)
    SMB(DO-214AA)
    单向TVS 58V截止 峰值浪涌电流:6.7A
SMBJ58A 数据手册
SMBJ5. 0 THRU SMBJ170 R TRANSIENT VOLTAGE SUPPRESSOR Reverse Voltage - 5.0 to 170 Volts PEAK PULSE POWER-600 Watts S E M I C O N D U C T O R FEATURES SMB(DO-214AA) 600 Watts Pulse capability Excellent clamping capability Low incremental surge resistance Fast response time High temperature soldering guaranteed: 260 C/10 seconds at terminals Component inaccordance to RoHS 2002/95/EC and WEEE 2002/96/EC 0.155(3.94) 0.130(3.30) 0.086(2.20) 0.077(1.95) 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) 0.096(2.44) 0.084(2.13) MECHANICAL DATA 0.008(0.203) MAX 0.060(1.52) 0.030(0.76) Case: JEDEC SMB(DO-214AA) molded plastic body Terminals: solder plated ,solderable per MIL-STD-750,method 2026 Polarity: color band denotes cathode except Bipolar Weight: 0.003ounce,0.093 gram 0.220(5.59) 0.200(5.08) Dimensions in inches and (millimeters) DEVICES FOR BIDIRECTIONAL APPLICATIONS 1. For bi-directional use C or CA suffix for Types SMBJ5.0 through Types SMBJ170. 2. Electrical characteristics apply in both directions. MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (Rating at 25 C ambient temperature unless otherwise specified) Symbols Valuse Units Peak power dissipation(Note 1) PPK Min.600 Watts Steady state power dissipation at Tj=75 C lead length 0.375"(9.5mm) Note( 2) PM 2.0 Watts Peak forward surge current,8.3ms single half sine-wave superimposed on rated load (JEDEC method)(Note 3) IFSM 100 Amps 3.5/5.0 Volts -55 to +175 C Maximum instantaneous forward voltage at 50.0A for unidirectional only VF TJ,TSTG Operating jumction and storage temperature range Note: 1.Non repetitive current pulse and derated above TA=25 C, T P =1ms 2.Mounted on copper pads area of (40X40mm) 3.Measured on 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minute maximum JINAN JINGHENG ELECTRONICS CO., LTD. 13-26 HTTP://WWW.JINGHENGGROUP.COM RATINGS AND CHARACTERISTIC CURVES( SMBJ SERIES) TYPE SMBJ5.0 SMBJ5.0A SMBJ6.0 SMBJ6.0A SMBJ6.5 SMBJ6.5A SMBJ7.0 SMBJ7.0A SMBJ7.5 SMBJ7.5A SMBJ8.0 SMBJ8.0A SMBJ8.5 SMBJ8.5A SMBJ9.0 SMBJ9.0A SMBJ10 SMBJ10A SMBJ11 SMBJ11A SMBJ12 SMBJ12A SMBJ13 SMBJ13A SMBJ14 SMBJ14A SMBJ15 SMBJ15A SMBJ16 SMBJ16A SMBJ17 SMBJ17A SMBJ18 SMBJ18A SMBJ20 SMBJ20A SMBJ22 SMBJ22A SMBJ24 SMBJ24A SMBJ26 SMBJ26A SMBJ28 SMBJ28A SMBJ30 SMBJ30A Breakdown Voltage V(BR)(Volts) MIN 6.40 6.40 6.67 6.67 7.22 7.22 7.78 7.78 8.33 8.33 8.89 8.89 9.44 9.44 10.0 10.0 11.1 11.1 12.2 12.2 13.3 13.3 14.4 14.4 15.6 15.6 16.7 16.7 17.8 17.8 18.9 18.9 20.0 20.0 22.2 22.2 24.4 24.4 26.7 26.7 28.9 28.9 31.1 31.1 33.3 33.3 MAX 7.30 7.00 8.15 7.37 8.82 7.98 9.51 8.60 10.3 9.21 10.9 9.83 11.5 10.4 12.2 11.1 13.6 12.3 14.9 13.5 16.3 14.7 17.6 15.9 19.1 17.2 20.4 18.5 21.8 19.7 23.1 20.9 24.4 22.1 27.1 24.5 29.8 26.9 32.6 29.5 35.3 31.9 38.0 34.4 40.7 36.8 JINAN JINGHENG ELECTRONICS CO., LTD. Test Current IT (mA) 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 Reverse Stand off Voltage VWM(Volts) 5.0 5.0 6.0 6.0 6.5 6.5 7.0 7.0 7.5 7.5 8.0 8.0 8.5 8.5 9.0 9.0 10.0 10.0 11.0 11.0 12.0 12.0 13.0 13.0 14.0 14.0 15.0 15.0 16.0 16.0 17.0 17.0 18.0 18.0 20.0 20.0 22.0 22.0 24.0 24.0 26.0 26.0 28.0 28.0 30.0 30.0 13-27 Maximum Reverse Leadage At VWM ID (uA) Maximum Peak Pulse Current Ippm (Amps) 800 800 800 800 500 500 200 200 100 100 50 50 20 20 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 65 68 55 61 51 56 47 52 44 48 42 46 39 43 37 40 33 37 31 34 28 31 26 29 24.4 27.0 23.1 25.1 21.8 24.2 20.0 22.8 19.5 21.5 17.6 19.4 15.0 17.7 14.6 16.0 13.5 14.9 12.6 13.8 11.7 13.0 Maximum Clamping Voltage At Ippm VC(Volts) 9.60 9.20 11.4 10.3 12.3 11.2 13.3 12.0 14.3 12.9 15.0 13.6 15.9 14.4 16.9 15.4 18.8 17.0 20.1 18.2 22.0 19.9 23.8 21.5 25.8 23.2 26.9 24.4 28.8 26.0 30.5 27.6 32.2 29.2 35.8 32.4 39.4 35.5 43.0 38.9 46.6 42.1 50.0 45.4 53.5 48.4 HTTP://WWW.JINGHENGGROUP.COM RATINGS AND CHARACTERISTIC CURVES( SMBJ SERIES) Maximum Maximum Reverse Test Peak Pulse Reverse Stand off Current Current Leadage TYPE Voltage IT Ippm At VWM VWM(Volts) (mA) (Amps) ID (uA) MAX MIN 1.0 SMBJ33 10.6 33.0 44.9 5 36.7 1.0 SMBJ33A 11.8 33.0 40.6 5 36.7 1.0 SMBJ36 9.8 36.0 48.9 5 40.0 1.0 SMBJ36A 10.8 36.0 44.2 5 40.0 1.0 SMBJ40 8.8 40.0 54.3 5 44.4 1.0 SMBJ40A 9.7 40.0 49.1 5 44.4 1.0 SMBJ43 8.2 43.0 58.4 5 47.8 1.0 SMBJ43A 9.0 43.0 52.8 5 47.8 1.0 SMBJ45 7.8 45.0 61.1 5 50.0 1.0 SMBJ45A 8.6 45.0 55.3 5 50.0 1.0 SMBJ48 7.3 48.0 65.1 5 53.3 1.0 SMBJ48A 8.1 48.0 58.9 5 53.3 1.0 SMBJ51 6.9 51.0 69.3 5 56.7 1.0 SMBJ51A 7.6 51.0 62.7 5 56.7 1.0 SMBJ54 6.5 54.0 73.3 5 60.0 1.0 SMBJ54A 7.2 54.0 66.3 5 60.0 1.0 SMBJ58 6.1 58.0 78.7 5 64.4 1.0 SMBJ58A 6.7 58.0 71.2 5 64.4 1.0 SMBJ60 5.8 60.0 81.5 5 66.7 1.0 SMBJ60A 6.5 60.0 73.7 5 66.7 1.0 SMBJ64 5.5 64.0 86.9 5 71.1 1.0 SMBJ64A 6.1 64.0 78.6 5 71.1 1.0 SMBJ70 5.0 70.0 95.1 5 77.8 1.0 SMBJ70A 5.5 70.0 86.0 5 77.8 1.0 SMBJ75 4.7 75.0 102 5 83.3 1.0 SMBJ75A 5.2 75.0 92.1 5 83.3 1.0 SMBJ78 4.5 78.0 106 5 86.7 1.0 SMBJ78A 5.0 78.0 95.8 5 86.7 1.0 SMBJ85 4.1 85.0 115 5 94.4 1.0 SMBJ85A 4.6 85.0 104 5 94.4 1.0 SMBJ90 3.9 90.0 122 5 100 1.0 SMBJ90A 4.3 90.0 111 5 100 1.0 SMBJ100 3.5 100 136 5 111 1.0 SMBJ100A 3.8 100 123 5 111 1.0 SMBJ110 3.2 110 149 5 122 1.0 SMBJ110A 3.5 110 135 5 122 1.0 SMBJ120 2.9 120 163 5 133 1.0 SMBJ120A 3.2 120 147 5 133 1.0 SMBJ130 2.7 130 176 5 144 1.0 SMBJ130A 3.0 130 159 5 144 1.0 SMBJ150 2.3 150 204 5 167 1.0 SMBJ150A 2.5 150 185 5 167 1.0 SMBJ160 2.2 160 218 5 178 1.0 SMBJ160A 2.4 160 197 5 178 1.0 SMBJ170 2.0 170 231 5 189 1.0 SMBJ170A 2.2 170 209 5 189 Notes: 1.V(BR) measured after IT applied for 300 S, IT=square wave pulse or equivalent. Breakdown Voltage V(BR)(Volts) Maximum Clamping Voltage At Ippm VC(Volts) 59.0 53.3 64.3 58.1 71.4 64.5 76.7 69.4 80.3 72.7 85.5 77.4 91.1 82.4 96.3 87.1 103 93.6 107 96.8 114 103 125 113 134 121 139 126 151 137 160 146 179 162 196 177 214 193 231 209 268 243 287 259 304 275 2. For bidirectional types having VWM of 10 Volts and less, The ID limit is doubled. JINAN JINGHENG ELECTRONICS CO., LTD. 13-28 HTTP://WWW.JINGHENGGROUP.COM RATINGS AND CHARACTERISTIC CURVES( SMBJ SERIES) FIG.2-PULSE DERATING CURVE PEAK PULSE POWER(PPP)or CURRENT(IPPM) DERATING IN PERCENTAGE,% FIG.1-PEAK PULSE POWER CURVE PPPM,PEAK PULSE POWER,KW 100 NON-REPETITIVE PULSE WAVEFORM SHOWN In FIG.3 TA=25 C 10 1 0.1 0.1uS 1.0uS 10uS 100uS 1.0mS 10mS 100 75 50 25 0 0 25 IFSM,PEAK FORWARD SURGE CURRENT, AMPERES 150 PULSE WIDTH(td)is DEFINED as the POINT WHERE the PEAK to 50% of IPPM 100 HALF VALUE-IPPM 2 10/1000usec.WAVEFORM as DEFINED by R.E.A. td 0 1.0 2.0 3.0 125 150 175 200 200 100 TJ=TJ max 8.3ms Single Half Sine Wave 10 1 10 4.0 100 NUMBER OF CYCLES AT 60HZ t,TIME,ms FIG.5-TYPICAL JUNCTION CAPACITANCE 6,000 CJ,JUNCTION CAPACITANCE,(PF) PEAK PULSE CURRENT-% Tr=10usec. 0 100 FIG.4-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT FIG.3-PULSE WAVEFORM 50 75 TA,AMBIENT TEMPERATURE,C TP,PULSE WIDTH,sec. PEAK VALUE IPPM 50 TJ=25 C f=1.0MHZ Vsig=50mVP-P MEASURED AT ZERO BIAS 1,000 100 10 1.0 MEASURED AT STAND-OFF VOLTAGE VWM 10 20 100 200 V(BR),BREAKDOWN VOLTAGE,VOLTS JINAN JINGHENG ELECTRONICS CO., LTD. 13-29 HTTP://WWW.JINGHENGGROUP.COM
SMBJ58A 价格&库存
很抱歉,暂时无法提供与“SMBJ58A”相匹配的价格&库存,您可以联系我们找货
