SMBJ15CA
SMBJ15CA
    ME-TECH(美台高科)
    SMB(DO-214AA)
    双向TVS 15V截止 峰值浪涌电流:24.6A@10/1000US
SMBJ15CA 数据手册
SMBJ××A(CA) Transient Voltage Suppressors ROHS Features  600 watts Peak Pulse Power (10/1000 μs)  Unidirectional and Bidirectional Protection  Fast Response Time : Typically < 1ps  Excellent Clamping Capability  Glass Passivated Junction  Built-in Strain relief  Low inductance  Low profile package  High temperature solder:260℃/20 seconds at terminal SMB (JEDEC DO-214AA) Mechanical Characteristics Applications  JEDEC DO-214AA(SMBJ) package  I/O Interfaces  Molding compound flammability rating:  Power lines UL 94V-0  Automotive and Telecommunication  Marking : Marking Code  Computers &Consumer Electronics  Packaging : Tape and Reel per EIA 481  Industrial Electronics  RoHS/WEEE Compliant Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power (tp =10/1000μs) (see Note1,2& 3) PPPM 600 Watts Peak pulse current (10/1000 μs) (see Note2&3) IPPM See Electrical Characteristics A Peak Forward surge current (see Note4&5) IFSM 100 A Power Dissipation on infinite heat sink TA = 50 °C (Fig5) PD 5.0 W Operating Junction Temperature range TJ -65 to + 150 ℃ TSTG -65 to + 150 ℃ Storage Temperature range Note1: Peak Pulse Power Rating as Pulse Width ,per Fig1. Note2: Peak Pusle Power or Current Derated above TA=25℃ Per Fig. 2 and Non-Repetitive Current Pulse,Per Fig.3. 2 Note3: Mounted on 5.0x5.0mm copper pad to each terminal. Note4: 8.3ms Single Half Sine Wave or Equivalent Square Wave. Note5: Maximum Forward Surge Current only for Unidirectional Device per Fig6. Rev 2: Nov 2015 Page 1 of 5 SMBJ××A(CA) Transient Voltage Suppressors ROHS Electrical Characteristics Part Number Reverse Stand off Voltage VRWM Breakdown Voltage VBR(Volts)@IT (Volts) UNI-POLAR BI-POLAR SMBJ5.0A SMBJ5.0CA SMBJ6.0A Test IT Maximum Clamping Voltage Vc@IPP Maximum PeakPulse Current Ipp Maximum Reverse Leakage IR@VRWM (mA) (Volts) (Amps) (μA) Current MIN MAX 5.0 6.40 7.07 10 9.2 65.2 50 SMBJ6.0CA 6.0 6.67 7.37 10 10.3 58.3 50 SMBJ6.5A SMBJ6.5CA 6.5 7.22 7.98 10 11.2 53.6 50 SMBJ7.0A SMBJ7.0CA 7.0 7.78 8.60 10 12.0 50.0 50 SMBJ7.5A SMBJ7.5CA 7.5 8.33 9.21 1 12.9 46.5 50 SMBJ8.0A SMBJ8.0CA 8.0 8.89 9.83 1 13.6 44.1 20 SMBJ8.5A SMBJ8.5CA 8.5 9.44 10.40 1 14.4 41.7 10 SMBJ9.0A SMBJ9.0CA 9.0 10.00 11.10 1 15.4 39.0 5 SMBJ10A SMBJ10CA 10 11.10 12.30 1 17.0 35.3 2 SMBJ11A SMBJ11CA 11 12.20 13.50 1 18.2 33.0 1 SMBJ12A SMBJ12CA 12 13.30 14.7 1 19.9 30.2 1 SMBJ13A SMBJ13CA 13 14.40 15.90 1 21.5 27.9 1 SMBJ14A SMBJ14CA 14 15.60 17.20 1 23.2 25.9 1 SMBJ15A SMBJ15CA 15 16.70 18.50 1 24.4 24.6 1 SMBJ16A SMBJ16CA 16 17.80 19.70 1 26.0 23.1 1 SMBJ17A SMBJ17CA 17 18.90 20.90 1 27.6 21.7 1 SMBJ18A SMBJ18CA 18 20.00 22.10 1 29.2 20.5 1 SMBJ20A SMBJ20CA 20 22.20 24.50 1 32.4 18.5 1 SMBJ22A SMBJ22CA 22 24.40 26.90 1 35.5 16.9 1 SMBJ24A SMBJ24CA 24 26.70 29.50 1 38.9 15.4 1 SMBJ26A SMBJ26CA 26 28.90 31.90 1 42.1 14.3 1 SMBJ28A SMBJ28CA 28 31.10 34.40 1 45.4 13.2 1 SMBJ30A SMBJ30CA 30 33.30 36.80 1 48.4 12.4 1 SMBJ33A SMBJ33CA 33 36.70 40.60 1 53.3 11.3 1 SMBJ36A SMBJ36CA 36 40.00 44.20 1 58.1 10.3 1 SMBJ40A SMBJ40CA 40 44.40 49.10 1 64.5 9.3 1 SMBJ43A SMBJ43CA 43 47.80 52.80 1 69.4 8.6 1 Rev 2: Nov 2015 Page 2 of 5 SMBJ××A(CA) Transient Voltage Suppressors ROHS Electrical Characteristics (Cont.) Part Number UNI-POLAR BI-POLAR SMBJ45A SMBJ45CA SMBJ48A Reverse Stand off Voltage VRWM (Volts) Breakdown Voltage VBR(Volts)@IT Test IT Maximum Clamping Voltage Vc@IPP (mA) (Volts) Current Maximum PeakPuls e Current Ipp Maximum Reverse Leakage IR@VRWM (μA) MIN MAX 45 50.00 55.30 1 72.7 8.3 1 SMBJ48CA 48 53.30 58.90 1 77.4 7.8 1 SMBJ51A SMBJ51CA 51 56.70 62.70 1 82.4 7.3 1 SMBJ54A SMBJ54CA 54 60.00 66.30 1 87.1 6.9 1 SMBJ58A SMBJ58CA 58 64.40 71.20 1 93.6 6.4 1 SMBJ60A SMBJ60CA 60 66.70 73.70 1 96.8 6.2 1 SMBJ64A SMBJ64CA 64 71.10 78.60 1 103 5.8 1 SMBJ70A SMBJ70CA 70 77.80 86.00 1 113 5.3 1 SMBJ75A SMBJ75CA 75 83.30 92.10 1 121 5.0 1 SMBJ78A SMBJ78CA 78 86.70 95.80 1 126 4.8 1 SMCJ85A SMCJ85CA 85 94.40 104 1 137 4.4 1 SMBJ90A SMBJ90CA 90 100 111 1 146 4.1 1 SMBJ100A SMBJ100CA 100 111 123 1 162 3.7 1 SMBJ110A SMBJ110CA 110 122 135 1 177 3.4 1 SMBJ120A SMBJ120CA 120 133 147 1 193 3.1 1 SMBJ130A SMBJ130CA 130 144 159 1 209 2.9 1 SMBJ150A SMBJ150CA 150 167 185 1 243 2.5 1 SMBJ160A SMBJ160CA 160 178 197 1 259 2.3 1 SMBJ170A SMBJ170CA 170 189 209 1 275 2.2 1 SMBJ180A SMBJ180CA 180 201 222 1 292 2.1 1 SMBJ200A SMBJ200CA 200 224 247 1 324 1.9 1 SMBJ220A SMBJ220CA 220 246 272 1 356 1.7 1 SMBJ250A SMBJ250CA 250 279 309 1 405 1.5 1 SMBJ300A SMBJ300CA 300 335 371 1 486 1.3 1 SMBJ350A SMBJ350CA 350 391 432 1 567 1.1 1 Rev 2: Nov 2015 (Amps) Page 3 of 5 SMBJ××A(CA) Transient Voltage Suppressors ROHS Typical Characteristics Figure 1: Peak Pulse Power Rating Curve Figure 2: Pulse Derating Curve PPPM – Peak Pulse Power - KW 100 Percent of Rated Power or Ipp 110 10 600W 10/1000µs Waveform 1 100 0.1 0.1 1 10 100 1000 90 80 70 60 50 40 30 20 10 0 0 10,000 25 td – Pulse Width - µs Cj – Junction Capacitance ( pF) IppM Percent IPPM /2– Half Value 50 td – Pulse Width 10/1000µs Waveform as defined by R.E.A 0 0 1.0 150 2.0 t - Time (ms) 3.0 Bidirectional VR=0V Unidirectional VR=0V 1000 Unidirectional @VRWM 100 Bidirectional @VRWM 10 4.0 1 10 100 1000 VBR –Reverse Breakdown Voltage (V) Figure 5: Steady State Power Dissipation Derating Curve Figure 6: Maximum Non-Repetitive Forward Surge Current Only Unidirectional 180 5.5 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 0 25 50 75 100 150 160 140 120 100 80 60 40 20 0 Ambient Temperature - TA (℃) Rev 2: Nov 2015 125 Peak Forward Surge Current IFSM (A) Steady State Power Dissipation PM(AV) ( W) 125 10000 IPPM – Peak Value 100 100 Figure 4: Typical Junction Capacitance Tj =25℃ Pulse Width(td ) is defined as the point where the peak current decays to 50% of IPPM tr =10µs– Rise Time 75 Ambient Temperature - TA (℃) Figure 3: Pulse Waveform 150 50 1 10 100 Number of Cycles at 60HZ Page 4 of 5 SMBJ××A(CA) Transient Voltage Suppressors ROHS Outline Drawing – SMBJ(DO-214AA) Millimeters E1 E Ref.(mm) Min. Max. A 2.130 2.440 A1 - 0.203 B 1.950 2.200 E 4.060 4.570 E1 0.152 0.305 D 3.300 3.940 L 0.760 1.520 Rev 2: Nov 2015 B D A L A1 Page 5 of 5
SMBJ15CA 价格&库存
很抱歉,暂时无法提供与“SMBJ15CA”相匹配的价格&库存,您可以联系我们找货
