MM9Z12-HAF
MM9Z12-HAF
    TOPDYNAMIC(泰邦)
    DFN1006-2H
    肖特基二极管 5mA DFN1006-2H
MM9Z12-HAF 数据手册
MM9Z2V0~MM9Z75-HAF Silicon Planar Zener Diodes Features • Total power dissipation: max. 250 mW • Small plastic package suitable for surface mounted design • High reliability PINNING PIN 1 DESCRIPTION Cathode 2 Anode 1 2 Transparent top view Simplified outline DFN1006-2H and symbol Absolute Maximum Ratings (Ta = 25℃) Parameter Total Device Dissipaton Junction and Storage Temperature Range Symbol Value Unit Ptot 250 mW Tj , Tstg - 65 to + 150 ℃ Symbol Max. Unit VF 0.9 V Characteristics at Ta = 25℃ Parameter Forward Voltage at IF = 10 mA TOP DYNAMIC Dated:16/03/2015 Rev:02 MM9Z2V0~MM9Z75-HAF Zener Voltage Type Marking Code VZT 1) Zener Impedance Leakage Current at lZT ZZT at lZT ZZK at IZK IR Max. (µA) at VR Min. (V) Max. (V) (mA) Max. (Ω) (mA) Max. (Ω) (mA) MM9Z2V0 9H 1.8 2.15 5 100 5 - - 120 0.5 (V) MM9Z2V2 9J 2.08 2.33 5 100 5 - - 120 0.7 MM9Z2V4 9K 2.2 2.6 5 100 5 1000 1 120 1 MM9Z2V7 9L 2.5 2.9 5 100 5 1000 1 120 1 MM9Z3V0 9M 2.8 3.2 5 100 5 1000 1 50 1 MM9Z3V3 9N 3.1 3.5 5 95 5 1000 1 20 1 MM9Z3V6 9P 3.4 3.8 5 90 5 1000 1 10 1 MM9Z3V9 9Q 3.7 4.1 5 90 5 1000 1 5 1 MM9Z4V3 9R 4 4.6 5 90 5 1000 1 5 1 MM9Z4V7 9S 4.4 5 5 80 5 800 1 2 1 MM9Z5V1 9T 4.8 5.4 5 60 5 500 1 2 1.5 MM9Z5V6 9U 5.2 6 5 40 5 200 1 1 2.5 MM9Z6V2 9V 5.8 6.6 5 10 5 100 1 1 3 MM9Z6V8 9W 6.4 7.2 5 15 5 160 1 0.5 3.5 MM9Z7V5 9X 7 7.9 5 15 5 160 1 0.5 4 MM9Z8V2 9Y 7.7 8.7 5 15 5 160 1 0.5 5 MM9Z9V1 9Z 8.5 9.6 5 15 5 160 1 0.5 6 MM9Z10 0A 9.4 10.6 5 20 5 160 1 0.1 7 MM9Z11 0B 10.4 11.6 5 20 5 160 1 0.1 8 MM9Z12 0C 11.4 12.7 5 25 5 80 1 0.1 9 MM9Z13 0D 12.4 14.1 5 30 5 80 1 0.1 10 MM9Z15 0E 13.8 15.6 5 30 5 80 1 0.1 11 MM9Z16 0F 15.3 17.1 2 40 2 80 1 0.1 12 MM9Z18 0G 16.8 19.1 2 45 2 80 1 0.1 13 MM9Z20 0H 18.8 21.2 2 55 2 100 1 0.1 15 MM9Z22 0J 20.8 23.3 2 55 2 100 1 0.1 17 MM9Z24 0K 22.8 25.6 2 70 2 120 1 0.1 19 MM9Z27 0L 25.1 28.9 2 80 2 300 1 0.1 21 MM9Z30 0M 28 32 2 80 2 300 1 0.1 23 MM9Z33 0N 31 35 2 80 2 300 1 0.1 25 MM9Z36 0P 34 38 2 90 2 500 1 0.1 27 MM9Z39 0Q 37 41 2 130 2 500 1 2 30 MM9Z43 0R 40 46 1 150 1 500 1 2 33 MM9Z47 0S 44 50 1 170 1 500 1 2 36 MM9Z51 0T 48 54 1 180 1 500 1 1 39 MM9Z56 0U 52 60 1 200 1 500 1 1 43 MM9Z62 0V 58 66 1 215 1 500 1 0.2 47 MM9Z68 0W 64 72 1 240 1 500 1 0.2 52 MM9Z75 0X 70 79 1 255 1 500 1 0.2 57 1) Tested with pulses tp = 20 ms. TOP DYNAMIC Dated:16/03/2015 Rev:02 MM9Z2V0~MM9Z75-HAF Power Dissipation: Ptot (mW) 300 200 100 0 0 25 150 100 Ambient Temperature: Ta ( C) O Derating Curve TOP DYNAMIC Dated:16/03/2015 Rev:02 MM9Z2V0~MM9Z75-HAF PACKAGE OUTLINE Plastic surface mounted package DFN1006-2H UNIT A A1 b D E e L R mm 0.51 0.46 0.05 0 0.55 0.45 1.05 0.95 0.65 0.55 0.4 0.3 0.2 0.15 0.05 Recommended Soldering Footprint 0.3 0.7 0.4 0.7 Packing information Package DFN1006-2H Pitch Reel Size Tape Width (mm) mm inch mm inch 8 4 ± 0.1 0.157 ± 0.004 178 7 Per Reel Packing Quantity 5,000 TOP DYNAMIC Dated:16/03/2015 Rev:02
MM9Z12-HAF 价格&库存
很抱歉,暂时无法提供与“MM9Z12-HAF”相匹配的价格&库存,您可以联系我们找货
