EKM107M2EK25RR
EKM107M2EK25RR
    MANYUE(万裕科技)
    插件,D16xL25mm
    直插铝电解电容 插件,D16xL25mm 100µF ±20% 250V
EKM107M2EK25RR 数据手册
KM +105˚C, General (普通品) Series FEATURES Rated working voltage range 6.3 to 100V DC / 160 to 450V DC at operation temperature range -40 to +105˚C / -25 to +105˚C. This series is for communication equipments, switching power supply, industrial measuring instruments, automotive electric products, etc.   SPECIFICATIONS Item Performance Characteristics Operating Temperature Range -40 to +105˚C -25 to +105˚C Rated Working Voltage Range 6.3 to 100V 160 to 450V Nominal Capacitance Range 0.47 to 33000μF Capacitance Tolerance ±20% at 120Hz, +20˚C Leakage Current tan δ (120Hz, +20˚C) I ≤0.01CV or 3 (μA) whichever is greater measured after 2 I ≤0.03CV +40 (μA) after 2 minutes application of rated minutes application of rated working voltage at +20˚C working voltage at +20˚C Working Voltage (V) tan δ (max.) 6.3 0.26 10 0.22 16 0.18 25 0.16 35 0.14 50 0.12 63 0.10 100 0.08 Working Voltage (V) tan δ (max.) 160 0.20 200 0.20 220 0.20 250 0.20 350 0.24 400 0.24 420 0.24 450 0.24 KM For capacitance value >1000μF, add 0.02 per another 1000μF Low Temperature Characteristics Impedance ratio max. at 120Hz Working Voltage (V) 6.3 Z-25˚C / Z+20˚C 5 Z-40˚C / Z+20˚C 10 Working Voltage (V) Z-25˚C / Z+20˚C 160 3 10 4 8 16 3 6 25 2 4 35 2 3 50 2 3 63 2 3 100 2 3 200 3 220 3 250 4 350 4 400 6 420 6 450 15 For capacitance value >1000μF, add 0.5 per another 1000μF for Z-25˚C / Z+20˚C add 1.0 per another 1000μF for Z-40˚C / Z+20˚C Miniature Aluminum Electrolytic Capacitors Test time : 2,000 hours Test temperature : +105˚C Test conditions : Rated DC working voltage High Temperature Loading Post test requirements at +20˚C Leakage current : ≤Initial specified value Cap. change : within ±20% of the initial measured with rated ripple current. value tan δ : ≤200% of the initial specified value Shelf Life At +105˚C no voltage applied after 1,000 hours and then being stabilized at +20˚C the capacitors shall meet the following limits Leakage current : ≤Initial specified value Cap. change : within ±20% of the initial measured value tan δ : ≤200% of the initial specified value Industrial Standard JIS C - 5101-4 (IEC 60384-4) CASE SIZE TABLE ΦD 5 6.3 F 2.0 2.5 Φd 0.5 0.5 1 23 456 7 89 10 11 12 13 14 KM 337 M 1E F 12 RR 12.5 16 18 22 25 3.5 5.0 5.0 7.5 7.5 10.0 12.5 0.5 0.6 0.6 0.6 0.8 0.8 0.8 1.0 (L
EKM107M2EK25RR 价格&库存
很抱歉,暂时无法提供与“EKM107M2EK25RR”相匹配的价格&库存,您可以联系我们找货
