OX-B-5E3MQ-10.000M
OX-B-5E3MQ-10.000M
    TRANSKO
    DIP5
    10MHz OCXO 20.5 X 20.5 X 11mm
OX-B-5E3MQ-10.000M 数据手册
OX - B RoHS Compliant OCXO 20.5 X 20.5 X 11mm SQUARE PACKAGE FEATURES:  AT/SC cut   Low aging, Compact Package APPLICATIONS: PCS Base Station, Cellular Base Station, Synthesizer, Digital Switching Measurement Equipment ■ SPECIFICATION FREQUENCY RANGE 2 ~ 100MHz STANDARD FREQUENCIES 10MHz, 12.8MHz, 20MHz, 38.88MHz, 100MHz FREQUENCY TOLERANCE ±0.2ppm (center control voltage) Vs. OPERATING TEMPERATURE FREQ. STABILITY See Table 1 Vs. LOAD (±10%) ±10ppb Vs. SUPPLY VOLTAGE (±5%) ±20ppb SHORT TERM STABILITY -11 1X10 /s (10MHz SC cut) STORAGE TEMPERATURE RANGE -40°C ~ +100°C SUPPLY VOLTAGE +3.3VDC, +5.0VDC, +12.0VDC SUPPLY CURRENT 3.6W max. during warm-up, 1.2W max. when static WARM-UP TIME AT Cut ±0.2ppm, 3minutes max. SC Cut ±0.1ppm, 3minutes max. LOGIC FAMILY OUTPUT Sine Wave HCMOS/LVCMOS LOAD 50Ω 15pF typ., 50pF max. available LEVEL 5dBm min. “1” level: 90%VDD min.; “0” level: 10%VDD max. HARMONIC -30dBm max. - NOISE SUPPRESSION -75dBm max. - SYMMETRY (DUTY CYCLE) - 45/55% RISE/FALL TIME - 6ns max.(fn40MHz) FREQUENCY DEVIATION CONTROL VOLTAGE AT Cut ±3.0ppm SC Cut ±0.7ppm 3.3V 0~3.3V 5.0V , 12V 0~5.0V SLOPE Positive LINEARITY ±10% DAY AGING YEAR 10 YEAR PHASE NOISE AT Cut ±2ppb SC Cut ±1ppb AT Cut ±300ppb SC Cut ±100ppb AT Cut ±2.0ppm SC Cut ±0.5ppm 10Hz -120dBc/Hz 100Hz -140dBc/Hz 1kHz -145dBc/Hz 10kHz -150dBc/Hz Transko Electronics, Inc reserves the right to make changes to the product (s), service (s), and specification (s) described herein without notice. See “Terms of Sale” for details on our website. Transko Electronics, Inc. 3981 E. Miraloma Ave. Anaheim, CA 92806 USA Tel: 714-528-8000 Fax: 714-528-8017 Website: www.transko.com E-mail: sales@transko.com Rev. 2: Mar. 2015 OX - B ■ TABLE 1 RoHS RoHS Compliant Compliant FREQUENCY STABILITY VS TEMPERATURE Frequency Stability vs Temperature Temperature Range AT CUT SC CUT ±50ppb ±5ppb 0°C ~ +50°C ±100ppb ±10ppb -20°C ~ +70°C ±100ppb ±30ppb -40°C ~ +75°C ■ PACKAGE DIMENSIONS 20.5 20.5 0.5 11max. 4.5 Ø0.45 15.24 Pin Configuration 2 3 7.62 20.5 1 5 4 1 VDC 2 Output 3 GND 4 VC 5 Ref. V or N/C Unit:mm ■ TEST CIRCUIT ■ PART NUMBERING GUIDE Voltage Control Sine Wave Oscillator 1 5 V 2 A +VCC OX-B 5 E5 J R 10.000M 3 4 Frequency Voltage RS=50R 0.1µF Oscilloscope Frequency in MHz 3: +3.3 V 5: +5.0 V 12: +12.0 V Output Frequency counter Q: Sine Wave R: CMOS Stability Voltage Control CMOS Oscillator 1 5 V 2 0.1µF A +VCC 3 4 15pF* Oscilloscope F1: ±0.001ppm F5: ±0.005ppm E1: ± 0.01ppm E5: ± 0.05ppm 01: ± 0.1ppm 03: ± 0.3ppm 05: ± 0.5ppm Other options available Operating Temperature H: 0°C to 50°C I: -10°C to 60°C J: -10°C to 70°C K: -20°C to 70°C L: -30°C to 70°C M: -40°C to 75°C Other options available Frequency counter * inclusive of jig and equipment capacitance Transko Electronics, Inc reserves the right to make changes to the product (s), service (s), and specification (s) described herein without notice. See “Terms of Sale” for details on our website. Transko Electronics, Inc. 3981 E. Miraloma Ave. Anaheim, CA 92806 USA Tel: 714-528-8000 Fax: 714-528-8017 Website: www.transko.com E-mail: sales@transko.com Rev. 2: Mar. 2015
OX-B-5E3MQ-10.000M 价格&库存
很抱歉,暂时无法提供与“OX-B-5E3MQ-10.000M”相匹配的价格&库存,您可以联系我们找货
OX-B-5E3MQ-10.000M
    • 1+3112.40880
    • 200+1241.87040
    • 500+1200.37680
    • 1000+1179.86760
