BSCL0020120968NM00
BSCL0020120968NM00
    CHILISIN(奇力新)
    INDUCTOR RF
BSCL0020120968NM00 数据手册
SMD Multilayer Ferrite Chip Inductors - BSCL Series BSCL Series The SMD multi-layered ferrite chip inductors provide a cost-effective solution for densely packed PC board designs. BSCL series comes in 4 sizes and is suitable for low frequency applications. Features Applications  RoHS compliant  Personal computers, HDDs, other various electronic devices  Any portable device where compact size and high mounting  High mounting density of compact circuit due to crosstalk elimination that results from a closed magnetic flux in a ferrite material  Suitable for flow and re-flow soldering  Available in 4 sizes densities are required Product Identification Shape and Dimensions Recommended Pattern Ferrite Terminal Electrode D D C A B Dimensions in mm Dimensions in mm TYPE A B C D TYPE A B C BSCL00160808 1.60.20 0.800.20 0.800.20 0.30.20 BSCL00160808 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 BSCL00201209 2.00.20 1.250.20 0.900.20 0.50.30 BSCL00201209 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.4 BSCL00201212 2.00.20 1.250.20 1.250.20 0.50.30 BSCL00201212 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.2 BSCL00321611 3.20.20 1.600.20 1.100.20 0.50.30 BSCL00321611 2.0 ~ 2.4 4.2 ~ 5.2 1.3 ~ 1.9 SMD Multilayer Ferrite Chip Inductors – BSCL Series Electrical Characteristics Test Inductance Tolerance Q Part Number SRF RDC IDC (MHz) Min (Ω) Max (mA) Max Frequency (H) (±%) Min (MHz) BSCL0016080810N00 0.010 20 15 50 300 0.2 50 BSCL0016080833N00 0.033 20 15 50 270 0.2 50 BSCL0016080847N00 0.047 20 15 50 260 0.3 50 BSCL0016080856N00 0.056 20 15 50 255 0.3 50 BSCL0016080868N00 0.068 20 15 50 250 0.3 50 BSCL0016080882N00 0.082 20 15 50 245 0.3 50 BSCL00160808R1000 0.10 20 / 15 / 10 25 25 240 0.5 50 BSCL00160808R1200 0.12 20 / 15 / 10 25 25 205 0.5 50 BSCL00160808R1500 0.15 20 / 15 / 10 25 25 180 0.6 50 BSCL00160808R1800 0.18 20 / 15 / 10 25 25 165 0.6 50 BSCL00160808R2200 0.22 20 / 15 / 10 25 25 150 0.8 50 BSCL00160808R2700 0.27 20 / 15 / 10 25 25 136 0.8 50 BSCL00160808R3300 0.33 20 / 15 / 10 25 25 125 0.85 35 BSCL00160808R3900 0.39 20 / 15 / 10 25 25 110 1.00 35 BSCL00160808R4700 0.47 20 / 15 / 10 25 25 105 1.35 35 BSCL00160808R5600 0.56 20 / 15 / 10 25 25 95 1.50 35 BSCL00160808R6800 0.68 20 / 15 / 10 25 25 85 1.70 35 BSCL00160808R8200 0.82 20 / 15 / 10 25 25 75 2.10 35 BSCL001608081R000 1.0 20 / 15 / 10 35 10 65 0.60 25 BSCL001608081R200 1.2 20 / 15 / 10 35 10 60 0.80 25 BSCL001608081R500 1.5 20 / 15 / 10 35 10 55 0.80 25 BSCL001608081R800 1.8 20 / 15 / 10 35 10 50 0.95 25 BSCL001608082R200 2.2 20 / 15 / 10 35 10 45 1.00 15 BSCL001608082R700 2.7 20 / 15 / 10 35 10 40 1.15 15 BSCL001608083R300 3.3 20 / 15 / 10 35 10 38 1.30 15 BSCL001608083R900 3.9 20 / 15 / 10 35 10 36 1.50 15 BSCL001608084R700 4.7 20 / 15 / 10 35 10 33 1.60 15 BSCL001608085R600 5.6 20 / 15 / 10 35 4 22 1.10 5 BSCL001608086R800 6.8 20 / 15 / 10 35 4 20 1.30 5 BSCL001608088R200 8.2 20 / 15 / 10 30 4 18 1.50 5 BSCL0016080810000 10 20 / 15 / 10 30 2 17 1.70 5 BSCL0016080812000 12 20 / 15 / 10 30 2 15 1.80 3 BSCL0016080815000 15 20 / 15 / 10 20 1 14 1.50 1 BSCL0016080822000 22 20 / 15 / 10 20 1 11 1.70 1 Note: When ordering, please specify tolerance code. Tolerance : K=±10% , L=±15% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  IDC:Applied the current to coils, the inductance shall be less than 10% initial value  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – BSCL Series Electrical Characteristics Inductance Tolerance Q Test Frequency SRF RDC IDC (H) (±%) Min (MHz) MHz) Min (Ω) Max (mA) Max BSCL0020120922N00 0.022 20 20 50 320 0.20 300 BSCL0020120933N00 0.033 20 / 15 20 50 320 0.20 300 BSCL0020120947N00 0.047 20 / 15 20 50 320 0.20 300 BSCL0020120956N00 0.056 20 / 15 20 50 320 0.20 300 BSCL0020120968N00 0.068 20 / 15 20 50 280 0.20 300 BSCL0020120982N00 0.082 20 / 15 20 50 255 0.20 300 BSCL00201209R1000 0.10 20 / 15 / 10 25 25 235 0.30 250 BSCL00201209R1200 0.12 20 / 15 / 10 25 25 220 0.30 250 BSCL00201209R1500 0.15 20 / 15 / 10 25 25 200 0.40 250 BSCL00201209R1800 0.18 20 / 15 / 10 25 25 185 0.40 250 BSCL00201209R2200 0.22 20 / 15 / 10 25 25 170 0.50 250 BSCL00201209R2700 0.27 20 / 15 / 10 25 25 150 0.50 250 BSCL00201209R3300 0.33 20 / 15 / 10 25 25 145 0.55 250 BSCL00201209R3900 0.39 20 / 15 / 10 25 25 135 0.65 250 BSCL00201209R4700 0.47 20 / 15 / 10 25 25 125 0.65 250 BSCL00201209R5600 0.56 20 / 15 / 10 25 25 115 0.75 150 BSCL00201209R6800 0.68 20 / 15 / 10 25 25 105 0.80 150 BSCL00201209R8200 0.82 20 / 15 / 10 25 25 100 1.00 150 BSCL002012091R000 1.0 20 / 15 / 10 45 10 75 0.40 50 BSCL002012091R200 1.2 20 / 15 / 10 45 10 65 0.50 50 BSCL002012091R500 1.5 20 / 15 / 10 45 10 60 0.50 50 BSCL002012091R800 1.8 20 / 15 / 10 45 10 55 0.60 50 BSCL002012092R200 2.2 20 / 15 / 10 45 10 50 0.65 30 Part Number Note: When ordering, please specify tolerance code. Tolerance : K=±10% , L=±15% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  IDC:Applied the current to coils, the inductance shall be less than 10% initial value  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – BSCL Series Electrical Characteristics Inductance Tolerance Q Test Frequency SRF RDC IDC (H) (±%) Min (MHz) (MHz) Min (Ω) Max (mA) Max BSCL002012122R700 2.7 20 / 15 / 10 45 10 45 0.75 30 BSCL002012123R300 3.3 20 / 15 / 10 45 10 41 0.80 30 BSCL002012123R900 3.9 20 / 15 / 10 45 10 38 0.90 30 BSCL002012124R700 4.7 20 / 15 / 10 45 10 35 1.00 30 BSCL002012125R600 5.6 20 / 15 / 10 45 4 32 0.90 15 BSCL002012126R800 6.8 20 / 15 / 10 45 4 29 1.00 15 BSCL002012128R200 8.2 20 / 15 / 10 45 4 26 1.10 15 BSCL0020121210000 10 20 / 15 / 10 45 2 24 1.10 15 BSCL0020121212000 12 20 / 15 / 10 45 2 22 1.20 15 BSCL0020121215000 15 20 / 15 / 10 30 1 19 0.80 5 BSCL0020121218000 18 20 / 15 / 10 30 1 18 0.90 5 BSCL0020121222000 22 20 / 15 / 10 30 1 16 1.1 5 Part Number Note: When ordering, please specify tolerance code. Tolerance : K=±10% , L=±15% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  IDC:Applied the current to coils, the inductance shall be less than 10% initial value  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – BSCL Series Electrical Characteristics Inductance Tolerance Q (H) (±%) Min BSCL0032161147N00 0.047 20 20 BSCL0032161156N00 0.056 20 BSCL0032161168N00 0.068 BSCL0032161182N00 Test SRF RDC IDC (MHz) Min (Ω) Max (mA) Max 50 320 0.15 300 20 50 280 0.25 300 20 20 50 280 0.25 300 0.082 20 20 50 250 0.25 300 BSCL00321611R1000 0.10 20 / 15 / 10 25 25 235 0.25 250 BSCL00321611R1200 0.12 20 / 15 / 10 25 25 220 0.30 250 BSCL00321611R1500 0.15 20 / 15 / 10 25 25 200 0.30 250 BSCL00321611R1800 0.18 20 / 15 / 10 25 25 185 0.40 250 BSCL00321611R2200 0.22 20 / 15 / 10 25 25 170 0.40 250 BSCL00321611R2700 0.27 20 / 15 / 10 25 25 150 0.50 250 BSCL00321611R3300 0.33 20 / 15 / 10 25 25 145 0.60 250 BSCL00321611R3900 0.39 20 / 15 / 10 25 25 135 0.50 200 BSCL00321611R4700 0.47 20 / 15 / 10 25 25 125 0.60 200 BSCL00321611R5600 0.56 20 / 15 / 10 25 25 115 0.70 150 BSCL00321611R6800 0.68 20 / 15 / 10 25 25 105 0.80 150 BSCL00321611R8200 0.82 20 / 15 / 10 25 25 100 0.90 150 BSCL003216111R000 1.0 20 / 15 / 10 45 10 75 0.40 100 BSCL003216111R200 1.2 20 / 15 / 10 45 10 65 0.50 100 BSCL003216111R500 1.5 20 / 15 / 10 45 10 60 0.50 80 BSCL003216111R800 1.8 20 / 15 / 10 45 10 55 0.50 70 BSCL003216112R200 2.2 20 / 15 / 10 45 10 50 0.60 60 BSCL003216112R700 2.7 20 / 15 / 10 45 10 45 0.60 60 BSCL003216113R300 3.3 20 / 15 / 10 45 10 41 0.70 60 BSCL003216113R900 3.9 20 / 15 / 10 45 10 38 0.80 50 BSCL003216114R700 4.7 20 / 15 / 10 45 10 35 0.90 50 BSCL003216115R600 5.6 20 / 15 / 10 45 4 32 0.70 25 BSCL003216116R800 6.8 20 / 15 / 10 45 4 29 0.80 25 BSCL003216118R200 8.2 20 / 15 / 10 45 4 26 0.90 25 BSCL0032161110000 10 20 / 15 / 10 45 2 24 1.00 25 BSCL0032161112000 12 20 / 15 / 10 45 2 22 1.00 15 BSCL0032161115000 15 20 / 15 / 10 35 1 19 0.70 5 BSCL0032161118000 18 20 / 15 / 10 35 1 18 0.75 5 BSCL0032161122000 22 20 / 15 / 10 35 1 16 0.90 5 BSCL0032161127000 27 20 / 15 / 10 35 1 14 0.90 5 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : K=±10% , L=±15% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  IDC:Applied the current to coils, the inductance shall be less than 10% initial value  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – BSCL Series Test Instruments:Agilent E4991A Impedance / Material Analyzer BSCL00160808 Q v s. FREQUENCY CHARACTERISTICS INDUCTANCE v s. FREQUENCY CHARACTERISTICS 80 100 6.8uH 70 1.8uH 10 60 6.8uH 0.12uH Q L( uH) 50 1.8uH 1 40 30 0.12uH 20 0.1 10 0 0.01 1 10 100 1 1000 10 100 FREQUENCY(MHz) FREQUENCY(MHz) BSCL00201209 Q v s. FREQUENCY CHARACTERISTICS INDUCTANCE v s. FREQUENCY CHARACTERISTICS 90 100 2.2uH 5.6uH 80 5.6uH 70 10 0.47uH 60 0.47uH 50 Q L( uH) 2.2uH 1 40 30 0.1 20 10 0.01 0 1 10 100 1000 1 10 FREQUENCY(MHz) 100 FREQUENCY(MHz) BSCL00321611 Q v s. FREQUENCY CHARACTERISTICS INDUCTANCE v s. FREQUENCY CHARACTERISTICS 100 100 10uH 2.7uH 90 0.47uH 80 10uH 70 10 L( uH) 60 Q 2.7uH 50 40 0.47uH 1 30 20 10 0 0.1 1 10 100 1000 1 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 10 FREQUENCY(MHz) 100 SMD Multilayer Ferrite Chip Inductors - BSCL Series Packaging Specifications Tape Dimensions Tape Material Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A B T W P F K Tape A B C D PCS / Reel BSCL00160808 1.05 1.85 0.95 8.0 4.0 3.5 - B 178 60 12 1.5 4000 BSCL00201209 1.50 2.30 0.97 8.0 4.0 3.5 - B 178 60 12 1.5 4000 BSCL00201212 1.35 2.25 0.22 8.0 4.0 3.5 1.35 A 178 60 12 1.5 3000 BSCL00321611 1.88 3.50 0.22 8.0 4.0 3.5 1.27 A 178 60 12 1.5 3000
BSCL0020120968NM00
物料型号:BSCL系列
器件简介:BSCL系列是SMD多層鐵氧體芯片電感器,提供經濟高效的解決方案,適用於密集的PCB板設計,適合低頻應用。
引脚分配:文档中未提供具体的引脚分配信息,但提到了适用于回流焊和波峰焊。
参数特性: - 符合RoHS标准 - 高安装密度,由於鐵氧體材料中的閉合磁通量消除了串訊 - 可用於4種尺寸 - 操作溫度範围-40℃~125℃(包括自體溫度上升)
功能详解:适用于个人电脑、硬盘驱动器、其他各种电子设备以及任何需要紧凑尺寸和高安装密度的便携设备。
应用信息:适用于需要紧凑尺寸和高安装密度的电子设备,如个人电脑、硬盘驱动器等。
封装信息:提供了详细的产品识别信息,包括内部代码、容差、电感、尺寸控制代码、产品系列等级、形状和尺寸、鐵氧體、端部、電極等。
电气特性:提供了详细的电感值、容差、Q值最小值、测试频率、自谐振频率、直流电阻和直流电流等参数。
测试设备:包括L&Q测试的HP4291A、自谐振频率测试的Agilent HP8753D/Agilent E4991A、直流电阻测试的HP4338B或CHEN HWA 502。
BSCL0020120968NM00 价格&库存
很抱歉,暂时无法提供与“BSCL0020120968NM00”相匹配的价格&库存,您可以联系我们找货
