SCCB0630-4R7M
SCCB0630-4R7M
    SCIENTIC(三体微)
    SMD,7.5x6.8mm
    功率电感 4.7μH ±20% 6.5A 28.5mΩ SMD,7.5x6.8mm
SCCB0630-4R7M 数据手册
Specification for Approval Customer : Customer P/N : Item Name : Description : Molded Power Inductor Scientic P/N : SCCB0630-4R7M Spec No. : SE110102-4R7M Version No. : 1.0 MSL Level 1 Operation temperature Package Weight MPQ 1500pcs/reel –40°C to +125°C including self-temperature rise. 13″ reel; Plastic tape: 16 mm wide,P=12mm. 0.75g/pcs typ. Manufacturer Approved by Customer Prepared Xiaoyan.Lu Prepared Checked Tao.Yang Checked Approved Xiangming.He Approved Date Mar.23, 2024 Date Remark: 1. Before use, customer should confirm whether this product is suitable for their design, Scientic only ensure products meet this specification. 2. This specification data change must be confirmed by both parties, any individual modification is invalid. 3. If customer placed orders without signing back this specification, it is regarded as recognition. Dongguan Scientic Electronics Technology Co.,Ltd Address:No. 1, Longshui Rd, Youganpu, Fenggang Town, Dongguan city, Guangdong Province, China Tel: 0769-89608765 Fax : 0769-89608765 Specification Revision History Revision Changed Date Request By V1.0 Mar.23, 2024 Xiaoyan.Lu Dongguan Scientic EIectronics Technology Co.,Ltd Tel: 0769-89608765 Fax : 0769-89608765 Change Content Initial Issue 1 Specification Caution of Application The products listed in this specification are designed and manufactured for general electronics equipment. That any misuse of the products deviating from products specifications or information will probably cause serious damage to person or/and property. We are not responsible for any damage or liability caused by use of the products in any of the applications below. 1. Transportation equipment (vehicles, trains, ships,etc.) 2. Military equipment 3. Aerospace/Aviation equipment 4. Undersea equipment 5. Atomic energy-related equipment 6. Power plant equipment 7. Traffic signal equipment 8. Medical equipment 9. Data-processing equipment 10. Safety equipment 11. Disaster prevention / crime prevention equipment 12. Other similar complexity or with reliability requirements applications comparable to the applications listed in the above. Dongguan Scientic EIectronics Technology Co.,Ltd Tel: 0769-89608765 Fax : 0769-89608765 2 Specification 1 Part No. definition SCCB 0630 - 4R7 M ① ② ③ ④ ⑤ Product Code 1 2 Product Family Series 2 Dimension ② 7.2×6.6×3.0mm 3 Process code ③ “-”:Standard Type 4 Inductance ④ 4R7= 4.7 uH 5 Tolerance M = ±20% Dimensions (mm)& recommend layout C A E G 4R7 B 3 D F H A B C D E F G H 7.50max 6.80max 3.00Max 3.00±0.30 1.60±0.30 3.50Ref 3.70Ref 8.40Ref Material list Core: Metal composite core Coil: Enamelled copper wire Electrode: Cu+Ni+Sn Dongguan Scientic EIectronics Technology Co.,Ltd Tel: 0769-89608765 Fax : 0769-89608765 3 Specification 4 Electrical characteristic test instrument 4.1 test ambient conditions Unless otherwise specified, the standard conditions for measurement/test as: ※Ambient Temperature : 5 to 35℃;Relative Humidity: 25 to 85% RH;Atmospheric Pressure: 86 to 106 kPa. ※If any doubt on the results, measurements/tests should be made within the following limits. ※Ambient Temperature : 25±1℃;Relative Humidity: 60 to 70% RH;Atmospheric Pressure: 86 to 106 kPa. 4.2 test method Test item Equipment Inductance LCR meter WK6500 or equivalent DCR LCR Meter HIOKI 3542 or equivalent Isat Irms Frequency Performance Diagrammatic Sketch LCR meter WK6500 + DC BIAS or equivalent DC power supply Agilent E3633A + thermometer or equivalent LCR meter WK6500 or equivalent Dongguan Scientic EIectronics Technology Co.,Ltd Tel: 0769-89608765 Fax : 0769-89608765 4 Specification 5 Electrical characteristics Part No. SCCB0630-4R7M ※ Inductance ( μH ) ※1 DC Resistance ( mΩ ) Saturation Current ( A ) ※2 Heat Rating Current ( A ) ※3 Withstanding Voltage(V)※4 ±20% Max Typ Max Typ Max Typ Max 4.7 32.0 28.5 7.00 9.00 5.50 6.50 100 All data is tested on 25℃ ambient temperature. ※1 Inductance is tested at 1MHz, 1.0V. ※2 Saturation current: The value of DC current when the inductance decreases approximate 30% of its initial value. ※3 Heat rating current: The value of DC current when product temperature rise is ΔT≤40℃ (Ta=25℃) ※4 Withstanding voltage: 1mA/3S. ※ Temp rise & Saturation:The typical value is the measured value, and the maximum value is the recommended current. 6 Temp rise & Saturation vs. current characteristics Dongguan Scientic EIectronics Technology Co.,Ltd Tel: 0769-89608765 Fax : 0769-89608765 5 Specification Packaging specification Carrier tape dimensions(mm) B0 6.80±0.10 K0 3.20 ±0.10 P0 4.00±0.10 P2 2.00±0.10 W 16.0±0.30 P 12.0±0.10 D 1.50±0.10 E 1.75±0.10 F 7.50±0.10 T 0.40±0.05 7.2 D T A0 ※ Packaging is referred to the international standard EIA-481-D. Packaging direction S procket hole Feeding direction N o com ponent 160m m M in. A P P2 K0 E nd 7.3 P0 B0 6.80 ±0.10 W A0 E 7.1 F 7 C om ponent S tart C arrier tape C over tape N o com ponent 100m m M in. C over tape 400m m M in. Reel dimensions(mm) 330 ± 2.0 D C B 100 Min C 16.5 +2.0/-0 D 22.0Max E 18.0 Min Dongguan Scientic EIectronics Technology Co.,Ltd Tel: 0769-89608765 Fax : 0769-89608765 13.0±0.5 31.0±0.8 2.0±0.5 A B E 6 Specification 7.4 Cover tape peel-off condition Cover tape 165°~180° Unreeling direction Label Pull direction C over tape Sprocket hole Carrier tape U nreeling direction 7.5 ※ Cover tape peel-off force will be 0.2 to 1.3N. ※ Reference peel-off speed 300±10mm/min. Carton dimensions and packaging quantity Reel Inner carton Out carton Label ■ Inner Carton (L*W*H):340*340*95mm SCCB0630 ■ Out Carton (L*W*H):355*355*216mm Per Reel Quantity Inner Carton Quantity Out Carton Quantity 1500 pcs (1500*4) =6000 pcs (6000*2) = 12000pcs Dongguan Scientic EIectronics Technology Co.,Ltd Tel: 0769-89608765 Fax : 0769-89608765 7 Specification 8 Reflow soldering specification 8.1 Reflow profile for SMT components Max time at max 217℃ Tp temp 10S max 255℃ 260℃ max Max Ramp Up Rate=3℃/sec. Max Ramp Down Rate=6℃/sec. 60~90sec. 200℃ 150℃ 60~120sec. 25℃ Time 25℃ to Peak =8 min max 8.2 Classification of peak package body temperature (TP) Package Volume Package Thickness PB-Free Assembly ※ 2000 mm3
SCCB0630-4R7M 价格&库存
很抱歉,暂时无法提供与“SCCB0630-4R7M”相匹配的价格&库存,您可以联系我们找货
