CA4-16.000-18-3050-R 数据手册
RoHS Compliant
Pb - Lead Free
Ltr
Date
Revisions
Appr
Electrical Specifications:
Frequency Range
Fundamental
Third Overtone
Standard
Mode of Oscillation
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Optional
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
3.200 to 70.000
3.200 to 32.768
24.576 to 70.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15
±10
-20 to +70
-40 to +85
-55 to +125
±5 first year
±3 thereafter
10 to 32 and Series Resonance
7.0
See ESR Table
1.0
500 at at 100 Vdc ± 15 Vdc
MHz
MHZ
PPM Max
PPM Max
ºC
PPM Max/Year
Frequency Range vs. ESR Values:
Frequency Range in MHz
3.200 to 3.500
3.510 to 3.999
4.000 to 5.999
6.000 to 7.999
8.000 to 9.999
10.000 to 15.999
16.000 to 32.768
24.576 to 70.000
ESR Ohms Max
300
200
120
80
60
50
40
80
Mode of Operation
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental-Third Overtone
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: July 27, 2006
Quartz Crystal
Surface Mount
HC-49/U-S SMD 4 Pad Package
General Product Specification
Part Number:
CA4 Series
www.aker-usa.com
pF
pF Max
Ohms
mW Max
M Ohm
Mechanical Outline:
Dimensions are millimeters.
PCB Solder Pad Layout:
Pad Connection:
Top View
Page:
2/4
Date: July 27, 2006
P/N:
CA4 Series
www.aker-usa.com
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: July 27, 2006
P/N:
www.aker-usa.com
CA4 Series
How to build a Part Number:
Series
Package
Frequency
3.200 to 70.000
Load Capacitance
Standard
Frequency Tolerance
Option
Standard
Frequency Stability
C
A4
Option
10
12
16
18
S
MHz
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
30
25
10
50
30
25
10
Mode of Oscillation
See Notes
3
Standard
Option
See Notes
X
Standard
Package Height
Option
See Notes
4
Packaging
See Notes
R
Temperature Range
Parameter
HC-49/U-S SMD 4 Pad
±30 PPM
±25 PPM
±20 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±20 PPM
±15 PPM
±10 PPM
Fundamental
Third Overtone
-20 to +70 ºC
-40 to +85 ºC
5.2 mm Max
4.0 mm Max
Bulk
Tape and Reel
Part Number Example:
CA4-24.000-18-3050-R
CA4: HC-49/U-S SMD 4 Pad Package
24.000 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Tolerance and ±50 PPM Stability
Fundamental Mode
-20 to +70°C Temperature Range
R: Tape and Reel Packaging
Notes:
1- Standard Temperature Range, Standard Height (5.2 mm), and Fundamental Mode do not
need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces.
4- Quantities less than 1000 are shipped bulk. 100 pieces in ESD bags.
5- Specification subject to change without notice.
Page:
4/4
Date: July 27, 2006
P/N:
www.aker-usa.com
CA4 Series
CA4-16.000-18-3050-R 价格&库存
很抱歉,暂时无法提供与“CA4-16.000-18-3050-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.475321+1.09651
- 10+7.3353110+0.94902
- 25+6.9416525+0.89809
- 50+6.6540950+0.86089
- 100+6.37773100+0.82513
- 250+6.03152250+0.78034
- 500+5.78205500+0.74807
- 国内价格 香港价格
- 1000+5.542921000+0.71713
- 2000+5.313862000+0.68749
- 3000+5.184333000+0.67074
- 5000+5.025695000+0.65021
- 7000+4.923887000+0.63704
- 10000+4.8183010000+0.62338
