CAA-40.000-18-3050-R
    AKER(安碁科技)
    HC49S
    40 MHz ±30ppm 晶体 18pF HC-49/US
CAA-40.000-18-3050-R 数据手册
Specification Title: Quartz Crystal Surface Mount HC-49/U-S SMD Short Package General Product Specification No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan, ROC All dimensions are millimeters. CAD: Review: Appr: Page: TCR EG JL 1/4 Series Name: CAA Series Date: August 01, 2022 Electrical Specifications: Frequency Range 3.500 to 80.000 Mode of Oscillation Fundamental 3.500 to 40.000 Third Overtone 24.000 to 80.000 Standard MHz MHz ±30 ±25 Frequency Tolerance at 25°C ±20 Optional PPM Max ±15 ±10 Standard ±30 ±100 ±50 Frequency Stability over Temperature Range ±25 Optional PPM Max ±20 ±15 ±10 Operating Temperature Range Standard -20 to +70 Extended ℃ -40 to +85 Storage Temperature Range -55 to +125 Aging ±5 PPM Max/Year Load Capacitance 6 to 47 and Series Resonance pF Shunt Capacitance 7.0 pF Max Equivalent Series Resistance(ESR) Drive Level See ESR Table Ohms 100, 500, 1000 or special requirement mW Max 500 at 100 Vdc ± 15 Vdc M Ohm Insulation Resistance Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation Frequency Range in MHz ESR Ohm Max Mode of Operation 3.500 to 3.999 200 Fundamental 24.000 to 29.999 120 Third Overtone 4.000 to 4.999 120 Fundamental 30.000 to 39.999 80 Third Overtone 5.000 to 5.999 90 Fundamental 40.000 to 80.999 60 Third Overtone 6.000 to 7.999 80 Fundamental 8.000 to 11.999 12.000 to 14.999 60 40 Fundamental Fundamental 15.000 to 19.999 35 Fundamental 20.000 to 40.000 25 Fundamental Ltr Revisions RoHS Compliant Pb - Lead Free www.aker-usa.com Date Appr Mechanical Outline: SUGGESTED LAND PATTERN : 5.5 2.0 5.5 9.5 Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: August 01, 2022 P/N: www.aker-usa.com CAA Series 2.00 1.50 1.75 Carrier Tape Dimensions: 4.00 A B-B SECTION Bo:15.0 24.0 11.50 B A B 1.50 12.00 Ko:5.0 Ao:5.00 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: August 01, 2022 P/N: www.aker-usa.com CAA Series How to build a Part Number: Series Package C AA Parameter HC-49/U-S SMD - Frequency 3.500 to 80.000 MHz - Load Capacitance 10 12 16 18 20 32 S 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series - Standard Frequency Tolerance Option Standard Frequency Stability Option 30 25 20 15 10 30 100 50 25 20 15 10 ±30PPM ±25PPM ±20PPM ±15PPM ±10PPM ±30PPM ±100PPM ±50PPM ±25PPM ±20PPM ±15PPM ±10PPM* - Mode of Oscillation See Notes 3 Standard Temperature Range Option See Notes X Standard Option See Notes 32 Packaging See Notes R Fundamental Third Overtone -20 to +70 ℃ -40 to +85 ℃ - Package Height 4.3 3.2 Bulk Tape and Reel Part Number Example: CAA-24.000-18-3050-R CAA: HC-49/U-S SMD Package 24.000 MHz Nominal Frequency 18pF Load Capacitance 3050: ±30 PPM Tolerance and ±50 PPM Stability Fundamental Mode -20 to +70°C Temperature Range Standard Height - 4.3 mm R: Tape and Reel Packaging Notes: 1- Standard Temperature Range, Package Height (4.3mm), and Fundamental Mode do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Quantities less than 1000 are shipped bulk. 100 pieces in ESD bags. 4- Specification subject to change without notice. Page: 4/4 Date: August 01, 2022 P/N: www.aker-usa.com CAA Series
CAA-40.000-18-3050-R 价格&库存
很抱歉,暂时无法提供与“CAA-40.000-18-3050-R”相匹配的价格&库存,您可以联系我们找货
  • 1+2.835351+0.36701
  • 10+2.4416110+0.31604
  • 25+2.3110825+0.29915
  • 50+2.2173550+0.28702
  • 100+2.12534100+0.27511
  • 250+2.00961250+0.26013
  • 500+1.92641500+0.24936
库存:1995
  • 1000+1.842351000+0.23848
  • 2000+1.766132000+0.22861
  • 3000+1.723003000+0.22303
  • 5000+1.670205000+0.21619
  • 7000+1.636297000+0.21180
  • 10000+1.6011210000+0.20725
库存:1995
