Thyristor Surge Suppressor (TSS) – S Series
Description
DO-214AA PXXXX S series solid state protection thyristor protect
telecommunication equipments such as modem, line cards, fax
machines and other CPE. PXXXX S series devices are used to enable
equipment to meet various regulatory requirements including GR
1089, ITU K.20, K.21 and K.45, IEC 60950, UL 60950 and TIA-968
(formerly known as FCC Part 68)
Electrical Parameters
Compared to surge suppression using other technologies, PXXXX S
series devices offer absolute surge protection regardless of the
surge current available and the rate of applied voltage (dv/dt).
P series devices:
⚫ Cannot be damaged by voltage
⚫ Eliminate hysteresis and heat dissipation typically found with
clamping devices.
⚫ Eliminate voltage overshoot caused by fast-rising transients
⚫ Are non-degenerative.
⚫ Will not fatigue
⚫ Have low capacitance, making them ideal for high-speed
transmission equipment.
Thermal Considerations
TJ – Operating Junction Temperature Range: -40~150°C
TS – Storage Temperature Range: -40~150°C
RƟJA – Thermal Resistance: Junction to Ambient: 90°C/W
Part Number Code
P
□□□□ S □
IPP Rating (A: 45A; B: 80A; C: 100A)
S: DO-214AA/SMB Package
Typical Breakdown Voltage
TSS Product Symbol
I-V Curve Characteristics
CO Off-state Capacitance — typical capacitance measured in off state.
IS Switching Current — maximum current required to switch to on state
IDRM Leakage Current — maximum peak off-state current measured at VDRM
IH Holding Current — minimum current required to maintain on state
IPP Peak Pulse Current — maximum rated peak impulse current
IT On-state Current — maximum rated continuous on-state current
ITSM Peak One-cycle Surge Current — maximum rated one-cycle AC current
VS Switching Voltage — maximum voltage prior to switching to on state during 100 V/μs surge
VDRM Peak Off-state Voltage — maximum voltage that can be applied while maintaining off state
VT On-state Voltage — maximum voltage measured at rated on-state current
新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan.
TEL: +886-3-5643931 FAX: +886-3-5644624
http://www.pttc.com.tw
Page: 1 of 5
2018/10/12 Rev: D
Electrical Characteristics
Part Number
Marking
VDRM
(V)
VS
(V)
IDRM
(μA)
IS
(mA)
IH
(mA)
IT
(A)
VT
(V)
C0
(pF)
(Min.)
(Max.)
(Max.)
(Max.)
(Min.)
(Max.)
(Max.)
(Typ.)
P0080SA
008A
6
25
5
800
50
2.2
4
45
P0300SA
03A
25
40
5
800
50
2.2
4
45
P0640SA
06A
58
77
5
800
150
2.2
4
35
P0720SA
07A
65
88
5
800
150
2.2
4
50
P0900SA
09A
75
98
5
800
150
2.2
4
40
P1100SA
11A
90
130
5
800
150
2.2
4
35
P1300SA
13A
120
160
5
800
150
2.2
4
35
P1500SA
15A
140
180
5
800
150
2.2
4
40
P1800SA
18A
170
220
5
800
150
2.2
4
40
P2000SA
20A
180
240
5
800
150
2.2
4
40
P2300SA
23A
190
260
5
800
150
2.2
4
45
P2600SA
26A
220
300
5
800
150
2.2
4
35
P3100SA
31A
275
350
5
800
150
2.2
4
35
P3500SA
35A
320
400
5
800
150
2.2
4
30
P4000SA
40A
360
460
5
800
150
2.2
4
P4500SA
45A
400
540
5
800
150
2.2
4
P5000SA
50A
440
600
5
800
150
2.2
4
P0080SB
008B
6
25
5
800
50
2.2
4
60
P0300SB
03B
25
40
5
800
50
2.2
4
65
P0640SB
06B
58
77
5
800
150
2.2
4
45
P0720SB
07B
65
88
5
800
150
2.2
4
45
P0900SB
09B
75
98
5
800
150
2.2
4
40
P1100SB
11B
90
130
5
800
150
2.2
4
40
P1300SB
13B
120
160
5
800
150
2.2
4
40
P1500SB
15B
140
180
5
800
150
2.2
4
35
P1800SB
18B
170
220
5
800
150
2.2
4
65
P2000SB
20B
180
240
5
800
150
2.2
4
60
P2300SB
23B
190
260
5
800
150
2.2
4
60
P2600SB
26B
220
300
5
800
150
2.2
4
45
P3100SB
31B
275
350
5
800
150
2.2
4
45
P3500SB
35B
320
400
5
800
150
2.2
4
40
P4000SB
40B
360
460
5
800
150
2.2
4
40
P4500SB
45B
400
540
5
800
150
2.2
4
40
P5000SB
50B
440
600
5
800
150
2.2
4
40
P0080SC
008C
6
25
5
800
50
2.2
4
75
P0300SC
03C
25
40
5
800
50
2.2
4
75
P0640SC
06C
58
77
5
800
150
2.2
4
55
P0720SC
07C
65
88
5
800
150
2.2
4
60
P0900SC
09C
75
98
5
800
150
2.2
4
65
P1100SC
11C
90
130
5
800
150
2.2
4
55
P1300SC
13C
120
160
5
800
150
2.2
4
90
P1500SC
15C
140
180
5
800
150
2.2
4
50
P1800SC
18C
170
220
5
800
150
2.2
4
55
P2000SC
20C
180
240
5
800
150
2.2
4
85
P2300SC
23C
190
260
5
800
150
2.2
4
65
P2600SC
26C
220
300
5
800
150
2.2
4
65
Page: 2 of 5
2018/10/12 Rev: D
VDRM
(V)
VS
(V)
IDRM
(μA)
IS
(mA)
IH
(mA)
IT
(A)
VT
(V)
C0
(pF)
(Min.)
(Max.)
(Max.)
(Max.)
(Min.)
(Max.)
(Max.)
(Typ.)
275
350
5
800
150
2.2
4
55
35C
320
400
5
800
150
2.2
4
50
P4000SC
40C
360
460
5
800
150
2.2
4
45
P4200SC
42C
400
500
5
800
150
2.2
4
45
P4500SC
45C
400
540
5
800
150
2.2
4
45
P5000SC
50C
440
600
5
800
150
2.2
4
45
Part Number
Marking
P3100SC
31C
P3500SC
Notes:
All measurements are made at an ambient temperature of 25℃. IPP applies to -40℃ through +85℃ temperature range.
Off-state capacitance (C0) is measured at 1MHz with a 2V bias and is typical value.
Surge Ratings
IPP (A)
ITSM
60 Hz
di/dt
Series
2/101
2/102
(Min.)
1.2/501
8/202
(Min.)
10/1601
10/1602
(Min.)
10/5601
10/5602
(Min.)
10/7001
5/3202
(Min.)
10/10001
10/10002
(Min.)
A
150
150
90
50
75
45
B
250
250
150
100
100
80
30
500
C
500
400
200
150
200
100
50
500
(A)
(Min.)
(A/μs)
(Typ.)
Notes:
1. Voltage waveform in μs.
2. Current waveform in μs.
Fig 1. tr * td Pulse Waveform
Page: 3 of 5
2018/10/12 Rev: D
Ratings and Characteristic Curves
Normalized DC Holding Current vs. Case Temp
Normalized VS Change vs. Junction Temperature
Marking Definitions
PolyTrans Trade mark
Product ID Code
Lot No
Physical Dimensions
Dimension
A
B
C
D
E
F
G
H
I
J
K
L
Millimeters
Inches
Min
Max
Min
Max
1.90
4.06
3.30
1.95
0.76
5.21
0.15
2.26
2.16
2.16
2.20
4.85
3.94
2.44
1.52
0.20
5.59
0.31
2.74
0.077
0.160
0.130
0.084
0.030
0.205
0.006
0.089
0.085
0.085
0.086
0.191
0.155
0.096
0.060
0.008
0.220
0.012
0.107
Page: 4 of 5
2018/10/12 Rev: D
Lead Free Wave Soldering Recommendations
Preheat
- Temperature Min (Tsmin)
- Temperature Max (Tsmax)
- Time (Tsmin to Tsmax)
- Average Ramp-Up Rate
150ºC
200ºC
60-180 seconds
1~3ºC/second
Peak Temperature
260ºC max.
Time within 5ºC of actual Peak
Temperature (tp)
40 seconds max.
Ramp-Down Rate
6 ºC /second max.
Note: If the wave soldering temperatures exceed the recommended profile, devices may not meet the performance requirements.
Packaging
Part Number
Component
Package
Quantity
PXXXX S Series
DO-214AA
2500
Packaging Specification
Tape & Reel – 12mm tape/13” reel
Standard
EIA STD RS-481
Tape and Reel Specifications
Page: 5 of 5
2018/10/12 Rev: D
很抱歉,暂时无法提供与“P2300SC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.95720
- 10+4.01760
- 30+3.55320
- 100+3.08880
- 500+2.80800
- 1000+2.66760
