BEP4200SC
BEP4200SC
    BORN(伯恩半导体)
    SMB(DO-214AA)
    双向撬棒瞬态电压保护
BEP4200SC 数据手册
BEPxxxxSC Features ◆ Bi-directional crowbar transient voltage protection ◆ High surge capability ◆ High off-state impedance ◆ Low leakage current ◆ Low on-state voltage ◆ Short-circuit failure mode DO-214AA(SMB) Main Application BORN’s thyristor surge protector devices are desi gned to help protect sensitive telecommunication equipment from the hazards caused by lighning ,power contact,and power induction. These devices enable equipment to comply with various regulatory requirements including GR 1089,ITU K.20,K.21and K.45,IEC 60950,UL 60950,and TIA-968-A(formerly known as FCC Part 68). Typical application including: ● Central office switching equipment. Analog and digital linecards(xDSL,T1/E1,ISDN……) ● Customer Premises Equipment(CPE)such as phones, fax machines,modems,POS terminals, ● ● ● ● ● PBX systems and caller ID adjunct boxes. Primary protection modules including Main Distribution Frames(MDF),building entrance equipment and station protection modules. Access network equipment such as remote terminals,line repeaters,multiplexers,cross-connects,WAN equipment,Network Interface Devices(NID). Data lines and security systems. CATV line amplifiers and power inserters. Sprinkler systems. Electrcal Parameters (Tamb=25℃) VDRM IDRM VBO IBO VT IT CO `IH Min. Max. Max. Max. Max. Max. Max. Min. V uA V mA V A pF mA BEP0080SC 6 5 25 800 4 2.2 100 50 BEP0300SC 25 5 40 800 4 2.2 100 50 BEP0640SC 58 5 77 800 4 2.2 85 150 BEP0720SC 65 5 88 800 4 2.2 85 150 BEP0900SC 75 5 98 800 4 2.2 70 150 BEP1100SC 90 5 130 800 4 2.2 70 150 Part Number Page 1 of 4 BEPxxxxSC VDRM IDRM VBO IBO VT IT CO `IH Min. Max. Max. Max. Max. Max. Max. Min. V uA V mA V A pF mA BEP1300SC 120 5 160 800 4 2.2 70 150 BEP1500SC 140 5 180 800 4 2.2 55 150 BEP1800SC 170 5 220 800 4 2.2 55 150 BEP2000SC 180 5 220 800 4 2.2 55 150 BEP2300SC 190 5 260 800 4 2.2 50 150 BEP2600SC 220 5 300 800 4 2.2 50 150 BEP3100SC 275 5 350 800 4 2.2 45 150 BEP3500SC 320 5 400 800 4 2.2 35 150 BEP3800SC 360 5 460 800 4 2.2 35 150 BEP4200SC 400 5 540 800 4 2.2 35 150 Part Number Eletrical Characteristics VDRM Stand-off voltage,is measured at IDRM IH Holding current. VBO Breakover voltage,is measured at 100V/μs. IBO Breadover current. CO Off-state capacitance ismeasured in VDC=2V@1MHZ. IT ON-state current VT On-state voltage. IDRM Leakage current,is measured at VDRM. Part Numbering System BEP (A) XXXX (B) S C (C) (D) (A) SH’s Semiconductor Surge Arrester (B) Series:0080,0300…3500,3800,4200etc. (C) Pake:SMB(DO-214AA) (D) Rating Sure Voltage:C:6KV(10/700μs ) Page 2 of 4 BEPxxxxSC Electrical Characteristics Curves Figure1 V-I Characteristics Figure2 tr x td Pulse Wave-form Figure 3 Normalized VS Change versus Junction Temperature Figure 4 Normalized DC Holding Current Thermal Considerations Package DO-214AA/SMB Symbol Parameter Value Unit TJ Operating Junction Temperature -40 to +150 ℃ TS Storage Temperature Range -40 to +150 ℃ RθJA Junction to Ambient on printed circuit 90 ℃/W Page 3 of 4 BEPxxxxSC Solder Reflow Recommendations ●Recommended reflow methods: IR, vapor phase oven, hot air oven, wave solder. ●The device can be exposed to a maximum temperature of 265°C for 10 seconds. ●Devices can be cleaned using standard industry methods and solvents. Notes: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. Product Dimensions B Dimension Inches Millimeters MIN MAX MIN MAX A 0.134 0.155 3.40 3.94 B 0.205 0.22 5.21 5.59 C 0.075 0.083 1.90 2.11 D 0.166 0.185 4.22 4.70 E 0.036 0.056 0.91 1.42 F 0.073 0.087 1.85 2.2 G 0.002 0.008 0.05 0.20 H 0.077 0.094 1.95 2.40 J 0.043 0.053 1.09 1.35 K 0.008 0.014 0.20 0.35 L 0.039 0.049 0.99 1.24 D C A H F L E J .079 (2.0) 0.110 (2.8) .079 (2.0) Page 4 of 4 K G
BEP4200SC 价格&库存
很抱歉,暂时无法提供与“BEP4200SC”相匹配的价格&库存,您可以联系我们找货
BEP4200SC
  • 5+0.98259
  • 50+0.80633
  • 150+0.71820
  • 500+0.65211
  • 3000+0.50382
  • 6000+0.47736
库存:10138
BEP4200SC
  • 1+0.73439
  • 200+0.50676
  • 1500+0.46041
  • 3000+0.43054
库存:1049
