P3500LA
P3500LA
    JKSEMI(金开盛)
    DO-15
    P3500LA
P3500LA 数据手册
TSS 半导体放电管Thyristor Surge Suppressors JKS’S TSS DO-41/15/27 Series Features ◆ ◆ ◆ ◆ ◆ ◆ Bi-directional crowbar transient voltage protection High surge capability High off-state impedance Low leakage current Low on-state voltage Short-circuit failure mode DO-41/15/27 Main Application JKS’s thyristor surge protector devices are designed to help protect sensitive telecommunication equipment from the hazards caused by lighning ,power contact,and power induction. These devices enable equipment to comply with various regulatory requirements including GR 1089,ITU K.20,K.21and K.45,IEC 60950,UL 60950,and TIA-968-A(formerly known as FCC Part 68). Typical application including: ● Central office switching equipment. Analog and digital linecards(xDSL,T1/E1,ISDN……) ● Customer Premises Equipment(CPE)such as phones, fax machines,modems,POS ● ● ● ● ● terminals, PBX systems and caller ID adjunct boxes. Primary protection modules including Main Distribution Frames(MDF),building entrance equipment and station protection modules. Access network equipment such as remote terminals,line repeaters,multiplexers,cross-connects,WAN equipment,Network Interface Devices(NID). Data lines and security systems. CATV line amplifiers and power inserters. Sprinkler systems. -1- TSS 半导体放电管Thyristor Surge Suppressors Electrcal Characteristics (Tamb=25℃) VDRM IDRM VBO IBO VT IT `IH CO Min. Max. Max. Max. Max. Max. Min. Max. V uA V mA V A mA P0080L_ 6 5 25 800 4 2.2 P0300L_ 25 5 40 800 4 P0640L_ 58 5 77 800 P0720L_ 65 5 88 P0900L_ 75 5 P1100L_ 90 P1300L_ Part Number pF A B C 50 50 75 100 2.2 50 70 75 100 4 2.2 150 50 65 100 800 4 2.2 150 50 65 100 98 800 4 2.2 150 45 60 90 5 130 800 4 2.2 150 45 60 90 120 5 160 800 4 2.2 150 45 60 90 P1500L_ 140 5 180 800 4 2.2 150 40 60 85 P1800L_ 170 5 220 800 4 2.2 150 40 60 85 P2000L_ 180 5 220 800 4 2.2 150 40 60 85 P2300L_ 190 5 260 800 4 2.2 150 35 55 80 P2600L_ 220 5 300 800 4 2.2 150 35 50 80 P3100L_ 275 5 350 800 4 2.2 150 30 45 65 P3500L_ 320 5 400 800 4 2.2 150 30 40 65 P3800L_ 360 5 460 800 4 2.2 150 25 40 45 P4200L_ 400 5 540 800 4 2.2 150 25 40 45 General Notes: ◆ All measurements are made at an ambient temperature of 25℃.Ipp applies to -40℃ through +85 ℃ temperature range. ◆ Special voltage(VBO and VDRM) and holding current(IH) requirements are available up on request. ◆ Off-state capacitance (CO) is measured at 1 MHz with a 2 V bias and is typical value. -2- TSS 半导体放电管Thyristor Surge Suppressors Electrical Parameters(Tamb=25℃) Symbol Parameter Symbol Stand-off voltage,is VDRM IDRM measured at IDRM IH Breakover voltage,is IBO Leakage current,is measured at VDRM IT Holding current VBO Parameter measured at 100V/μs CO Breadover current VT ON-state current Off-state capacitance ismeasured in VDC=2V@1MHZ On-state voltage Surge Ratings IPP IPP IPP IPP IPP ITSM 2x10 µs 8x20 µs 10x160 µs 10x560 µs 10x1000 µs 60 Hz Amps Amps Amps Amps Amps Amps A 150 150 90 50 45 20 500 B 250 250 250 200 80 30 500 C 500 400 200 150 100 50 500 Series di/dt Amps/µs Thermal Considerations Package DO-41/15/27 Symbol TJ TS RθJA Parameter Operating Junction Temperature Storage Temperature Range Junction to Ambient on printed circuit Value Unit -40 to +150 ℃ -40 to +150 ℃ 70 ℃/W -3- TSS 半导体放电管Thyristor Surge Suppressors Electrical Characteristics Curves Figure1 V-I Characteristics Figure2 tr x td Pulse Wave-form Figure 3 Figure 4 Normalized DC Holding Current Normalized VS Change versus Junction Temperature versus Case Temperature -4- TSS 半导体放电管Thyristor Surge Suppressors Product Dimensions A D C D B DO-41 Dimension Inches Millimeters NOTE MIN MAX MIN MAX A 0.166 0.205 4.10 5.20 B 0.080 0.107 2.00 2.70 Φ C 0.028 0.034 0.70 0.90 Φ D 1.000 25.40 DO-15 Dimension Inches Millimeters NOTE MIN MAX MIN MAX A 0.230 0.300 5.80 7.60 B 0.104 0.140 2.60 3.60 Φ C 0.026 0.034 0.70 0.90 Φ D 1.000 25.40 -5- TSS 半导体放电管Thyristor Surge Suppressors Product Dimensions A D C D B DO-27 Dimension Inches MIN Millimeters MAX MIN MAX NOTE A 0.370 9.50 B 0.250 6.40 Φ 1.30 Φ C 0.048 D 1.000 0.052 1.20 25.40 Summary of Packing Options Package Type Description DO-41/15/27 Packing Industry Quantity Standard DO-41 DO-15 DO-27 5000PCS 4000PCS 1200PCS Tape and Reel Pack N/A -6-
P3500LA 价格&库存
很抱歉,暂时无法提供与“P3500LA”相匹配的价格&库存,您可以联系我们找货
P3500LA
    • 5+0.73138
    • 50+0.61733
    • 150+0.56031
    • 500+0.51754
    • 2500+0.44885
    • 5000+0.43168
