P0080TB-MS
P0080TB-MS
    MSKSEMI(美森科)
    SMA(DO-221AC)
    P0080TB-MS
P0080TB-MS 数据手册
www.msksemi.com PXXXXTB-MS Semiconductor Compiance Features Low capatcitance Cannot be damaged by voltage Will not fatigue Eliminate voltage overshoot Glass passivated junction Halogen free and RoHS compliant SMA Symbol Mechanical Data CASE: SMAJ(DO-214AC) Molded Plastic UL Flammability Classification Rating 94V0 Mounting Position:Any Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Peak Pulse Voltage Symbol VPP Value 4000 Units V Remarks 10/700us Peak Pulse Current IPP 80 A 10/1000us Peak Pulse Current IPK 250 A 8/20us Peak One-cycle Surge Current ITSM 25 A 60Hz Rate of Rise of Current 500 A/us Typical Thermal Resistance Junction to Lead di/dt RθJL 30 ℃/W Typical Thermal Resistance Junction to Ambient RθJA 120 ℃/W TJ -40 to 150 ℃ TSTG -55 to 150 ℃ Operating Temperature Range Storage Temperature Range PXXXXTB-MS Semiconductor Compiance Electrical Characteristics ( Ratings at 25 ℃ ambient temperature unless otherwise specified). P/N Mark VS @100KV/S IS_LMT VT @ IT IT ID @ VD VD CO@1MHz,2VDC IH V MAX mA V MAX A uA MAX V pF TYP mA MIN P0080TB-MS P008B XXXX 25 500 4 2.2 5 6 29 40 P0220TB-MS P02B XXXX 30 500 4 2.2 5 15 29 40 P0300TB-MS P03B XXXX 40 500 4 2.2 5 25 28 40 P0640TB-MS P06B XXXX 77 800 4 2.2 5 58 27 120 P0720TB-MS P07B XXXX 88 800 4 2.2 5 65 27 120 P0900TB-MS P09B XXXX 98 800 4 2.2 5 75 27 120 P1100TB-MS P11B XXXX 130 800 4 2.2 5 90 25 120 P1300TB-MS P13B XXXX 160 800 4 2.2 5 120 25 120 P1500TB-MS P15B XXXX 180 800 4 2.2 5 140 24 120 P1800TB-MS P18B XXXX 220 800 4 2.2 5 170 22 120 P2300TB-MS P23B XXXX 260 800 4 2.2 5 190 21 120 P2600TB-MS P26B XXXX 300 800 4 2.2 5 220 20 120 P3100TB-MS P31B XXXX 350 800 4 2.2 5 275 18 120 P3500TB-MS P35B XXXX 400 800 4 2.2 5 320 17 120 P4500TB-MS P45B XXXX 530 800 4 2.2 5 400 13 120 www.msksemi.com PXXXXTB-MS Semiconductor Compiance Ratings and Characteristic Curves ( Ratings at 25℃ ambient temperature unless otherwise specified). 2 16 14 1.8 10 Ratio of IH / IH (TC=25℃) Percent of VS Change (%) 12 8 6 4 2 0 25, 0 -2 -4 1.6 1.4 1.2 1 25, 1 0.8 0.6 -6 -8 0.4 -40 -20 0 20 40 60 80 100 120 140 -40 160 -20 0 TJ - Junction Temperature (℃) 40 60 80 100 120 140 160 Fig.2 - Normalized DC Holding Current vs. Case Temperature 100 Current (A) VT,IT 50 IH VS,IS VD,ID VB 0 tr td t - Time (us) Voltage (V) Fig.3 - tr/td us Pulse Waveform 10000 Fig.4 - VI Curve 100 1000 100 10 1 0.1 1 10 100 td - Pulse Width (us) Fig.5 - Peak Pulse Current Rating 1000 CO - Typical Off-state Capacitance (pF) IPP - Peak Pulse Current, % IPK Fig.1 - Peak Pulse Current Rating IPP - Peak Pulse Current (A) 20 TC - Case Temperature (℃) 80 60 40 20 0 0 100 200 300 400 500 VB - Breakdown Voltage (V) Fig.6 - Typical Off-state Capacitance www.msksemi.com PXXXXTB-MS Semiconductor Compiance PACKAGE MECHANICAL DATA A Dimensions B C Ref. H F G D E L J K Millimeters Min. Max. Min. Max. A 4.25 4.65 0.167 0.183 B 2.50 2.90 0.098 0.114 C 1.35 1.65 0.053 0.065 D 0.76 1.52 0.030 0.060 E 4.93 5.28 0.194 0.208 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 1.98 2.41 0.078 0.095 J 6.50 L 0.256 2.30 K DO-214AC (SMA) Inches 1.70 0.090 0.067 REEL SPECIFICATION P/N PXXXXTB-MS PKG QTY SMA 5000 www.msksemi.com PXXXXTB-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
P0080TB-MS 价格&库存
很抱歉,暂时无法提供与“P0080TB-MS”相匹配的价格&库存,您可以联系我们找货
