P0080TA
P0080TA
    JKSEMI(金开盛)
    SMA(DO-221AC)
    TSS半导体放电管
P0080TA 数据手册
TSS 半导体放电管 JKS ’S TSS Thyristor Surge Suppressors SMA Series Features ◆ Bi-directional crowbar transient voltage protection ◆ High surge capability ◆ High off-state impedance ◆ Low leakage current ◆ Low on-state voltage ◆ Short-circuit failure mode DO-214AC(SMA) Main Application JKS’s thyristor surge protector devices are designed to help protect sensitive telecommunication equipment from the hazards caused by lighning ,power contact,and power induction. These devices enable equipment to comply with various regulatory requirements including GR 1089,ITU K.20,K.21and K.45,IEC 60950,UL 60950,and TIA-968-A(formerly known as FCC Part 68). Typical application including: ● Central office switching equipment. Analog and digital linecards(xDSL,T1/E1,ISDN……) ● Customer Premises Equipment(CPE)such as phones, fax machines,modems,POS ● ● ● ● ● terminals, PBX systems and caller ID adjunct boxes. Primary protection modules including Main Distribution Frames(MDF),building entrance equipment and station protection modules. Access network equipment such as remote terminals,line repeaters,multiplexers,cross-connects,WAN equipment,Network Interface Devices(NID). Data lines and security systems. CATV line amplifiers and power inserters. Sprinkler systems. www.jinkaisheng.com -1- TSS 半导体放电管 Thyristor Surge Suppressors Electrcal Characteristics (Tamb=25℃) VDRM IDRM VBO IBO VT IT `IH CO Min. Max. Max. Max. Max. Max. Min. Max. V uA V mA V A mA pF P0080TA 6 5 25 800 4 2.2 50 50 P0300TA 25 5 40 800 4 2.2 50 70 P0640TA 58 5 77 800 4 2.2 150 50 P0720TA 65 5 88 800 4 2.2 150 50 P0900TA 75 5 98 800 4 2.2 150 45 P1100TA 90 5 130 800 4 2.2 150 45 P1300TA 120 5 160 800 4 2.2 150 45 P1500TA 140 5 180 800 4 2.2 150 40 P1800TA 170 5 220 800 4 2.2 150 40 P2000TA 180 5 220 800 4 2.2 150 40 P2300TA 190 5 260 800 4 2.2 150 35 P2600TA 220 5 300 800 4 2.2 150 35 P3100TA 275 5 350 800 4 2.2 150 30 P3500TA 320 5 400 800 4 2.2 150 30 P3800TA 360 5 460 800 4 2.2 150 25 P4200TA 400 5 540 800 4 2.2 150 25 Part Number General Notes: ◆ All measurements are made at an ambient temperature of 25℃.Ipp applies to -40℃ through +85 ℃ temperature range. ◆ Special voltage(VBO and VDRM) and holding current(IH) requirements are available up on request. ◆ Off-state capacitance (CO) is measured at 1 MHz with a 2 V bias and is typical value. www.jinkaisheng.com -2- TSS 半导体放电管 Thyristor Surge Suppressors Electrical Parameters(Tamb=25℃) Symbol Parameter Symbol Parameter VDRM Stand-off voltage,is measured at IDRM IH Holding current IT ON-state current On-state voltage Leakage current,is IDRM measured at VDRM VBO Breakover voltage,is measured at 100V/μs VT IBO Breadover current CO Off-state capacitance ismeasured in VDC=2V@1MHZ Surge Ratings Series A IPP IPP IPP IPP IPP ITSM 2x10 µs 8x20 µs 10x160 µs 10x560 µs 10x1000 µs 60 Hz Amps Amps Amps Amps Amps Amps 150 150 90 50 45 20 di/dt Amps/µs 500 Thermal Considerations Package SMA(DO-214AC) Symbol TJ TS RθJA Parameter Operating Junction Temperature Storage Temperature Range Junction to Ambient on printed circuit www.jinkaisheng.com Value Unit -40 to +150 ℃ -40 to +150 ℃ 90 ℃/W -3- TSS 半导体放电管 Thyristor Surge Suppressors Electrical Characteristics Curves Figure1 V-I Characteristics Figure2 tr x td Pulse Wave-form Figure 3 Normalized VS Change versus Figure 4 Normalized DC Holding Current Junction Temperature versus Case Temperature www.jinkaisheng.com -4- TSS 半导体放电管 Thyristor Surge Suppressors Product Dimensions B Dimension Inches Millimeters D MIN MAX MIN MAX A 0.098 0.114 2.50 2.90 B 0.188 0.208 4.80 5.28 C 0.055 0.062 1.40 1.60 D 0.157 0.181 4.00 4.60 E 0.030 0.060 0.76 A C H F E .079 (2.0) 1.52 0.110 F 0.078 0.096 2.00 (2.8) 2.44 .079 H 0.080 0.104 2.051 (2.0) 2.643 Summary of Packing Options Package Type Description Packing Industry Quantity Standard 5000PCS EIA-481-D DO-214AC(SMA) Embossed Carrier Reel Pack www.jinkaisheng.com -5-
P0080TA 价格&库存
很抱歉,暂时无法提供与“P0080TA”相匹配的价格&库存,您可以联系我们找货
