P0640TA
P0640TA
    SEMIWARE(赛米微尔)
    SMA(DO-214AC)
    半导体放电管(TSS) 58V 45A SMA(DO-214AC)
P0640TA 数据手册
TSS-TA Thyristor Surge Suppresser DESCRIPTION DO - 214AC / SMA Thyristor solid state protection thyristor protect telecommunications equipment such as modems , line cards , fax machines , and other CPE . This Series devices are used to enable equipment to meet various regulatory requirements including GR1089 , ITUK . 20 , K . 21 and K . 45 , IEC 60950 , and TIA - 968 ( formerly known as FCC Part 68 ). FEATURES DO-214AC PACKAGE > Excellent capability of absorbing transient surge > Quick response to surge voltage > Eliminates overvoltage caused by fast rising transients > Solid-state silicon technology, non degenerative 2 1 APPLICATIONS > Audio/Video line > Network and telecom > Data lines and security systems > Serial ports SCHEMATIC SYMBOL PART NUMBER AND ELECTRICAL PARAMETER @ T=25℃ RH = 45%-75% PART NUMBER V DRM V I DRM uA Max VS V Max IS mA VT V Max IT A IH mA Min CO pF Typ P0080TA 6 5 25 800 4 2.2 50 50 P0300TA 25 5 40 800 4 2.2 50 50 P0640TA 58 5 77 800 4 2.2 50 50 P1800TA 170 5 220 800 4 2.2 50 50 P2300TA 190 5 260 800 4 2.2 50 50 P2600TA 220 5 300 800 4 2.2 50 50 P3100TA 275 5 350 800 4 2.2 50 50 P3500TA 320 5 400 800 4 2.2 50 50 P4200TA 390 5 500 800 4 2.2 50 50 1、Vs is measured at 100KV/S 2、Off-state capacitance is measured in V DC =2V,V RMS =1V,F=1MHz 3、All measurements are made at an ambient temperature of 25℃ SURGE RATINGS Series IPP 2x10us (A) IPP 8x20us (A) IPP 10x560us (A) IPP 10x1000us (A) VPP 10x700us (V) I TSM 60Hz (A) d i /d t (A/us) P0080TA Thru P4200TA 150 150 50 45 3000 20 500 Document Number: 151001 Page 1 www.semiware.com.cn TSS-TA Thyristor Surge Suppresser THERMAL CONSIDERATIONS Symbol Parameter Value Unit TJ Operang Juncon Temperature -40 to +150 ℃ TS Storage Temperature Range -40 to +150 ℃ RθJA Juncon to Ambient on printed circuit 90 ℃/W TYPICAL DEVICE CHARACTERISTICS IPP– Peak Pulse Current – %IPP +I IT IS IH I DRM -V +V V DRM VT VS Peak Value 100 tr = rise me to peak value td = decay me to half value Wave form = t r x t d 50 Half Value 0 0 td tr t – Time (μs) -I V-I Characteristics tr x td Pulse Waveform 2.0 14 1.8 IH I H (Tc=25 °C) 10 8 6 25 °C 4 2 Rao of Percent of V S Change – % 12 0 -4 1.6 1.4 25 °C 1.2 1.0 0.8 0.6 -6 0.4 -40 -8 -40 -20 0 20 40 60 80 100 120 140 16 0 0 20 40 60 80 1 00 120 1 40 160 Case Temperature (T C ) - °C Juncon Temperature (TJ) – °C Normalized VS Change vs. Junction Temperature Document Number: 151001 -20 Normalized DC Holding Current vs. Case Temperature Page 2 www.semiware.com.cn TSS-TA Thyristor Surge Suppresser ENVIRONMENTAL CHARACTERISTICS Tesng Items Technical Standards High Temperature Reverse Bias Test Temperature:150±3℃, Bias=80%V DRM ;Time:168H High Temperature Life Test Temperature:150℃ ;Time:168H High-Low Temperature Cycle Test Temperature:From -40℃ to 150℃ ;Dwell Time:30min,10-100 Cycles High Temperature&High Humidity Test Temperature:85℃.Humidity:85%; Time:168H Pressure Cooker Test Temperature:121℃, 2 atm.Humidity:100%; Time:24H To 168H Resistance Of Soldering Heat Temperature:260±5℃;Time Of Dip Soldering:10s,3 Times PRODUCT DIMENSIONS OUTLINE DIMENSIONS A C B H D E MILLIMETERS DIM INCHES MIN MAX MIN MAX A 1 . 23 1.63 0 . 049 0.064 B 4.10 4.55 0 . 162 0.179 C 2.51 2.76 0 . 099 0.109 D 1.96 2.26 0 . 077 0.089 E 0.75 1.51 0 . 030 0.060 F 0.00 0.20 0 . 000 0.008 G 4.87 5.22 0 . 192 0.206 H 0.15 0.30 0 . 006 0.012 F NOTES G 1. Dimensions are exclusive of mold flash and metal burrs. PAD LAYOUT DIMENSIONS MILLIMETERS DIM MAX MIN MAX A 1.57 - 0 . 062 - B 1.55 - 0 . 061 - C - 2.28 - 0.090 D 1.55 - 0 . 061 - A B Document Number: 151001 C D INCHES MIN Page 3 www.semiware.com.cn TSS-TA Thyristor Surge Suppresser SOLDERING PARAMETERS Reflow Condion Pre Heat Lead–free assembly Temperature Min (Ts(min)) 150°C Temperature Max (Ts(max) 200°C Time (min to max) (ts) 60 – 180 secs Average ramp up rate (Liquidus Temp (T L ) to peak 3°C/second max T S (max)to T L - Ramp-up Rate 3°C/second max 217°C Temperature (T L ) (Liquidus) Reflow Time (min to max) (ts) 60 – 150 seconds 260°C Peak Temperature (T P ) Time within 5°C of actual peak Temperature (tp) 20 – 40 seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (T P ) 8 minutes Max. Do not exceed 260°C TAPE AND REEL SPECIFICATION 10 Pitches Cumulave Tolerance on tape ± 0.2 P0 D t E F W K0 B0 A0 P User Direcon of Feed SPECIFICATIONS REEL DIA. TAPE WIDTH 330mm (13”) 12mm A0 B0 K0 D E 2.79 ± 0.10 5.33 ± 0.10 2.36 ± 0.10 1.55 ± 0.10 1.75 ± 0.10 F W P0 P 5.5 ± 0.05 12.00 ± 0.30 4.00 ± 0.10 4.00 ± 0.10 tmax 0.40 NOTES 1. Dimensions are in millimeters. 2. Surface mount product is taped and reeled in accordance with EIA-481. 3. Suffix - T = 13” Reel - 5,000 pieces per 12mm tape. ORDERING INFORMATION Part Number PXXXXTA Document Number: 151001 Component Package QTY/Reel Reel Size DO-214AC 5000PCS 13" Page 4 www.semiware.com.cn TSS-TA Thyristor Surge Suppresser CONTACT US Headquarters A Building Caohejing I&E Park Pujiang Minhang Shanghai China Hotline 400-021-5756 Web http://www.semiware.com.cn By Telephone General: 86-21-3463-7173 Sales: 86-21-3463-7345 Customer Service: 86-21-3463-7173-8810 Technical Support: 86-21-3463-7173-8811 By Email Sales: sales08@semiware.com.cn Customer Service: sales17@semiware.com.cn Technical Support: fae03@semiware.com.cn By Fax General: 86-21-3965-0654 Sales:86-21-3463-7458 COPYRIGHT ©Semiware 2009 - This literature is subject to all applicable copyright laws and is not for resale in any manner. SPECIFICATIONS: Semiware reserves the right to change the electrical and or mechanical characteristics described herein without notice. DESIGN CHANGES : Semiware reserves the right to discontinue product lines without notice and that the final judgement concerning selection and specifications is the buyer’s and that in furnishing engineering and technical assist-ance.Semiware assumes no responsibility with respect to the selection or specifications of such products.Semiware makes no warranty,representation or guarantee regarding the suitability of its products for any particular purpose, nor does Semiware assume any liability arising out of the application or use of any product or circuit and specifically disclaims any and all liability without limitation special,consequential or incidental damages. LIFE SUPPORT POLICY: Semiware products are not authorized for use in life support systems without written consent from the factory. Document Number: 151001 Page 5 www.semiware.com.cn
P0640TA 价格&库存
很抱歉,暂时无法提供与“P0640TA”相匹配的价格&库存,您可以联系我们找货
