TPW4157-TR
TPW4157-TR
    3PEAK(思瑞浦)
    SOT23-6
    1 电路 IC 开关 2:1 1.15 欧姆 SOT23-6
TPW4157-TR 数据手册
TPW4157 Low Voltage 1Ω SPDT Analog Switch Features Description Latch-Up Performance Exceeds 800 mA Per JESD 78, TPW4157 is high performance Single Pole/Double Throw Class II (SPDT) analog switches. The devices feature ultra low RON of ⚫ Supply Voltage: 1.65V to 5.5V 1.15Ω maximum at 4.5V VCC and will operate over the wide VCC ⚫ Low ON-State Resistance: typical 0.95Ω at Vs = 4.5V ⚫ Bandwidth: 100 MHz ⚫ Fast switching times: tON =40 ns, tOFF =15 ns ⚫ Break-Before-Make Switching ⚫ Operation Temperature Range: –40°C to 125°C ⚫ range of 1.65V to 5.5V. The TPW4157 features very low quiescent current even when the control voltage is lower than the VCC supply. This feature services the portable applications very well allowing for the direct interface with processor general purpose I/Os. Applications Function Table ⚫ Industry control systems ⚫ Battery-powered systems Input: Select Pin Function ⚫ Audio Signal Routing Low B0 Connected to A ⚫ Portable Instruments and Mobile Device High B1 Connected to A Pin Description Pin Configuration 6Pin SC70/SOT23 -C Suffixes B1 1 6 Select GND 2 5 VS B0 3 4 A www.3peak.com 1 / 15 Pin name Pin No Pin function B1 1 Switch Port 1 GND 2 Ground B0 3 Switch Port 0 A 4 Common switch port VCC 5 Power supply Select 6 Select pin Rev.A.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch Table of Contents Features ........................................................................................................................................................................... 1 Applications ..................................................................................................................................................................... 1 Description....................................................................................................................................................................... 1 Function Table ................................................................................................................................................................. 1 Pin Description ................................................................................................................................................................ 1 Table of Contents ............................................................................................................................................................ 2 Revision History .............................................................................................................................................................. 3 Order Information ............................................................................................................................................................ 3 Absolute Maximum Ratings Note 1 ................................................................................................................................... 4 ESD and Latch Up Rating ............................................................................................................................................... 4 Thermal Information ....................................................................................................................................................... 4 Recommended Operating Conditions Note 1 .................................................................................................................. 4 Electrical Characteristics ............................................................................................................................................... 5 VCC = 4.5 to 5.5V, unless otherwise noted. ................................................................................................................................. 5 VCC = 2.7 to 3.6V, unless otherwise noted. ................................................................................................................................. 6 VCC = 1.65 to 1.95V, unless otherwise noted. ............................................................................................................................. 7 TA = 0°C to 50°C, unless otherwise noted. .................................................................................................................................. 8 Typical Performance Characteristics ............................................................................................................................ 9 Test Circuit and Waveforms ......................................................................................................................................... 10 Application Information ................................................................................................................................................ 11 Tape and Reel Information ........................................................................................................................................... 12 Package Outline Dimensions ....................................................................................................................................... 13 SC70-6 ....................................................................................................................................................................................... 13 SOT23-6..................................................................................................................................................................................... 14 IMPORTANT NOTICE AND DISCLAIMER .................................................................................................................... 15 www.3peak.com 2 / 15 Rev.B.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch Revision History Date Revision Notes 2018/3/24 Rev.Pre Pre-Release Version 2018/11/1 Rev.0 Initial Release Version 2019/4/21 Rev.0.01 Update Mark Information Update Package Outline Correct Toff test condition in figure 6: 50% of output -> 90% of output Correct Tb test condition in Electrical Characteristics: B0 or B1 = 3V -> B0 or B1 = 1.5V; in figure 7: 0.9*Vout -> 0.9V Spec of ΔRON at 1.65Vcc change: 2/3/3ohm –> 5/7/7ohm 2021/4/1 Rev.A.0 Add TPW4157-TR 2022/3/23 Rev.B.0 Update SOT23-6 MSL from 1 to 3 Order Information Order Number Operating Temperature Range Package Marking Information MSL Transport Media, Quantity TPW4157-CR -40 to 125°C 6-Pin SC70 415XX Note 1 1 Tape and Reel, 3000 TPW4157-TR -40 to 125°C 6-Pin SOT23 415XX Note 1 3 Tape and Reel, 3000 Note 1: “XX” identify the date code information. www.3peak.com 3 / 15 Rev.B.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch Absolute Maximum Ratings Note 1 Parameters Rating Supply Voltage, VCC -0.5V to 6V Select Input Voltage -0.5V to 6V Select Input Diode Current –50mA Switch I/O Port Voltage -0.5 to VCC + 0.5 Switch I/O Port diode current ±50mA Switch Current 200mA Maximum Junction Temperature 150°C Storage Temperature Range –65 to 150°C Lead Temperature (Soldering, 10 sec) 260°C Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. ESD and Latch Up Rating Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001 4 Kv CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002 2 Kv JESD 78, 25°C 800 mA LU Latch Up JESD 78, 125°C 800 mA Thermal Information Package Type θJA 6-Pin SC70 400 θJC Unit °C/W Recommended Operating Conditions Note 1 Over operating temperature range Parameters Min Max Unit Supply Voltage, VCC 1.65 5.5 V Select Input Voltage 0 VCC V 100 ns/V Input Transition Rise and Fall Rate Switch I/O Port Voltage 0V VCC V Operating Temperature Range –40 125 °C Note 1: Select input must be held HIGH or LOW and it must not float. www.3peak.com 4 / 15 Rev.B.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch Electrical Characteristics VCC = 4.5 to 5.5V, unless otherwise noted. Symbol Parameter Conditions VCC (V) 25°C -40°C to 85°C -40°C to 125°C Limit Unit Power Supply ICC Quiescent Supply Current VIN = 0V or VCC 5.5 0.3 0.5 1.5 Max μA ΔICC Increase in ICC per Input Select Input at 2.7V, others at VCC or GND 4.3 20 25 25 Max μA Digital Input VIH Input Voltage High 2.4 2.4 Min V VIL Input Voltage Low 0.8 0.8 Max V IIN Control Input Leakage ±1 ±1 Max μA Typ Ω VIN = 0V or VCC 5.5 RON IOUT = 100mA, B0 or B1 = 3.5V 4.5 0.95 RON IOUT = 100mA, B0 or B1 = 3.5V 4.5 1.15 1.4 1.5 Max Ω Analog Switch ΔRON Maximum ON resistance IOUT = 100mA, B0 or B1 = 3.5V 4.5 0.12 0.15 0.2 Max Ω RFLAT(ON) On Resistance Flatness IOUT = 100mA, B0 or B1 = 0V, 1V, 2V 4.5 0.3 0.4 0.5 Max Ω INO(OFF), INC(OFF) Switch OFF Leakage Current on B0, B1 A = 1V, 4.5V, B0 or B1 = 4.5V, 1V 5.5 ±10 ±25 ±50 Max nA IA(OFF) Switch OFF Leakage Current on A A = 1V, 4.5V, B0 or B1 = 4.5V, 1V 5.5 ±10 ±50 ±100 Max nA IA(ON) Switch ON Leakage Current on A A = 1V, 4.5V, B0 or B1 = 1V, 4.5V or Floating 5.5 ±10 ±50 ±100 Max nA Typ ns Dynamic Characteristics tPHL, tPLH Switch IN to OUT time B0 or B1 = 3V,RL = 50Ω, CL = 35pF, Figure 6 4.5 5 tON Switch turn-on time B0 or B1 = 3V,RL = 50Ω, CL = 35pF, Figure 6 4.5 40 45 45 Max ns tOFF Switch turn-off time B0 or B1 = 3V,RL = 50Ω, CL = 35pF, Figure 6 4.5 15 20 20 Max ns tB Break before make time B0 or B1 = 1.5V,RL = 50Ω, CL = 35pF, Figure 7 4.5 20 40 40 Max ns Q Charge Injection CL = 1.0nF, VGEN = 0V, RGEN = 0Ω, Figure 8 5.5 20 Typ pC OFF-Isolation f = 1MHz, RL = 50Ω, Figure 9 5 -65 Typ dB Crosstalk f = 1MHz, RL = 50Ω, Figure 10 5 -65 Typ dB BW Bandwidth RL = 50Ω 5 100 Typ MHz THD Total Harmonic Distortion RL = 600Ω, VIN = 0.5VPP, f = 20Hz to 20kHz 5 0.004 Typ % Capacitance CIN Select Input capacitance 5 5 Typ pF COFF B-Port Off capacitance 5 12 Typ pF CON ON Capacitance 5 40 Typ pF www.3peak.com 5 / 15 Rev.B.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch VCC = 2.7 to 3.6V, unless otherwise noted. Symbol Parameter Conditions VCC (V) 25°C -40°C to 85°C -40°C to 125°C Limit Unit VIN = 0V or VCC 3.6 0.3 0.5 1.5 Max μA Power Supply ICC Quiescent Supply Current Digital Input VIH Input Voltage High 1.65 1.65 Min V VIL Input Voltage Low 0.6 0.6 Max V IIN Control Input Leakage ±1 ±1 Max μA Typ Ω VIN = 0V or VCC 3.6 RON IOUT = 100mA, B0 or B1 = 1.5V 2.7 2 RON IOUT = 100mA, B0 or B1 = 1.5V 2.7 2.5 2.7 3 Max Ω Analog Switch ΔRON Maximum ON resistance IOUT = 100mA, B0 or B1 = 1.5V 2.7 0.25 0.3 0.35 Max Ω RFLAT(ON) On Resistance Flatness IOUT = 100mA, B0 or B1 = 0V, 0.75V, 1.5V 2.7 1 1.1 1.2 Max Ω INO(OFF), INC(OFF) Switch OFF Leakage Current on B0, B1 A = 0V, 3.6V, B0 or B1 = 3.6V, 0V 3.6 ±10 ±25 ±50 Max nA IA(OFF) Switch OFF Leakage Current on A A = 0V, 3.6V, B0 or B1 = 3.6V, 0V 3.6 ±10 ±50 ±100 Max nA IA(ON) Switch ON Leakage Current on A A = 0V, 3.6V, B0 or B1 = 0V, 3.6V or Floating 3.6 ±10 ±50 ±100 Max nA Typ ns Dynamic Characteristics tPHL, tPLH Switch IN to OUT time B0 or B1 = 1.5V,RL = 50Ω, CL = 35pF, Figure 6 2.7 10 tON Switch turn-on time B0 or B1 = 1.5V,RL = 50Ω, CL = 35pF, Figure 6 2.7 60 70 70 Max ns tOFF Switch turn-off time B0 or B1 = 1.5V,RL = 50Ω, CL = 35pF, Figure 6 2.7 25 30 30 Max ns tB Break before make time B0 or B1 = 1.5V,RL = 50Ω, CL = 35pF, Figure 7 2.7 20 Typ ns Q Charge Injection CL = 1.0nF, VGEN = 0V, RGEN = 0Ω, Figure 8 3 20 Typ pC OFF-Isolation f = 1MHz, RL = 50Ω, Figure 9 3 -65 Typ dB Crosstalk f = 1MHz, RL = 50Ω, Figure 10 3 -65 Typ dB BW Bandwidth RL = 50Ω 3 100 Typ MHz THD Total Harmonic Distortion RL = 600Ω, VIN = 0.5VPP, f = 20Hz to 20kHz 3 0.01 Typ % www.3peak.com 6 / 15 Rev.B.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch VCC = 1.65 to 1.95V, unless otherwise noted. Symbol Parameter Conditions VCC (V) 25°C -40°C to 85°C -40°C to 125°C Limit Unit VIN = 0V or VCC 1.95 0.3 0.5 1.5 Max μA Power Supply ICC Quiescent Supply Current Digital Input VIH Input Voltage High 1.4 1.4 Min V VIL Input Voltage Low 0.4 0.4 Max V IIN Control Input Leakage ±1 ±1 Max μA Typ Ω VIN = 0V or VCC 1.95 RON IOUT = 10mA, B0 or B1 = 0.9V 1.65 10 RON IOUT = 10mA, B0 or B1 = 0.9V 1.65 15 18 18 Max Ω Analog Switch ΔRON Maximum ON resistance IOUT = 10mA, B0 or B1 = 0.9V 1.65 5 7 7 Max Ω INO(OFF), INC(OFF) Switch OFF Leakage Current on B0, B1 A = 0V, 1.95V, B0 or B1 = 1.95V, 0V 1.95 ±10 ±25 ±50 Max nA IA(OFF) Switch OFF Leakage Current on A A = 0V, 1.95V, B0 or B1 = 1.95V, 0V 1.95 ±10 ±50 ±100 Max nA IA(ON) Switch ON Leakage Current on A A = 0V, 1.95V, B0 or B1 = 0V, 1.95V or Floating 1.95 ±10 ±50 ±100 Max nA Typ ns Dynamic Characteristics tPHL, tPLH Switch IN to OUT time B0 or B1 = 1.0V,RL = 50Ω, CL = 35pF, Figure 6 1.65 10 tON Switch turn-on time B0 or B1 = 1.0V,RL = 50Ω, CL = 35pF, Figure 6 1.65 80 90 90 Max ns tOFF Switch turn-off time B0 or B1 = 1.0V,RL = 50Ω, CL = 35pF, Figure 6 1.65 50 70 70 Max ns tB Break before make time B0 or B1 = 1.0V,RL = 50Ω, CL = 35pF, Figure 7 1.65 20 Typ ns Q Charge Injection CL = 1.0nF, VGEN = 0V, RGEN = 0Ω, Figure 8 1.8 20 Typ pC OFF-Isolation f = 1MHz, RL = 50Ω, Figure 9 1.8 -65 Typ dB Crosstalk f = 1MHz, RL = 50Ω, Figure 10 1.8 -65 Typ dB BW Bandwidth RL = 50Ω 1.8 100 Typ MHz THD Total Harmonic Distortion RL = 600Ω, VIN = 0.5VPP, f = 20Hz to 20kHz 1.8 0.01 Typ % www.3peak.com 7 / 15 Rev.B.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch TA = 0°C to 50°C, unless otherwise noted. VCC (V) Spec Limit Unit A = 1V, 4.5V, B0 or B1 = 4.5V, 1V 3.6 ±10 Max nA Switch OFF Leakage Current on A A = 1V, 4.5V, B0 or B1 = 4.5V, 1V 3.6 ±20 Max nA IA(ON) Switch ON Leakage Current on A A = 1V, 4.5V, B0 or B1 = 1V, 4.5V or Floating 3.6 ±20 Max nA INO(OFF), INC(OFF) Switch OFF Leakage Current on B0, B1 A = 1V, 4.5V, B0 or B1 = 4.5V, 1V 5.5 ±10 Max nA IA(OFF) Switch OFF Leakage Current on A A = 1V, 4.5V, B0 or B1 = 4.5V, 1V 5.5 ±20 Max nA IA(ON) Switch ON Leakage Current on A A = 1V, 4.5V, B0 or B1 = 1V, 4.5V or Floating 5.5 ±20 Max nA Symbol Parameter Conditions INO(OFF), INC(OFF) Switch OFF Leakage Current on B0, B1 IA(OFF) www.3peak.com 8 / 15 Rev.B.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch Typical Performance Characteristics VCC = 5V, unless otherwise specified. 1.4 2.5 1.2 2 0.8 RON(Ω) RON(Ω) 1 0.6 B0_-40C B0_25C B0_85C B0_125C 0.4 0.2 B1_-40C B1_25C B1_85C B1_125C 1.5 1 B0_-40C B0_25C B0_85C B0_125C 0.5 0 0 0 1 2 3 4 5 0 0.5 1 VIN(V) 2 2.5 3 Figure 2. RON, VCC = 2.7V, Temp = -40, 25, 85, 125°C 0 -10 -10 -20 -20 -30 -30 Crosstalk(dB) 0 -40 -50 -60 -40 -50 -60 -70 -70 -80 -80 -90 -90 -100 10K 1.5 VIN(V) Figure 1. RON, VCC = 4.5V, Temp = -40, 25, 85,125°C Off Isolation(dB) B1_-40C B1_25C B1_85C B1_125C 100K 1M Frequency(Hz) 10M -100 10K 100K 1M 10M Frequency(dB) Figure 3. Off-Isolation, VCC = 4.5V Figure 4. Crosstalk, VCC = 4.5V 0 -3 Gain(dB) -6 -9 -12 -15 -18 -21 -24 100K 1M 10M 100M Frequency(Hz) Figure 5. Bandwidth, VCC = 4.5V www.3peak.com 9 / 15 Rev.B.0 TPW4157 Low Voltage 1Ω SPDT Analog Switch Test Circuit and Waveforms tR
TPW4157-TR 价格&库存
很抱歉,暂时无法提供与“TPW4157-TR”相匹配的价格&库存,您可以联系我们找货
TPW4157-TR
  • 1+5.747881+0.74298
  • 10+4.0822810+0.52768
  • 25+3.6611225+0.47324
  • 100+3.19659100+0.41320
  • 250+2.97535250+0.38460
  • 500+2.84176500+0.36733
  • 1000+2.731761000+0.35311
库存:2949
TPW4157-TR
  • 1+3.47168
  • 200+2.38944
  • 1500+2.17664
  • 3000+2.03072
库存:2955
TPW4157-TR
    • 10+0.50600
    库存:286
    TPW4157-TR
    • 3000+2.721253000+0.35175
    库存:2949
    TPW4157-TR
    • 1+3.31725
    • 30+3.21358
    • 100+3.00625
    • 500+2.79893
    • 1000+2.69526
    • 2000+2.59160
    库存:100
