SPD8811B
SPD8811B
http//:www.sh-willsemi.com
1-Line,Bi-directional, Thyristor Surge Suppressors
Descriptions
The SPD8811B is a bi-directional TSS (Thyristor
Surge
Suppressors)
which
can
provide
ESD
protection for IC. It is specifically designed to protect
telecom equipments from damaging overvoltage
transients.
The SPD8811B is used to enable equipments to meet
SMB (DO-214AA)
various regulatory requirements including, ITU-T K.20,
K.21 and IEC 61000-4-5
The SPD8811B is available in SMB package.
Standard products are Pb-free and Halogen-free.
Features
Peak off-state voltage: ±58V Max
Excellent capability of absorbing transient surge
Quick response to surge voltage
Eliminate voltage overshoot caused by fast-rising
Schematic Diagram
transients
Low leakage current:
Solid-state silicon technology, non degenerative
8811B
Applications
Audio/Video line
Network and telecom
Data lines and security systems
Serial ports
BNC interface
DVR
AAYW
AA
= Device code
Y
= Year code
W
= Week code
Marking (Top View)
Order information
Will Semiconductor Ltd.
1
Device
Package
Shipping
SPD8811B-2/TR
SMB
3000/Tape&Reel
Revision 1.4, 2017/11/16
SPD8811B
Absolute maximum ratings
Parameter
Junction temperature
Operating temperature
Symbol
Rating
TJ
-40~150
o
-40~125
o
-55~150
o
TL
260
o
RθJA
90
TOP
Storage temperature
TSTG
Lead temperature
Junction to ambient thermal resistance
Unit
C
C
C
C
o
C/W
Electrical characteristics (TA=25 oC, unless otherwise noted)
1)
VDRM
IDRM
VS
VBR
V
μA
V
V
Max.
Max.
Min.
1
77
60
Part Number
SPD8811B
58
2)
IS
IH
VT
IT
CO
mA
mA
V
A
pF
Max.
Max.
150
4
800
Typ.
2.2
50
Notes:
1)
VBR is measured at IBR=1mA.
2)
Off-state capacitance is measured at f = 1MHz, VDC = 2V.
Surge Ratings
Part Number
SPD8811B
8/20μs
1)
1.2/50μs
400 A
2)
5/320μs
1)
10/700μs
2)
2/10μs
1)
2/10μs
2)
6000 V
500 A
Notes:
1)
Current waveform.
2)
Voltage waveform.
2
SPD8811B
o
IPP - Peak Pulse Current - %IPP
Typical characteristics (TA=25 C, unless otherwise noted)
I
IDRM
Peak off-state current
VS
Switching voltage
IS
Switching current
IH
Holding current
VT
On-state voltage
IT
On-state current
Peak Value
100
VDRM Peak off-state voltage
IT
IS
IH
IDRM
VT
VDRM
VS V
tr = rise time to peak value
td = decay time to half value
Waveform = tr × td
Half Value
50
Definitions of electrical characteristics
td
tr
t-Time (μs)
Peak pulse current waveform
10
2.00
1.75
6
Ratio of IH/IH(TC=25℃)
Percent of VS Change - %
8
4
2
25℃
1.25
25℃
1.00
0.75
0.50
-4
-6
1.50
-25
50
75
100
125
0.25
150
Junction Temperature(TJ) - ℃
50
75
100
125
150
Case Temperature(TC) - ℃
Normalized VS Change vs. Junction Temperature
-25
Normalized Holding Current vs. Case Temperature
3
SPD8811B
Package outline dimensions
SMB
Symbol
Dimensions in millimeter
Min.
Typ.
Max.
A
4.30
4.50
4.70
B
3.30
3.50
3.70
C
2.00
2.15
2.30
D
5.05
5.30
5.55
E
0.10
0.20
0.30
F
0.95
1.25
1.55
G
0.20 Max.
H
2.10
2.30
2.50
I
1.85
2.00
2.15
Recommend land pattern (Unit: mm)
Notes:
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
4
很抱歉,暂时无法提供与“SPD8811B-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.50164
- 50+1.18044
- 150+1.04285
- 500+0.87113
- 3000+0.79467
- 6000+0.74877
