P4200SB-MS
P4200SB-MS
    MSKSEMI(美森科)
    SMB(DO-214AA)
    ESD TVS TSS MOV GDT PLED
P4200SB-MS 数据手册
www.msksemi.com P4200SB-MS Semiconductor Compiance Features Low capatcitance Cannot be damaged by voltage Will not fatigue Eliminate voltage overshoot Glass passivated junction Halogen free and RoHS compliant Mechanical Data CASE: SMB(DO-214AA) Molded Plastic UL Flammability Classification Rating 94V0 Mounting Position:Any SMB Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Peak Pulse Voltage Symbol VPP Value 4000 Units V Remarks 10/700us Peak Pulse Current IPP IPK ITSM 80 A 10/1000us 250 25 A A 8/20us 60Hz di/dt RθJL 500 A/us 20 Typical Thermal Resistance Junction to Ambient Operating Temperature Range RθJA ℃/W ℃/W TJ 100 -40 to 150 Storage Temperature Range TSTG -55 to 150 ℃ Peak Pulse Current Peak One-cycle Surge Current Rate of Rise of Current Typical Thermal Resistance Junction to Lead ℃ Electrical Characteristics ( Ratings at 25 ℃ ambient temperature unless otherwise specified). P/N P4200SB-MS Mark P42B XXXX VS @100KV/S IS_LMT V T @ IT IT ID @ V D VD CO@1MHz,2VDC IH V MAX mA V MAX A uA MAX V pF TYP mA MAX 520 800 4 2.2 5 400 36 100 www.msksemi.com P4200SB-MS Semiconductor Compiance Ratings and Characteristic Curves ( Ratings at 25℃ ambient temperature unless otherwise specified). 16 2 14 1.8 10 Ratio of IH / IH (TC=25℃) Percent of VS Change (%) 12 8 6 4 2 0 25, 0 -2 -4 -40 -20 0 1 25, 1 0.8 -40 -20 0 20 40 60 80 100 120 140 160 TC - Case Temperature (℃) Fig.1 - Peak Pulse Current Rating Fig.2 - Normalized DC Holding Current vs. Case Temperature 100 Current (A) VT,IT 50 IH VS,IS VD,ID 0 tr td t - Time (us) 10000 100 10 1 1 10 100 td - Pulse Width (us) Fig.5 - Peak Pulse Current Rating Fig.4 - VI Curve 100 1000 0.1 VB Voltage (V) Fig.3 - tr/td us Pulse Waveform 1000 CO - Typical Off-state Capacitance (pF) IPP - Peak Pulse Current, % IPK 1.2 0.4 20 40 60 80 100 120 140 160 TJ - Junction Temperature (℃) IPP - Peak Pulse Current (A) 1.4 0.6 -6 -8 1.6 80 60 40 20 0 0 100 200 300 VB - Breakdown Voltage (V) 400 500 Fig.6 - Typical Off-state Capacitance www.msksemi.com P4200SB-MS Semiconductor Compiance PACKAGE MECHANICAL DATA A Dimensions B C Ref. H F G D E L J K Millimeters Min. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 L 0.270 2.60 K DO-214AA (SMB) Inches 2.40 0.100 0.090 REEL SPECIFICATION P/N P4200SB-MS PKG QTY SMB 3000 www.msksemi.com P4200SB-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
P4200SB-MS 价格&库存
很抱歉,暂时无法提供与“P4200SB-MS”相匹配的价格&库存,您可以联系我们找货
