BEP3100SC
BEP3100SC
    BORN(伯恩半导体)
    SMB(DO-214AA)
    晶闸管浪涌抑制器
BEP3100SC 数据手册
BEPxxxxSC Thyristor Surge Suppressor HF LF RoHS BEPxxxxSC »Features ■ Silicon technology Cannot be damaged by voltage Low capacitance Eliminate voltage overshoot Epoxy resin package ■ Will not fatigue ■ Complies with following standards: - GR1089 - ITU K.20, K.21 and K.45 - IEC 60950 - UL 60950 - TIA-968 RoHS Compliant ■ ■ ■ ■ ■ »Mechanical ■ ■ ■ ■ ■ SMB (DO-214AA) »Applications Characteristics Package: SMB (3.67×5.4×2.3mm) Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 1 per J-STD-020 ■ ■ ■ »Marking Information COMMERCIAL SYSTEMS INDUSTRIAL & INSTRUMENTATION COMMUNICATIONS »Pin Configuration xxxC YYWW xxxC = Type Code YYWW = Date Code »Summary of Packing Options Package SMB Revision: 2018 Packing Description Packing Quantity Industry Standard Tape/Reel,13" reel 3000 EIA-481-1 Tape/Reel,7" reel 500 EIA-481-1 www.born-tw.com 1/6 BEPxxxxSC »Absolute Maximum Ratings Parameter Symbol Value Units Remarks Peak Pulse Voltage VPP 6000 V 10/700us Peak Pulse Current IPP 100 A 10/1000us Peak Pulse Current IPK 400 A 8/20us Peak One-cycle Surge Current ITSM 30 A 60Hz Rate of Rise of Current di/dt 500 A/us Typical Thermal Resistance Junction to Lead RθJL 20 ℃/W Typical Thermal Resistance Junction to Ambient RθJA 100 ℃/W TJ -40 to 150 ℃ TSTG -55 to 150 ℃ Operating Temperature Range Storage Temperature Range »Electrical Characteristics (TA=25°C unless otherwise noted) MIN Part Number Marking TYP IS_LMT VT IT ID VD CO V mA V @ IT A uA @ VD V 100KV/S pF 1MHz,2VDC MIN MAX MAX mA MAX TYP BEP0080SC E-8C 40 25 500 4 2.2 5 6 105 BEP0220SC P02C 40 30 500 4 2.2 5 15 105 BEP0300SC P03C 40 40 500 4 2.2 5 25 100 BEP0640SC CP06C 120 77 800 4 2.2 5 58 95 BEP0720SC P07C 120 88 800 4 2.2 5 65 95 BEP0900SC P09C 120 98 800 4 2.2 5 75 95 BEP1100SC P11C 120 130 800 4 2.2 5 90 90 BEP1300SC P13C 120 160 800 4 2.2 5 120 90 BEP1500SC P15C 120 180 800 4 2.2 5 140 85 BEP1800SC P18C 120 220 800 4 2.2 5 170 80 BEP2300SC P23C 120 260 800 4 2.2 5 190 75 BEP2600SC P26C 120 300 800 4 2.2 5 220 70 BEP3100SC P31C 120 350 800 4 2.2 5 275 65 BEP3500SC P35C 120 400 800 4 2.2 5 320 60 BEP4500SC P42C 120 550 800 4 2.2 5 400 45 Revision: 2018 MAX VS IH www.born-tw.com 2/6 BEPxxxxSC »Rating And Characteristic Curves (TA=25°C unless otherwise noted) 16 2 14 1.8 10 Ratio of IH / IH (TC=25℃) Percent of VS Change (%) 12 8 6 4 2 0 25, 0 -2 -4 1.6 1.4 1.2 1 25, 1 0.8 0.6 -6 -8 0.4 -40 -20 0 20 40 60 80 100 120 140 160 -40 -20 0 TJ - Junction Temperature (℃) 60 80 100 120 140 160 Fig.2 - Normalized DC Holding Current vs. Case Temperature 100 Current (A) VT,IT 50 IH VS,IS VD,ID VB 0 tr td t - Time (us) Voltage (V) Fig.3 - tr/td us Pulse Waveform Fig.4 - VI Curve 10000 100 1000 100 10 1 0.1 1 10 100 1000 CO - Typical Off-state Capacitance (pF) IPP - Peak Pulse Current (A) 40 TC - Case Temperature (℃) Fig.1 - Peak Pulse Current Rating IPP - Peak Pulse Current, % IPK 20 td - Pulse Width (us) 60 40 20 0 0 100 200 300 400 500 VB - Breakdown Voltage (V) Fig.5 - Peak Pulse Current Rating Revision: 2018 80 Fig.6 - Typical Off-state Capacitance www.born-tw.com 3/6 BEPxxxxSC »Package Dimensions B D C A F H L G Z X Y SMB Dimension Revision: 2018 Inches Millimeters MIN NOM MAX MIN NOM MAX A 0.134 0.144 0.155 3.4 3.67 3.94 B 0.205 0.213 0.22 5.21 5.4 5.59 C 0.075 0.079 0.083 1.9 2 2.1 D 0.169 0.185 4.3 4.7 L 0.03 0.06 0.76 1.52 F 0.006 0.012 0.152 0.305 G - 0.008 - 0.203 H 0.085 0.096 2.15 0.091 2.3 X 0.11 2.8 Y 0.079 2 Z 0.079 2 www.born-tw.com 2.45 4/6 BEPxxxxSC »Soldering Parameters tp Temperature (T) TP Ramp-up TL tL Critical Zone TL to TP Ts(max) Ramp-down Ts(min) ts Preheat 25℃ t 25℃ to Peak Time (t) Reflow Condition Pre Heat Lead-free assembly - Temperature Min (Ts(min)) 150°C - Temperature Max (Ts(max)) 200°C - Time (min to max) (ts) Average ramp up rate (Liquidus Temp (TL) to peak) 3°C/second max TS(max) to TL - Ramp-up Rate 3°C/second max Reflow - Temperature (TL) (Liquidus) - Time (tL) 217°C 60 – 150 secs 260+0/-5 °C Peak Temperature (TP) Time within 5°C of actual peak Temperature (tp) 20 – 40 secs Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (t) 8 minutes Max. Do not exceed Revision: 2018 60 – 180 secs 260°C www.born-tw.com 5/6 BEPxxxxSC »Tape and Reel Specification Carrier tape P0 W 0.059(1.5) DIA Cover tape P D1 or D2 Dimensions are in inches(millimeters) 0.80 (20.2) Arbor Hole Dia. Direction of Feed W1 Dimension P P0 W W1 D1 D2 Revision: 2018 Inches MIN NOM 0.315 0.157 0.472 0.492 7 13 Millimeters MAX www.born-tw.com MIN NOM 8 4 12 12.5 177.8 330.2 MAX 6/6
BEP3100SC 价格&库存
很抱歉,暂时无法提供与“BEP3100SC”相匹配的价格&库存,您可以联系我们找货
BEP3100SC
  • 5+0.79704
  • 50+0.63634
  • 150+0.55599
  • 500+0.49572
  • 3000+0.44756
  • 6000+0.42347
库存:4315
BEP3100SC
  • 1+0.39820
  • 3000+0.37180
库存:4142
