P0300SB
P0300SB
    SEMBO(深波)
    SMB(DO-214AA)
    P0300SB
P0300SB 数据手册
TSS P0300SB Features      Fails short circuit when surged in excess of ratings Low voltage overshoot High repetitive surge current capability Low on‐state voltage P0080SA~P3500SA are also available in SMA package DO-214AA (SMB) Main Applications     Customer Premises Equipment (CPE) Modems, Line cards, DSL, ISDN, T‐1/E‐1 Data lines and security systems Fax machines, Telephones etc. Thermal Considerations Type Number Symbol Operating Junction Storage Temperature Range Units TJ, TG -40 to + 150 °C TS -65 to + 150 °C RθJA 90 °C/W Storage Temperature Range Thermal Resistance: Junction to Ambient Value Package Dimensions DO-214AA/SMB F B1 E B A C1 D C A B B1 C C1 D E F Min 4.06 3.30 1.95 5.21 0.76 - 2.13 0.152 Max Min Max 4.57 0.16 0.18 3.94 0.13 0.155 2.20 0.077 0.086 5.59 0.205 0.22 1.52 0.03 0.06 0.203 0.008 2.44 0.305 0.084 0.096 0.006 0.012 Dim Millimeters (mm) Inches (inch) http://www.sembo.com.cn TSS P0300SB Ordering Information P 0300 S B B: I PP=100A SMB Voltage Electrical Characteristics (T Ambient=25ºC unless noted otherwise) Part VDRM VS IH IS IT VT CO Number V min V max mA min mA max A max V max pF min pF max P0300SB 25 40 50 800 2.2 4 15 140 Surge Ratings IPP Series B IPP 2x10μS 8x20μS Amps Amps 250 250 IPP 10x160μS IPP 10x560μS IPP 10x1000μS Amps Amps Amps 150 100 75 ITSM 50/60Hz Amps di/dt Amps/μS 25 500 Note: 1. Peak pulse current rating (IPP) is non‐repetitive and guaranteed for the life of the product. 2. IPP ratings applicable over temperature range of ‐40℃ to +85℃ 3. The device must initially be in thermal equilibrium with ‐40℃< TJ
P0300SB 价格&库存
很抱歉,暂时无法提供与“P0300SB”相匹配的价格&库存,您可以联系我们找货
