TSS-SB
Thyristor Surge Suppresser
DESCRIPTION
DO - 214AA / SMB Thyristor solid state protection thyristor protect telecommunications equipment such as modems ,
line cards , fax machines , and other CPE . This Series devices are used to enable equipment to meet various regulatory requirements including GR1089 , ITUK . 20 , K . 21 and K . 45 , IEC 60950 , and TIA - 968 ( formerly known as FCC Part 68 ).
FEATURES
DO-214AA PACKAGE
> Excellent capability of absorbing transient surge
> Quick response to surge voltage
> Eliminates overvoltage caused by fast rising transients
> Solid-state silicon technology, non degenerative
2
1
APPLICATIONS
> Audio/Video line
> Network and telecom
> Data lines and security systems
> Serial ports
SCHEMATIC SYMBOL
PART NUMBER AND ELECTRICAL PARAMETER @ T=25℃ RH = 45%-75%
PART
NUMBER
V DRM
V
Min.
I DRM
uA
Max.
VS
V
Max.
IS
mA
VT
V
Max.
IT
A
IH
mA
CO
pF
Max.
P0080SB
6
5
25
800
4
2.2
≥50
80
P0300SB
25
5
40
800
4
2.2
≥50
80
P0640SB
58
5
77
800
4
2.2
≥150
80
P1800SB
170
5
220
800
4
2.2
≥150
80
P2300SB
190
5
260
800
4
2.2
≥150
80
P2600SB
220
5
300
800
4
2.2
≥150
80
P3100SB
275
5
350
800
4
2.2
≥150
40
P3500SB
320
5
400
800
4
2.2
≥150
40
P4200SB
390
5
500
800
4
2.2
≤50
70
1、Vs is measured at 100KV/S
2、Off-state capacitance is measured in V DC =2V,V RMS =1V,F=1MHz
3、All measurements are made at an ambient temperature of 25℃
SURGE RATINGS
Series
IPP
2x10us
(A)
IPP
8x20us
(A)
IPP
10x560us
(A)
IPP
10x1000us
(A)
VPP
10x700us
(V)
I TSM
60Hz
(A)
d i /d t
(A/us)
P0080SB
Thru
P4200SB
300
300
100
80
4000
32
500
Document Number: 151003
Page 1
www.semiware.com.cn
TSS-SB
THERMAL CONSIDERATIONS
Symbol
Parameter
Value
Unit
TJ
Operang Juncon Temperature
-40 to +150
TS
Storage Temperature Range
-40 to +150
RθJA
Juncon to Ambient on printed circuit
90
℃/W
TYPICAL DEVICE CHARACTERISTICS
IPP– Peak Pulse Current – %IPP
+I
IT
IS
IH
I DRM
-V
+V
V DRM
VT
VS
Peak
Value
100
tr = rise me to peak value
td = decay me to half value
Wave form = t r x t d
50
Half Value
td
tr
t – Time (μs)
-I
V-I Characteristics
tr x td Pulse Waveform
2.0
14
1.8
8
6
25 °C
4
2
IH
I H (Tc=25 °C)
10
1.6
Rao of
Percent of V S Change – %
12
1.0
1.4
25 °C
1.2
0.8
0.6
-6
0.4
-40
-8
-40 -20
80 100 120 140 16 0
60
80 1 00 120 1 40 160
Case Temperature (T C ) - °C
Juncon Temperature (TJ) – °C
Normalized VS Change vs. Junction Temperature
-20
Normalized DC Holding Current vs. Case Temperature
Page 2
www.semiware.com.cn
TSS-SB
ENVIRONMENTAL CHARACTERISTICS
Tesng Items
Technical Standards
High Temperature Reverse Bias Test
Temperature:150±3℃, Bias=80%V DRM ;Time:168H
High Temperature Life Test
Temperature:150℃ ;Time:168H
High-Low Temperature Cycle Test
Temperature:From -40℃ to 150℃ ;Dwell Time:30min,10-100 Cycles
High Temperature&High Humidity Test
Temperature:85℃.Humidity:85%; Time:168H
Pressure Cooker Test
Temperature:121℃, 2 atm.Humidity:100%; Time:24H To 168H
Resistance Of Soldering Heat
Temperature:260±5℃;Time Of Dip Soldering:10s,3 Times
PRODUCT DIMENSIONS
SMB PACKAGE DIMENSIONS
A
C
B
H
D
E
A
1.96
B
4.35
C
3.30
D
2.20
E
2.20
0.077
0.087
4.85
0.171
0.191
3.94
0130
0.155
2.50
0.087
0.098
0.76
1.52
0.030
0.060
F
0.02
0.20
0.001
0.008
G
5.08
5.59
0.200
0.220
H
0.15
0.30
0.006
0.012
NOTES:
F
G
1.Dimensions are exclusive of mold flash and metal burrs
2.Cathode Band is only applicable to the unidireconal package
RECOMMENDED PAD LAYOUT DIMENSIONS
E
A
B
C
D
A
2.20
0.087
B
1.45
0.057
C
2.55
0.100
0.057
1.45
D
E
Page 3
www.semiware.com.cn
TSS-SB
SOLDERING PARAMETERS
Reflow Condion
Pre Heat
Lead–free assembly
Temperature Min (Ts(min))
150°C
Temperature Max (Ts(max)
200°C
Time (min to max) (ts)
60 – 180 secs
Average ramp up rate (Liquidus Temp (T L ) to peak
3°C/second max
T S (max)to T L - Ramp-up Rate
3°C/second max
Temperature (T L ) (Liquidus)
217°C
60 – 150 seconds
Reflow
Peak Temperature (T P )
260°C
Time within 5°C of actual peak Temperature (tp)
20 – 40 seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (T P )
8 minutes Max.
Do not exceed
260°C
TAPE AND REEL SPECIFICATION
10 Pitches Cumulave
Tolerance on tape ± 0.2
P0
D
t
E
F
W
K0
B0
A0
P
User Direcon of Feed
SPECIFICATIONS
REEL DIA.
TAPE
WIDTH
330mm (13”)
12mm
A0
B0
K0
D
E
3.79 ± 0.15 5.72 ± 0.15 2.46 ± 0.30 1.55 ± 0.05 1.75 ± 0.10
F
W
P0
P
tmax
5.5 ± 0.05 12.00 ± 0.30 4.00 ± 0.10 8.00 ± 0.10 0.25 ± 0.10
NOTES
1. Dimensions are in millimeters.
2. Surface mount product is taped and reeled in accordance with EIA-481.
3. Suffix - T = 13” Reel - 3,000 pieces per 12mm tape.
ORDERING INFORMATION
Part Number
Component Package
QTY/Reel
Reel Size
PxxxxSB
DO-214AA
3000PCS
13"
Page 4
www.semiware.com.cn
TSS-SB
CONTACT US
Headquarters
A Building Caohejing I&E Park Pujiang Minhang Shanghai
China
Hotline
400-021-5756
Web
http://www.semiware.com.cn
By Telephone
Sales: 86-21-3463-7345
Customer Service: 86-21-3463-7172-8810/8826
Technical Support: 86-21-3463-7173-8811
By Email
Sales: sales03@semiware.com.cn
Customer Service: sales17@semiware.com.cn
Technical Support: fae03@semiware.com.cn
By Fax
General: 86-21-3965-0654
Sales:86-21-3463-7458
COPYRIGHT ©Semiware 2009 - This literature is subject to all applicable copyright laws and is not for resale in any manner.
SPECIFICATIONS: Semiware reserves the right to change the electrical and or mechanical characteristics described herein without notice.
DESIGN CHANGES : Semiware reserves the right to discontinue product lines without notice and that the final judgement concerning selection and specifications is the buyer’s and that in furnishing engineering and technical assistance. Semiware assumes no responsibility with respect to the selection or specifications of such products.Semiware makes no warranty,representation or guarantee regarding the suitability of its products for any particular purpose, nor does Semiware assume any liability arising out of the application or use of any product or circuit and specifically disclaims any and all liability without limitation special,consequential or incidental damages.
LIFE SUPPORT POLICY: Semiware products are not authorized for use in life support systems without written consent from the factory.
Page 5
www.semiware.com.cn
很抱歉,暂时无法提供与“P2600SB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.54346
- 50+0.43460
- 150+0.38016
- 500+0.33934
- 3000+0.30672
- 6000+0.29031
