LPA0D05529U84L
LPA0D05529U84L
    LUCKI(蓝晶芯微)
    HC49S
    5.5296MHZ ±20PPM 20PF
LPA0D05529U84L 数据手册
LUCKI CM ELECTRONICS Co.,Ltd 规格书 SPECIFICATION Customer : Part Number: LK Part No.: LPA0D05529U84L Holder : HC-49S Frequency: 5.5296MHz/49S/20PF/20PPM Manufacturer: Lucki Electronics Date: 2023/05/22 Prepared Checked Approved Zhao Qian Zhang Dongwei Zhang Bin (For Customer Use) Acceptable Professional manufacturer of quartz crystal Http://www.lucki.com.cn LUCKI CM ELECTRONICS Co.,Ltd Revision History No. Revised Date Change Content Professional manufacturer of quartz crystal Approved Http://www.lucki.com.cn Remark LUCKI CM ELECTRONICS Co.,Ltd 目录 TABLE OF CONTENT 规格内容 Specification content 页码 PAGE CRYSTAL ELECTRICAL SPECIFICATION · · · · · · · · · 4 · · MARKING & DIMENSIONS · · · · · · · · · · · · · · · · · ·5 · PACKING · · · · · · · · · · · · · · · · · · · · · · · · · · 6 · · · · RELIABILITY SPECIFIXATIONS · · · · · · · · · · · · · · ·7~8 · · · Professional manufacturer of quartz crystal Http://www.lucki.com.cn PAGE: CRYSTAL ELECTRICAL SPECIFICATION 1 HC-49S 2 Holder Type Mode of Vibration 3 Oscillation Mode Fundamental 4 Nominal Frequency 5.5296 MHz 5 Load Capacitance 20 pf 6 Frequency Tolerance(25℃) ±20 ppm 7 Effective Series Resistance 80 ohms Max 8 Shunt Capacitance(C0) 7.0pf Max 9 Motional Capcitance(C1) N/A AT CUT 10 Drive Level 100 uW 11 Operation Temperature Range - 40℃~+85℃ 12 Stabibity Over Temperature Range ±30 ppm 13 Insulation Resistance 500 Mohms Min.at DC 100V 14 Ration of Holder to Motional(C0/C1) N/A 15 Storage Temperature -55℃~﹢125℃ 16 Aging ±3 ppm/year Professional manufacturer of quartz crystal (related to 25℃) Http://www.lucki.com.cn 4 PAGE: Marking specification DIMENSIONS(Unit:mm) Professional manufacturer of quartz crystal Http://www.lucki.com.cn 5 PAGE: 6 PACKING 200pcs 装一袋 5袋装一小盒,盒内放置气泡膜 L L H H W W 装箱数量 L(长) 尺寸 W(宽) H(高) 内盒 200 mm 150 mm 45 mm 10K外箱 325 mm 245 mm 240 mm 20K外箱 425 mm 325 mm 240 mm Professional manufacturer of quartz crystal Http://www.lucki.com.cn PAGE: 7 RELIABILITY SPECIFIXATIONS No. Test Item Test Methods 1 Mechanical Endurance 机械特性 Provided that measurement shall be carried out after letting it alone in the room temperature for 1 hour。 试验产品应在室温下放置1小时后方可进行以下试验。 1.1 SHOCK 抗击测试 Electrical characteristics shall be satisfied after dropping three time from the height of 75cm onto Three。 产品从75cm高度自由落下到硬木板3次电气参数仍符合要求。 VIBRATION 抗振测试 Electrical characteristics shall be satisfied after supplying following Vibration。 电气性能应满足以下的振动要求。 (1) VIBRATION FREQUENCY 振动频率 10—55Hz (2) REPEATED PERIOD 周 期 1—2min (3) FULL CYCLE 全 振 幅 1.5mm P—P (4) DIRECTION 振动方向 X.Y.Z 1.2 1.3 STRENGTH OF TERMINALS/LEAD—WIRES 引脚与基座底部的强度测试 1.3.1 PULLING 可靠性测试 1.3.2 BENDING 弯曲度测试 a) Body of specimen shall be fixed, and 900g of tension weight shall be supplied gradually to axial direction of terminals/leadwires for 30 sec .产品应固定在900g的拉力的情况下逐渐延基座 底部/引线脚中轴方向拉30秒钟。 b)After above test a), there is no observation of any visual damages on the specimen. 经过a)的测试,产品应没有任何可以目测到的损坏。 a)Body of specimen shall be fixed, and 90degree bending shall be given, being supplied 225g stension weight .After that, terminals/lead-wires shall be straightened gradually .Then the same bending and straightening shall be supplied to the opposite direction in the same axial . (Refer to Fig-1) 产品固定后,以90o的弯曲并供以225g的拉力,然后沿同一轴线 并与相反的方向90 o的弯曲及伸直。(如图1所示) b)After above test a), there is no observation of any visual damages on the specimen . 通过a)测试后,晶体上应没有任何可以目测到的损坏。 工具 约 R 0.75 端子 拉力 约3 Professional manufacturer of quartz crystal Http://www.lucki.com.cn (mm) PAGE: 8 RELIABILITY SPECIFIXATIONS No. Test Item Test Methods SEALING TIGHTNESS 绝缘性测试 Absolute ethyl alcohol inflating:0.5MPa,for 20min,Insulation resistance:≥500MΩ (100V DC) 酒精加压(压力0.5MPa)20分钟,100V 直流电压下绝缘电阻≥ 500MΩ SOLDERING DIP 浸锡测试 Terminals/lead-wires of specimen shall be dipped into solder melted tank at +230℃—±5℃for 3sec . Dipping depth shall be 2mm from the bottom of specimens body .(After applying ROSIN flux) Soldering portion shall be covered in over 95% of terminals/lead-wires dipped .将晶体引线脚置于+260℃—±5℃的 锡桶中3分钟,基座底部离锡表面2mm,(加上松香焊剂后)引 线脚的沾锡率为95%以上。 1.6 SOLDER HEATING 沾锡耐热性测试 Terminals/lead-wires of specimen shall be dipped into solder melted tank at +350℃—±10℃ for 3 sec Electrical characteristics shall be satisfied after dipping depth shall be 2mm from edge of terminals/lead-wires . 将已沾锡的产品的引线脚置于+350℃—±10℃的锡桶中3-4秒钟后 基座底部离锡表面2mm,电气性能仍符合要求 2 ENVIRONMENTAL ENDURANCE 环境特性 Provided that measurement shall be carried out after letting it alone in the room temperature for 1 hour . 必须将试验产品在室温下放置1小时后方可进行测试. 2.1 HUMIDITY 耐湿测试 Electrical characteristics shall be satisfied after letting it alone at 60℃—±2℃ in humidity of 90—95% for 250 hours . 试验产品在温度为60℃—±2℃,相对温度90—95%的试验箱内放 置250小时后电气性能仍符合要求 2.2 STORAGE IN LOW TEMPERATURE 低温储存测试 Electrical characteristics shall be satisfied after letting it alone at -30℃—±2℃ for 250 hours . 试验产品在温度为-30℃—±2℃的试验箱中放置250小时后电气性 能仍符合要求。 2.3 STORAGE IN HIGH TEMPERATURE 高温储存测试 Electrical characteristics shall be satisfied after letting it alone at +85℃—±2℃ for 250 hours . 试验产品在温度为+85℃—±2℃的试验箱中放置250小时后电气性 能仍符合要求。 1.4 1.5 Electrical characteristics shall be satisfied after supplying the following temperature cycle (3cycles) .Temperature shift from low to high, high to low shall be done in 1℃/min (Refer to Fig-2) 电气性能应满足以下温度周期要求(3个周期)温度变换从低到 高,从高到低变化量为1℃/分。(如图2所示) 2.4 TEMPERATRRE CYCLE 温度变换测试 ++2255℃ ℃± ± 55℃ ℃ ++ 55 ++8855 - 2- 2 - -3300 ++ 33 - 5- 5 ℃ ℃ ℃ ℃ 11 CCYYCCLLEE Professional manufacturer of quartz crystal Http://www.lucki.com.cn
LPA0D05529U84L 价格&库存
很抱歉,暂时无法提供与“LPA0D05529U84L”相匹配的价格&库存,您可以联系我们找货
LPA0D05529U84L
    • 5+0.56916
    • 50+0.44993
    • 200+0.39032
    • 400+0.34560
    库存:627
