01.X.SA.120LQPJ2016000000
    CREC(晶宝)
    HC49S
    无源晶振 16MHz ±30ppm 20pF -10℃~+60℃
01.X.SA.120LQPJ2016000000 数据手册
Chengdu Kingbri Frequency Technology Co., Ltd TYPICAL APPLICATION - Bluetooth ,Automotive,Wireless - Computers, Modems, Communications - Set-top Box, DECT/WD DIMENSIONS (mm) ELECTRICAL SPECIFICATION PARAMETERS Nominal Frequency Mode of vibration Frequency Tolerance Frequency Stability Load Capacitance Shunt Capacitance Equivalent Series Resistance Drive Level Aging (First Year) Insulation Resistan XSA-49S TYP MAX 32 AT Fundamental ±5ppm~±50ppm Table 2 6pF~100pF or specify 7 Table 1 100 500 -5 5 500 - MIN 3 UNITS CONDITIONS MHz @+25℃±3℃ Ref 25℃±3℃ @+25℃±3℃ @DC100V ppm ppm pF pF Ω uW ppm MΩ EQUIVALENT SERIES RESISTANCE (Table 1) Frequency Range MODE E.S.R(Ω) 3MHz≤F0<5MHz 5MHz≤F0≤9MHz 9MHz<F0<12MHz 12MHz≤F0≤16MHz 16MHz<F0<25MHz 25Hz≤F0≤32MHz AT Fundamental AT Fundamental AT Fundamental AT Fundamental AT Fundamental AT Fundamental 150 80 60 40 30 25 FREQ. STABILITY vs. TEMP. RANGE(Table 2) ppm Temp.℃ ±5 ±10 ±20 ○ ○ ○ 0~70 ○ -20~70 ○ X ○ -40~85 X X ○: Available △:Conditional X: Not available Other special specifications are designed to customer's requirements,More details available XME
01.X.SA.120LQPJ2016000000 价格&库存
很抱歉,暂时无法提供与“01.X.SA.120LQPJ2016000000”相匹配的价格&库存,您可以联系我们找货
