HY24M49SOB2T02
HY24M49SOB2T02
    HYJG(惠源晶工)
    HC49S
    无源晶振 24MHz ±20ppm 20pF 30Ω -40℃~+85℃
HY24M49SOB2T02 数据手册
中山惠源晶工电子科技有限公司 Zhongshan Huiyuan Crystal Electronic Technology Co., Ltd GENERAL SPECIFICATIONS(电气特性) 1. Series model: (系列号) 2.Normal Frequency: (标称频率) 3.Oscillation Mode: (振动模式) 4.Load Capacitance(CL): (负载电容) 5.Frequency Tolerance 25±3℃: (频率偏差 25±3℃) 6.Stability Over Temperature Range: (工作温度频率偏差) HC49S-2DIP 3.579545~39.550MHz ■Fundamental □3rd 20PF ±20PPM ±30 PPM 7.Effective Series Resistance: (等效电阻) 3.579545~4.9152MHZ≤120 Ω 5~6.7458MHA≤80 Ω 7.2~8.704MHA≤60 Ω 9.216~11.529475MHA≤40 Ω 12~39.550MHA≤30 Ω 8.Shunt Capacitance(C0): (静态电容) ≤ 5 PF 9. Typical drive level: 100 uW TYP. (激励功率) 10.Operation Temperature Range: -40℃ to +85℃ (工作温度范围) 11.Storage Temperature: -40℃ to +85℃ (存储温度) 12.Insulation Resistance: ≥500 MΩ at DC 100V (绝缘阻抗) 13.Aging: ±3 PPM/Year (老化率) 14.Leak 1×10-7Torr.1/sec Max (检漏) 15.Test circuit S&A 250B Pi-Network Crystal Measurement System (测试仪器) Remark(备注): 晶振最佳储存条件:温度:25±5℃,湿度:
HY24M49SOB2T02 价格&库存
很抱歉,暂时无法提供与“HY24M49SOB2T02”相匹配的价格&库存,您可以联系我们找货
HY24M49SOB2T02
  • 10+0.43168
  • 100+0.34355
  • 400+0.28847
库存:182
