B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China
TEL :+86(0)755-83279247
Fax :+86(0)755-8327-9247
http://www.starwavecorp.com
E-mail :info@starwavecorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
HC-49S
NOMINAL FREQ.
8.000000MHz
STARWAVE P/N
SWXSHACVF0-8.000000
REVISION
A1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) STAR requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by STAR after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
RoHS Compliant
FMT-DOC024
Issue Date: 03.09'06 VER.D
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
HC-49S
NOMINAL FREQ.
8.000000MHz
STARWAVE P/N
SWXSHACVF0-8.000000
REVISION
A1
PE/RD
QA
MFG
21-Jul-23 21-Jul-23 21-Jul-23
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
RoHS Compliant
Issue Date: 03.07'09 VER.D
P/N: SWXSHACVF0-8.000000
Rev
Revise page
A1
N/A
Revise contents
Date
21/07/2023
REVISION:
A1
PAGE: 2
Ref.No.
Reviser
N/A
Shu-Chen Ko
REVISION:
A1
PAGE: 3
CONTENT
SPECIFICATIONS
PAGE
ELECTRICAL SPECIFICATIONS
4
DIMENSIONS
5
MARKING
6
PACKING
7
RELIABILITY SPECIFICATIONS
8
ATTACHMENT(S) (optional)
TESTING DATA
ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
P/N: SWXSHACVF0-8.000000 REVISION: A1
PAGE: 4
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25+/-5oC
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25+/-1oC
Relative humidity
40%~70%
Measure equipment
SAUNDERS 250A/250B CRYSTAL IMPEDANCE METER.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
please refer to marking code page
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
Nominal Frequency
Oscillation Mode
Load Capacitance
Frequency Tolerance (25 oC)
Effective Series Resistance
Shunt Capacitance (C0)
Motional Capacitance (C1)
Drive Level
Operation Temperature Range
Stability Over Temperature Range
Insulation Resistance
Attenuation of Spurious Frequency Amplitude
Ratio of Holder to Motional (C0/1)
Storage Temperature
Aging
RLD2(0.1~500uW)
DLD2(0.1~500uW)
Weight
8.000000 MHz
FUND
20.0 pF
+/- 10 ppm
100 Ohms Max.
7.0 pF Max.
1.9 fF Max.
500 uW Typ.
-40oC ~ +85oC
+/- 30 ppm
(related to 25 oC)
500 MOhms Min. at DC 100V
N/A
N/A
o
o
-40 C ~ +85 C
+/- 3.0 ppm / year.
80 Ohms Max.
60 Ohms Max.
0.52 g +/- 0.05g
DIMENSIONS
A1
PAGE: 5
UNIT:mm
For example :
Marking
STAR
Introduction
Pb Free Product
49S 8.000 MHz
3.8 max.
3.68 max.
3.3+/-0.2
For example :
Pin Connet GND
11.5 Max.
0.43+/-0.125
Marking
Solder Coating
(Sn-Ag-Cu Pb Free Coating)
5.0 Max.
4.88+/- 0.25
A1
PAGE: 6
Packing For Pb Free Parts :
1.INNER BOX:(Unit:mm)
10bagx200pcs
=2000pcs/box
200pcs/bag
PUT IN
PUT
2.LOGO STICKER(CARTON and INNER BOX):(Unit:mm)
150+/-10
190+/-10
A
42+/-10
Label A
G
PUT IN
A
# (1) Put in stuff between space.
(2) Tie Up the Carton with 4 Packthreads.
(3) "G" : Pb-Free Product
REVISION:
A1
PAGE: 7
No. TEST ITEM
1 Drop Test
2 Fine Leak
3 Gross Leak
4 Mechanical Shock
5 Vibration
6 Solderability
Resistance To
7
Soldering Heat
8 Terminal Strength
TEST METHODS
50 cm Height, Fall freely onto firm wood for 3 Times.
Helium Bombing 5Kgf / cm2 for 2 Hours .
125oC FC#40 ,120 Seconds.
Device are shocked to half sine wave ( 1000 G )
three mutually perpendicular axes each 3 times.
Frequency range
10 ~ 55 Hz
Amplitude
10G
Sweep Time
1 minute
Test Time
X,Y,Z Plan,each 2 hrs.
Temperature
235 oC +/- 5 oC
Immersing depth
0.5 mm minimum
Immersion time
5 +/- 0.5 seconds
Flux
Rosin resin methyl
alcohol solvent ( 1 : 4 )
Test Temperature
260 oC +/- 5 oC
Test Time
10 +/- 1 sec.
2.5mm From terminal , bend 90o,3 times.
Total 5 cycles of the following
9 Thermal Shock
temperature cycle
125+/-3 0C
25 0C
-55+/-3 0C
TEST CRITERIA
dF/F
SWXSHACVF0-8.000000 价格&库存
很抱歉,暂时无法提供与“SWXSHACVF0-8.000000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.63947
- 50+0.50987
- 200+0.44507
