SWXSHACVF0-20.000000
    STARWAVE(思大)
    HC-49S-2P
    无源晶振 20MHz ±10ppm 20pF 60Ω -40℃~+85℃
SWXSHACVF0-20.000000 数据手册
B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China TEL :+86(0)755-83279247 Fax :+86(0)755-8327-9247 http://www.starwavecorp.com E-mail :info@starwavecorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : HC-49S NOMINAL FREQ. : 20.000000MHz STARWAVE P/N : SWXSHACVF0-20.000000 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) STAR requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by STAR after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. RoHS Compliant FMT-DOC024 Issue Date: 03.09'06 VER.D B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China TEL :+86(0)755-83279247 Fax :+86(0)755-8327-9247 http://www.starwavecorp.com E-mail :info@starwavecorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : HC-49S NOMINAL FREQ. : 20.000000MHz STARWAVE P/N : SWXSHACVF0-20.000000 REVISION : A1 PE/RD QA MFG 21-Jul-23      21-Jul-23       21-Jul-23    NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant Issue Date: 03.07'09 VER.D P/N: SWXSHACVF0-20.000000 Rev Revise page A1 N/A Revise contents Date 21/07/2023 REVISION: A1 PAGE: 2 Ref.No. Reviser N/A Shu-Chen Ko Issue Date: 03.07'09 VER.D P/N: SWXSHACVF0-20.000000 REVISION: A1 PAGE: 3 CONTENT SPECIFICATIONS PAGE • ELECTRICAL SPECIFICATIONS 4 • DIMENSIONS 5 • MARKING 6 • PACKING 7 • RELIABILITY SPECIFICATIONS 8 ATTACHMENT(S) (optional) TESTING DATA • ELECTRICAL CHARACTERISTICS TEST A YES NO • TEMPERATURE CHARACTERISTICS TEST B YES NO Issue Date: 03.07'09 VER.D P/N: SWXSHACVF0-20.000000 REVISION: A1 PAGE: 4 ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25+/-5oC Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25+/-1oC Relative humidity 40%~70% : Measure equipment SAUNDERS 250A/250B CRYSTAL IMPEDANCE METER. Crystal cutting type The crystal is using AT CUT (thickness shear mode). please refer to marking code page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. Nominal Frequency Oscillation Mode Load Capacitance Frequency Tolerance (25 oC) Effective Series Resistance Shunt Capacitance (C0) Motional Capacitance (C1) Drive Level Operation Temperature Range Stability Over Temperature Range Insulation Resistance Attenuation of Spurious Frequency Amplitude Ratio of Holder to Motional (C0/1) Storage Temperature Aging RLD2(0.1~500uW) DLD2(0.1~500uW) Weight 8.000000 MHz FUND 20.0 pF +/- 10 ppm 100 Ohms Max. 7.0 pF Max. 1.9 fF Max. 500 uW Typ. -40oC ~ +85oC +/- 30 ppm (related to 25 oC) 500 MOhms Min. at DC 100V N/A N/A o o -40 C ~ +85 C +/- 3.0 ppm / year. 80 Ohms Max. 60 Ohms Max. 0.52 g +/- 0.05g Issue Date: 03.07'09 VER.D P/N: SWXSHACVF0-20.000000 REVISION: A1 DIMENSIONS PAGE: 5 UNIT:mm For example : Marking STAR Introduction Pb Free Product 49S 8.000 MHz 3.8 max. 3.68 max. 3.3+/-0.2 For example : Pin Connet GND 11.5 Max. 0.43+/-0.125 Marking Solder Coating (Sn-Ag-Cu Pb Free Coating) 5.0 Max. 4.88+/- 0.25 Issue Date: 03.07'09 VER.D P/N: SWXSHACVF0-20.000000 REVISION: A1 PAGE: 6 Packing For Pb Free Parts : 1.INNER BOX:(Unit:mm) 10bagx200pcs =2000pcs/box 200pcs/bag PUT IN PUT 2.LOGO STICKER(CARTON and INNER BOX):(Unit:mm) 150+/-10 190+/-10 A 42+/-10 Label A G 20 PUT IN 20 A # (1) Put in stuff between space. (2) Tie Up the Carton with 4 Packthreads. (3) "G" : Pb-Free Product Issue Date: 03.07'09 VER.D P/N: SWXSHACVF0-20.000000 REVISION: A1 PAGE: 7 RELIABILITY SPECIFICATIONS No. TEST ITEM 1 Drop Test 2 Fine Leak 3 Gross Leak 4 Mechanical Shock 5 Vibration 6 Solderability Resistance To 7 Soldering Heat 8 Terminal Strength TEST METHODS 50 cm Height, Fall freely onto firm wood for 3 Times. Helium Bombing 5Kgf / cm2 for 2 Hours . 125oC FC#40 ,120 Seconds. Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. Frequency range 10 ~ 55 Hz Amplitude 10G Sweep Time 1 minute Test Time X,Y,Z Plan,each 2 hrs. Temperature 235 oC +/- 5 oC Immersing depth 0.5 mm minimum Immersion time 5 +/- 0.5 seconds Flux Rosin resin methyl alcohol solvent ( 1 : 4 ) Test Temperature 260 oC +/- 5 oC Test Time 10 +/- 1 sec. 2.5mm From terminal , bend 90o,3 times. Total 5 cycles of the following 9 Thermal Shock temperature cycle 125+/-3 0C 25 0C -55+/-3 0C TEST CRITERIA dF/F
SWXSHACVF0-20.000000 价格&库存
很抱歉,暂时无法提供与“SWXSHACVF0-20.000000”相匹配的价格&库存,您可以联系我们找货
  • 5+0.55674
  • 50+0.44010
  • 200+0.38178
库存:106
