TAXM4M2GLDBET2S
TAXM4M2GLDBET2S
    YJX(雅晶鑫)
    HC49S
    无源晶振 4MHz ±20ppm 20pF 80Ω -20℃~+70℃
TAXM4M2GLDBET2S 数据手册
雅晶鑫電子 ● TAXM4M2GLDBET2S ELECTRICAL PARAMETERS 谐振器产品技术指标 1.Holder Type(型号规格) 2.Mode of Oscillation(振动模式) 3.Frequency(标称频率) 4.Load Capacitance (CL)(负载电容) 5.Drive Level(激励功率) 6.Equivalent Resistance(谐振电阻) 7.Shunt Capacitance (Co)(静态电容) 8.Motional Capacitance (C1) (动态电容) 9.Frequency Tolerance at 25℃(调整频差) 10.Stability over operation temperance(温度频差) 11.Insulation Resistance (at DC 100V)(绝缘电阻) 12.Operating Temperature Range(工作温度范围) 13.Storage Temperature Range(储存温度范围) 14.Aging(老化率) 15.DLD2 16.FLD2 N/A 17.RLD2 18.SPDB N/A 19.Other(其它) OUTLINE DIMENSIONS(UNIT:mm)外形尺寸(单位:mm) Min Max Units SEAM HC49S Fundamental MHZ 4.000000 pF 20 uw 100 Ω 80 pF 0 7 fF N/A ppm -20 20 ppm ± 30 MΩ 500 -20 70 ℃ -30 85 ℃ ±5 ppm/year N/A Ω N/A ppm N/A Ω N/A db N/A
TAXM4M2GLDBET2S 价格&库存
很抱歉,暂时无法提供与“TAXM4M2GLDBET2S”相匹配的价格&库存,您可以联系我们找货
TAXM4M2GLDBET2S
  • 1+0.41030
  • 200+0.35640
库存:186
TAXM4M2GLDBET2S
  • 5+0.43460
  • 50+0.38135
  • 200+0.31958
  • 400+0.29960
  • 2400+0.28361
  • 5000+0.27562
库存:7780
