S1C80000UWGAC
S1C80000UWGAC
    JYJE(晶友嘉)
    HC49S
    无源晶振 8MHz ±20ppm 15pF 60Ω -40℃~+85℃
S1C80000UWGAC 数据手册
深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD CRYSTAL RESONATOR SPECIFICATIONS 石英晶体谐振器承认书 客户 Customer: 立创商城 型号 Product: S1C 客户料号 Code No: 我司料号 Code No: S1C80000UWGAC 频率 Frequency: 8.000MHz 数量 Sample Quantity: 日期 Date: 2021-12-10 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 深圳市龙华区东环二路数字智能颖博园 B 栋 412 TEL: 86-755-32840201 32850080 FAX: 86-755-84269460 供应商确认栏: 制作 Handler 戴晓嘉 确认 Checked 陈斌 核审 Approved 李晨 客户承认栏: 承认 Checked 核审 Approved 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 1.Electrical Parameters No. Item Symb Electrical Specification Min. F0 Type Max. 8.000 Units 1 Nominal Frequency 2 Mode of Vibration 3 Frequency Tolerance ΔF/F0 -20 20 ppm 4 Operating Temperature Range TOPR -20 70 ℃ 5 Frequency Stability TC -20 20 ppm 6 Storage Temperature TSTG -40 90 ℃ 7 Load Capacitance 8 Equivalent Series Resistance 9 Drive Level DL 10 Insulation Resistance IR 11 Shunt Capacitance C0 12 Motional Capacitance C1 13 Aging Per Year Fa Remark MHz Fundamental CL 15 ESR 2. Equivalent Circuit: Page:2 At 25℃±3℃ PF 70 100 Ω μW 100 MΩ 7 At 100VDC PF PF -3 3 ppm First Year 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 3.实物 Product 4.外型尺寸 Outline Dimensions (unit:mm) Page:3 深圳市晶友嘉电子有限公司 SHENZHEN JINGGUANGHUA ELECTRONIC CO.,LTD 5.回流焊曲线 Reflow Profiles Profiles Feature Pb-Free Assembly Average Ramp-up Rate (Ts max to Tp) 3℃/second max. Preheat Temperature Min (Ts min) Temperature Max(Ts max) Time (ts min to ts max) 125℃ 200℃ 60~180 seconds Time maintained above Temperature (TL) Time (tL) 217℃ 60~150 seconds Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature(tp) 20~40 second Ramp-down rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Suggest reflow times 3 times max. Page:4 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 6.机械可靠/信赖性 Mechanical Performance Item 1. 2.. Drop characteristics Shake characteristics Condition Standard Free drop from 50cm height on a hard Frequency change: wooden board for 3 times. (Board is ≤5ppm thickness more than 30 mm.) Rr as specification Shake frequency 10~55Hz, cyc1~2 Frequency change: minutes, swing 1.5mm, direction x/y/z, all ≤5ppm 30 minutes, test after 1 hours. Rr as specification Put crystal into the pressure cabin with 3. Airproof alcohol, keep pressure 0.4~0.5mpa 10 characteristics minutes, then take out and blow for 5 IR≥500MΩ minutes 4. 5. 6. 7. 8. Weld characteristics Humidity characteristics 260℃ Max, 10 seconds 90% exhibit tin ok Frequency change: +40±2℃ & 90%~95% R.H. 250 hours ≤5ppm Rr as specification Low temperature -30±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. High temperature +85±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. Temperature -30±3℃/30±3 min~+85±2℃/30±3min, 5 cycling cycles Page:5 Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 7.Dimension of Inside Package 内包装尺寸图 200pcs/bag*10=1 inner box Dimensions of outside Package 外包装尺寸图 10 inner box=1 outer box Page:6
S1C80000UWGAC 价格&库存
很抱歉,暂时无法提供与“S1C80000UWGAC”相匹配的价格&库存,您可以联系我们找货
S1C80000UWGAC
    • 5+0.67986
    • 50+0.54508
    • 200+0.44118
    库存:130
