深圳市晶友嘉电子有限公司
SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD
CRYSTAL RESONATOR SPECIFICATIONS
石英晶体谐振器承认书
客户 Customer:
立创商城
型号 Product:
S1C
客户料号 Code No:
我司料号 Code No:
S1C92160ZWGAC
频率 Frequency:
9.216MHz
数量 Sample Quantity:
日期 Date:
2021-6-7
深圳市晶友嘉电子有限公司
深圳市龙华区东环二路数字智能颖博园 B 栋 412
TEL: 86-755-32840201 32850080
FAX: 86-755-84269460
供应商确认栏:
制作 Handler
戴晓嘉
确认 Checked
陈斌
核审 Approved
李晨
客户承认栏:
承认 Checked
核审 Approved
深圳市晶友嘉电子有限公司
1.Electrical Parameters
No.
Item
Symb
Electrical Specification
Min.
F0
Type
Max.
9.216
Units
1
Nominal Frequency
2
Mode of Vibration
3
Frequency Tolerance
ΔF/F0
-20
ppm
4
Operating Temperature Range
TOPR
-20
70
5
Frequency Stability
TC
-30
30
ppm
6
Storage Temperature
TSTG
-40
90
7
Load Capacitance
8
Equivalent Series Resistance
9
Drive Level
DL
10
Insulation Resistance
IR
11
Shunt Capacitance
C0
12
Motional Capacitance
C1
13
Aging Per Year
Fa
Remark
MHz
Fundamental
CL
ESR
2. Equivalent Circuit:
Page:2
At 25℃±3℃
PF
70
100
Ω
μW
500
MΩ
7
At 100VDC
PF
PF
-3
3
ppm
First Year
深圳市晶友嘉电子有限公司
3.实物 Product
4.外型尺寸 Outline Dimensions (unit:mm)
Page:3
深圳市晶友嘉电子有限公司
SHENZHEN JINGGUANGHUA ELECTRONIC CO.,LTD
5.回流焊曲线 Reflow Profiles
Profiles Feature
Pb-Free Assembly
Average Ramp-up Rate (Ts max to Tp)
3℃/second max.
Preheat
Temperature Min (Ts min)
Temperature Max(Ts max)
Time (ts min to ts max)
125℃
200℃
60~180 seconds
Time maintained above
Temperature (TL)
Time (tL)
217℃
60~150 seconds
Peak/Classification Temperature (Tp)
Time within 5℃ of actual Peak
Temperature(tp)
20~40 second
Ramp-down rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Suggest reflow times
3 times max.
Page:4
深圳市晶友嘉电子有限公司
6.机械可靠/信赖性 Mechanical Performance
Item
1.
2..
Drop
characteristics
Shake
characteristics
Condition
Standard
Free drop from 50cm height on a hard
Frequency change:
wooden board for 3 times. (Board is
≤5ppm
thickness more than 30 mm.)
Rr as specification
Shake frequency 10~55Hz, cyc1~2
Frequency change:
minutes, swing 1.5mm, direction x/y/z, all
≤5ppm
30 minutes, test after 1 hours.
Rr as specification
Put crystal into the pressure cabin with
3.
Airproof
alcohol, keep pressure 0.4~0.5mpa 10
characteristics
minutes, then take out and blow for 5
IR≥500MΩ
minutes
4.
5.
6.
7.
8.
Weld
characteristics
Humidity
characteristics
260℃ Max, 10 seconds
90% exhibit tin ok
Frequency change:
+40±2℃ & 90%~95% R.H. 250 hours
≤5ppm
Rr as specification
Low temperature
-30±2℃, 250 hours, put in room
characteristics
temperature, test after 1 hours.
High temperature
+85±2℃, 250 hours, put in room
characteristics
Temperature
-30±3℃/30±3 min~+85±2℃/30±3min, 5
cycling
cycles
Page:5
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Rr as specification
深圳市晶友嘉电子有限公司
7.Dimension of Inside Package
内包装尺寸图
200pcs/bag*10=1 inner box
Dimensions of outside Package
外包装尺寸图
10 inner box=1 outer box
Page:6
很抱歉,暂时无法提供与“S1C92160ZWGAC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.76313
- 50+0.60783
- 200+0.53018
