CD05M020000RDCAD1
CD05M020000RDCAD1
    TKD(泰晶)
    HC49S
    20MHZ 20PF ±20PPM
CD05M020000RDCAD1 数据手册
STANDARD SPECIFICATION 产品规格书 客户 Customer: 客户料号 Customer P/N NO.: 产品描述 Product Description: 49S 20MHZ 20PF ±20PPM TKD 料号 TKD P/N. NO.: CD05M020000RDCAD1 客户批准 Customer Approval : (请批准后回签一份 PLEASE RETURN A COPY WITH APPROVAL) TKD SCIENCE AND TECHNOLOGY Co.,LTD 泰晶科技股份有限公司 Shen zhen Tai jing Industry Co., Ltd. 深 圳 市 泰 晶 实 业 有 限 公 司 批准 审核 制作 APPROVED CHECK DESIGNER 叶保平 金龙腾 苏婷婷 地址:湖北省随州市曾都经济开发区交通大道 1131 号 ADD:TKD Crystal Science Park,Zengdu Economic Developing Zone,Suizhou,Hubei TEL:0722-3308231,FAX:0722-3309768 URL:www.sztkd.com Page:1 REV. Description of Revision History Date Designer Checked By A New revision 2020-10-21 Sutingting Jinlongteng 地址:湖北省随州市曾都经济开发区交通大道 1131 号 ADD:TKD Crystal Science Park,Zengdu Economic Developing Zone,Suizhou,Hubei TEL:0722-3308231,FAX:0722-3309768 URL:www.sztkd.com Page:2 CRYSTAL SPECIFICATION 1. 2. 3. 4. 5. 6. Description: Quartz Crystal Nominal Frequency: 20.000000MHz Oscillation Mode: Fundamental Cutting Mode: AT cut Measurement Instrument: S&A 250B(Measured FL) Electrical Characteristics: [1]Operation Conditions: Item Symbol MIN. Operating Temperature Range Topt Storage Temperature Range Tstg MAX. Unit -40 85 ℃ -40 85 ℃ Load Capacitance CL Drive Level DL 0.1 Symbol MIN. Tolerance dF/Fo Stability Over Temperature Aging TYP. 20 Condition pF 100 uW MAX. Unit Condition 20 20 ppm Refer to Center Frequency@25±3℃ dF/F25 -30 30 ppm Refer to Operating Temperature @-40~+85℃ dF/F25 -5 5 ppm Per Year MAX. Unit ESR 30 Ω Shunt Capacitance C0 7 pF Insulation Resistance IR [2]Frequency Stability: Item TYP. dF/Fo:Frequency Deviation Refer to Center Frequency dF/F25:Frequency Deviation Refer to 25℃ Frequency [3]Electrical Performance: Item Equivalent Series Resistance Symbol MIN. 500 TYP. MΩ Condition @Series @DC 100 Volt 7. Marking:Laser TKD:Company Logo 20.000:Nominal Frequency TKD20.000 地址:湖北省随州市曾都经济开发区交通大道 1131 号 ADD:TKD Crystal Science Park,Zengdu Economic Developing Zone,Suizhou,Hubei TEL:0722-3308231,FAX:0722-3309768 URL:www.sztkd.com Page:3 8. Outline drawing (unit:mm) 地址:湖北省随州市曾都经济开发区交通大道 1131 号 ADD:TKD Crystal Science Park,Zengdu Economic Developing Zone,Suizhou,Hubei TEL:0722-3308231,FAX:0722-3309768 URL:www.sztkd.com Page:4 9. Reliability Specification Test Item Condition of test Performance Requirements Tensile Strength Termination The unit’s lead wire should withstand a tensile force applied to the There should be no termination in the direction of its draw-out axis of up to 1000g abnormalities detected on maintained as is for 10±2s the unit Solder ability The lead is immersed in a 235±5℃ solder bath within 2±0.5 A new uniform coating of seconds. solder shall cover min mun 95% of the surface being immersed. Vibration Drop Endurance condition by a frequency sweep shall be made. The entire frequency range from 10HZ to 50HZ and return to 10HZ,shall be transverseb in 1min. Amplitude(total excursion):1.5mm this motion shall be applied for a period of 2h each of 3 mutually perpendicular axes(a total of 6h) (1).Frequency Change:±5ppm (2).Resistance:±15% Form 70cm height 3 times on 3cm hard wooden floor (1).Frequency Change:±5ppm (2).Resistance:±15% Damp heat The unit shall be stored at a temperature of 40±2℃with relative (1).Frequency humidity of 90%to95% for 48h, then it shall be subjected to Change:±5ppm standard atmospheric conditions for 1 ~ 2h after which (2).Resistance:±15% measurement shall be made. Dry heat The unit shall be stored at a temperature of 100℃±5℃ for 24h, (1).Frequency then it shall be subjected to standard atmospheric conditions for Change:±5ppm 1~2h after which measurement shall be made. (2).Resistance:±15% Cold The unit shall be stored at a temperature of-40℃±5℃ for 48h, then (1).Frequency it shall be subjected to standard atmospheric conditions for 1~2h Change:±5ppm after which measurement shall be made. (2).Resistance:±15% Aging The unit shall be stored at a temperature of 85℃±5℃ for 7d then it shall be subjected to standard atmospheric conditions for 1~2h after which measurement shall be made. Temperature cycling Refer to specification verdict The unit shall be subjected to 5 successive change of temperature Refer to cycles, each as show in table below,then it shall be subjected to specification standard atmospheric conditions for 1 ~ 2h after which measurement shall be made verdict Temperature Duration 1 -40℃±3℃ 2 Standard atmospheric Within 30s conditions 3 100℃±3℃ 4 Standard atmospheric Within 30s conditions 30min 30min 地址:湖北省随州市曾都经济开发区交通大道 1131 号 ADD:TKD Crystal Science Park,Zengdu Economic Developing Zone,Suizhou,Hubei TEL:0722-3308231,FAX:0722-3309768 URL:www.sztkd.com Page:5 Test Item Sealing Condition of test The crystal filter unit shall be immersed in a industry alcohol for 5±0.5 minutes then 25±3℃ 1~2 Hr before testing Resistance to soldering heat Performance Requirements Insulation Resistance>500MΩ Refer to specification verdict Reflow soldering cure see the chart. Soldering iron method: Bit temperature: 350℃±10℃ Application time of soldering iron:5s Max 地址:湖北省随州市曾都经济开发区交通大道 1131 号 ADD:TKD Crystal Science Park,Zengdu Economic Developing Zone,Suizhou,Hubei TEL:0722-3308231,FAX:0722-3309768 URL:www.sztkd.com Page:6 地址:湖北省随州市曾都经济开发区交通大道 1131 号 ADD:TKD Crystal Science Park,Zengdu Economic Developing Zone,Suizhou,Hubei TEL:0722-3308231,FAX:0722-3309768 URL:www.sztkd.com Page:7
CD05M020000RDCAD1 价格&库存
很抱歉,暂时无法提供与“CD05M020000RDCAD1”相匹配的价格&库存,您可以联系我们找货
