LPC0S13560U83L
LPC0S13560U83L
    LUCKI(蓝晶芯微)
    HC-49S-SMD-2P-MiNi
    无源晶振 13.56MHz ±20ppm 20pF
LPC0S13560U83L 数据手册
page 1 of 6 LUCKI CM ELECTRONICS Co.,Ltd APPROVAL SHEET Customer : Part Number: LK Part No.: LPC0S13560U83L Holder : 47SMD Frequency: 13.560MHZ 20PF ±20PPM Manufacturer: Lucki Electronics Date: 2023-05-31 Prepared Checked Approved Zhao Qian Zhang Dongwei Zhang Bin (For Customer Use) Acceptable Professional manufacturer of quartz crystal Http://www.lucki.com.cn page 2 of 6 LUCKI CM ELECTRONICS Co.,Ltd Revision History No. Revised Date Change Content Professional manufacturer of quartz crystal Approved Http://www.lucki.com.cn Remark page 3 of 6 LUCKI CM ELECTRONICS Co.,Ltd 一、电性能参数 ELECTRICAL PARAMETERS: No. 1 2 特性 Characteristic 产品型号 Ackage Type 标称频率 Nominal Frequency 范围 Limits ZC-47SMD 13.560000MHz 3 振动模式 Mode of Vibration 4 常温频差 Frequency Tolerance ±20ppm 5 工作温度范围 Operating Temperature Range -20℃~+70℃ 6 频率稳定度 Frequency Stability ±30ppm 7 8 储存温度范围 Storage Temperature Range 负载电容 Load capacitance AT—Fund(基频) 25±3℃ 测试 20pF 谐振电阻 Equivalent Series Resistance 40Ω max 10 激励功率 Drive Level 100μW max 11 绝缘电阻 Insulation Resistance 500MΩ 12 静电容 Shunt Capacitance 5pF max 年老化率 Aging Per Year Measure at 25℃±3℃ -40℃~+85℃ 9 13 备注 Remark At 250VDC ±5ppm 14 Professional manufacturer of quartz crystal Http://www.lucki.com.cn page 4 of 6 LUCKI CM ELECTRONICS Co.,Ltd 三、外形尺寸 Outline Dimensions (unit: mm) NO. 1. 2 规格 F16Mhz H 2.3Max 2.1Max 四、印字 Marking Professional manufacturer of quartz crystal Http://www.lucki.com.cn page 5 of 6 LUCKI CM ELECTRONICS Co.,Ltd 五、包装方式 Packing T/R: 3000pcs/ REEL 单位 units : mm: Model ZC-47SM A 4.7±0.1 B 9.5±0.1 D Φ1.5 E F P P0 T W 1.75±0.1 7.5±0.1 8.0±0.1 4.0±0.1 0.3±0.05 16±0.3 Professional manufacturer of quartz crystal Http://www.lucki.com.cn page 6 of 6 LUCKI CM ELECTRONICS Co.,Ltd Professional manufacturer of quartz crystal Http://www.lucki.com.cn
LPC0S13560U83L 价格&库存
很抱歉,暂时无法提供与“LPC0S13560U83L”相匹配的价格&库存,您可以联系我们找货
LPC0S13560U83L
    • 5+0.29652
    • 50+0.23172
    • 150+0.19932
    • 500+0.17502
    • 3000+0.15558
    • 6000+0.14580
    库存:5
