深圳市晶友嘉电子有限公司
SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD
CRYSTAL RESONATOR SPECIFICATIONS
石英晶体谐振器承认书
客户 Customer:
立创商城
型号 Product:
S4T
客户料号 Code No:
我司料号 Code No:
S4T67458UWKAC
频率 Frequency:
6.7458MHz
数量 Sample Quantity:
日期 Date:
2021-12-10
深圳市晶友嘉电子有限公司
深圳市龙华区东环二路数字智能颖博园 B 栋 4 楼
TEL: 86-755-32840201 32850080
FAX: 86-755-84269460
供应商确认栏:
制作 Handler
确认 Checked
核审 Approved
戴晓嘉
陈斌
李晨
客户承认栏:
承认 Checked
核审 Approved
Page:1
深圳市晶友嘉电子有限公司
1.Electrical Parameters
No.
Item
Symb
Electrical Specification
Min.
F0
Type
Max.
6.7458
Remark
Units
1
Nominal Frequency
MHz
2
Mode of Vibration
3
Frequency Tolerance
ΔF/F0
-20
ppm
4
Operating Temperature Range
TOPR
-20
70
5
Frequency Stability
TC
-20
ppm
6
Storage Temperature
TSTG
-40
85
7
Load Capacitance
CL
8
Equivalent Series Resistance
ESR
120
Ω
9
Drive Level
DL
100
μW
10
Insulation Resistance
IR
11
Shunt Capacitance
12
13
Fundamental
15
At 25℃±3℃
PF
MΩ
At 100VDC
C0
PF
1.36+-10%
Motional Capacitance
C1
PF
5.14+-10%
Aging Per Year
Fa
ppm
First Year
2. Equivalent Circuit:
Page:2
500
-3
3
深圳市晶友嘉电子有限公司
3.实物 Product
4.外型尺寸 Outline Dimensions (unit:mm)
2.3mm Max
Page:3
深圳市晶友嘉电子有限公司
SHENZHEN JINGGUANGHUA ELECTRONIC CO.,LTD
5.回流焊曲线 Reflow Profiles
Profiles Feature
Pb-Free Assembly
Average Ramp-up Rate (Ts max to Tp)
3℃/second max.
Preheat
Temperature Min (Ts min)
Temperature Max(Ts max)
Time (ts min to ts max)
125℃
200℃
60~180 seconds
Time maintained above
Temperature (TL)
Time (tL)
217℃
60~150 seconds
Peak/Classification Temperature (Tp)
Time within 5℃ of actual Peak
Temperature(tp)
20~40 second
Ramp-down rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Suggest reflow times
3 times max.
Page:4
深圳市晶友嘉电子有限公司
6.机械可靠/信赖性 Mechanical Performance
Item
1.
2..
Drop
characteristics
Shake
characteristics
Condition
Standard
Free drop from 50cm height on a hard
Frequency change:
wooden board for 3 times. (Board is
≤5ppm
thickness more than 30 mm.)
Rr as specification
Shake frequency 10~55Hz, cyc1~2
Frequency change:
minutes, swing 1.5mm, direction x/y/z, all
≤5ppm
30 minutes, test after 1 hours.
Rr as specification
Put crystal into the pressure cabin with
3.
Airproof
alcohol, keep pressure 0.4~0.5mpa 10
characteristics
minutes, then take out and blow for 5
IR≥500MΩ
minutes
4.
5.
6.
7.
8.
Weld
characteristics
Humidity
characteristics
260℃ Max, 10 seconds
90% exhibit tin ok
Frequency change:
+40±2℃ & 90%~95% R.H. 250 hours
≤5ppm
Rr as specification
Low temperature
-30±2℃, 250 hours, put in room
characteristics
temperature, test after 1 hours.
High temperature
+85±2℃, 250 hours, put in room
characteristics
Temperature
-30±3℃/30±3 min~+85±2℃/30±3min, 5
cycling
cycles
Page:5
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Rr as specification
深圳市晶友嘉电子有限公司
7.包装 PACKING
1. 每 盘 数 量 Capacity of a plastic reel : 3000 PCS ;
2. 每内箱数量 Capacity per inner box : 3000 PCS
(A reel inner) ;
3. 每大箱数量 Capacity per outer carton : 10000 PCS (10×inner box) .
Page:6
很抱歉,暂时无法提供与“S4T67458UWKAC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.86843
- 50+0.68699
- 150+0.59627
- 500+0.52823
