M332768DWNAC
M332768DWNAC
    JYJE(晶友嘉)
    HC-49S-SMD-2P-MiNi
    无源晶振 32.768kHz ±20ppm 7pF 70kΩ -40℃~+85℃
M332768DWNAC 数据手册
深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD CRYSTAL RESONATOR SPECIFICATIONS 石英晶体谐振器承认书 客户 Customer: 立创商城 型号 Product: M3 客户料号 Code No: 我司料号 Code No: M332768DWNAC 频率 Frequency: 32.768KHz 数量 Sample Quantity: 日期 Date: 2021-6-16 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 深圳市龙华新区东环二路数字智能颖博园 B 栋 412 TEL: 86-755-32840201 32850080 FAX: 86-755-8426946 供方确认栏: 制作 Handler 确认 Checked 核审 Approved 戴晓嘉 陈斌 李晨 客户承认栏: 承认 Checked 核审 Approved Page:1 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 1.Electrical Parameters No. Item Symb Electrical Specification Min. 1 Nominal Frequency 2 Mode of Vibration 3 Frequency Tolerance 4 Operating Temperature Range F0 Type Max. 32.768 Units Remark KHz NT ΔF/F0 -20 20 ppm TOPR -20 70 ℃ 5 Frequency Stability TC -30 30 ppm 6 Storage Temperature TSTG -40 85 ℃ 7 Load Capacitance CL 8 Equivalent Series Resistance ESR 9 Drive Level DL 10 Insulation Resistance IR 500 11 Aging Per Year Fa -3 2. Equivalent Circuit: Page:2 7 At 25℃±3℃ -0.034 +/-0.006ppm/℃2 PF 70 0.1 3 kΩ μW 1uW max MΩ At 100VDC ppm First Year 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 3.实物 Product 4.外型尺寸 Outline Dimensions (unit:mm) Page:3 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 5.回流焊曲线 Reflow Profiles Profiles Feature Pb-Free Assembly Average Ramp-up Rate (Ts max to Tp) 3℃/second max. Preheat Temperature Min (Ts min) Temperature Max(Ts max) Time (ts min to ts max) 125℃ 200℃ 60~180 seconds Time maintained above Temperature (TL) Time (tL) 217℃ 60~150 seconds Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature(tp) 20~40 second Ramp-down rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Suggest reflow times 3 times max. Page:4 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 6.机械可靠/信赖性 Mechanical Performance Item 1. 2.. Drop characteristics Shake characteristics Condition Standard Free drop from 50cm height on a hard Frequency change: wooden board for 3 times. (Board is ≤5ppm thickness more than 30 mm.) Rr as specification Shake frequency 10~55Hz, cyc1~2 Frequency change: minutes, swing 1.5mm, direction x/y/z, all ≤5ppm 30 minutes, test after 1 hours. Rr as specification Put crystal into the pressure cabin with 3. Airproof alcohol, keep pressure 0.4~0.5mpa 10 characteristics minutes, then take out and blow for 5 IR≥500MΩ minutes 4. 5. 6. 7. 8. Weld characteristics Humidity characteristics 260℃ Max, 10 seconds 90% exhibit tin ok Frequency change: +40±2℃ & 90%~95% R.H. 250 hours ≤5ppm Rr as specification Low temperature -30±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. High temperature +85±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. Temperature -30±3℃/30±3 min~+85±2℃/30±3min, 5 cycling cycles Page:5 Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification
M332768DWNAC 价格&库存
很抱歉,暂时无法提供与“M332768DWNAC”相匹配的价格&库存,您可以联系我们找货
M332768DWNAC
    • 5+0.72317
    • 50+0.57802
    • 150+0.50544
    • 500+0.45101
    • 3000+0.37714
    • 6000+0.35537
    库存:941
