SS1045-SS10100
Schottky Barrier Diode
»Features
Low forward voltage drop
Guarding protection
Glass passivated junction
High current capability
High efficiency operation
Extremely low thermal resistance
Halogen free and RoHS compliant
»General Description
Case: JEDEC DO -214AB molded plastic
Polarity: Color band denotes cathode
Mounting Position: Any
Weight: 0.009 ounces, 0.25 gram
SMC(DO-214AB)
» Maximum Ratings and Electrical Characteristics
Ratings at 2 5℃ ambient temperature unless otherwise specified.
Single phase half wave 60HZ. resistive or inductive load. For capacitive load current derate
by 20%
SYMBOL
SS1045
SS1060
SS10100
Marking
SS1045
SS1060
SS10100
Maximum repetitive peak reverse voltage
VRRM
45
60
100
V
Maximum RMS voltage
VRWS
31
42
70
V
Maximum DC blocking voltage
VDC
45
60
100
V
Maximum average forward rectified
current at TL=90
IF(AV)
10.0
A
Peak forward surge current 8.3ms single
half-sine-wave
IFSM
150
A
Maximum instantaneous forward voltage
at I FM=10.0A
VF
Maximum DC reverse current TJ=25
at rated DC blocking voltage TJ=125
IR
UNITS
CHARACTERISTICS
Maximum thermal resistance
Operating temperature range
Storage temperature range
R
0.75
0.55
0.85
0.2
0.1
50.0
5.0
mA
o
28
JL
V
C/W
TJ
-55 ---- +125
o
C
TSTG
-55 ---- +150
o
C
»Summary of Packing Options
Package
Packing Description
Packing Quantity
Industry Standard
SMC
Tape/Reel,13" reel
3000
EIA-481-1
Revision 2018
www.born-tw.com
1/3
SS1045-SS10100
210
Peak Forward Surage Current
Amperes
16.0
14.0
12.0
Amperes
Average Forward Rectified Current
»Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted))
10.0
8.0
6.0
4.0
2.0
0.0
150
120
90
f=60Hz
60
30
10
Lead Temperature
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
100
Number of cycles
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
100
SS1045 -SS1060C
SS10100
500
100
10
1
SS1045
SS1060
SS10100
0.1
TJ=100 C
1
0.1
0.01
TJ=25 C
0.
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
Revision 2018
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
CURRENT,AMPERES
TJ=25 C
0.001
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
www.born-tw.com
2/3
SS1045-SS10100
»Package Information - SMC
B
D
A
C
F
H
L
G
Z
X
Y
SMC
Dimension
Revision 2018
Inches
MIN
NOM
Millimeters
MAX
MIN
NOM
MAX
A
0.22
0.245
5.59
6.22
B
0.305
0.32
7.75
8.13
C
0.114
0.126
2.9
3.2
D
0.26
0.28
6.6
7.11
F
0.006
0.012
0.15
0.305
G
H
L
X
Y
Z
0.087
0.03
0.008
0.11
0.06
2.2
0.76
0.203
2.8
1.52
0.15
0.119
0.151
www.born-tw.com
3.82
3.03
3.84
3/3
很抱歉,暂时无法提供与“SS10100 SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.79403
- 50+0.63073
- 150+0.54909
- 500+0.48785
- 3000+0.42428
- 6000+0.39979
