SS82 SMC
SS82 SMC
    BORN(伯恩半导体)
    SMC(DO-214AB)
    电压:20V 电流:8A
SS82 SMC 数据手册
SS82-SS820 Schottky Barrier Diode »Features  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency  Built-in strain relief,ideal for automated placement  High forward surge current capability  High temperature soldering guaranteed: 250℃/10 seconds at terminals »General Description SMC(DO-214AB)  Case: JEDEC DO -214AB molded plastic  Terminals: Axial leads. Solderable per MIL - STD - 750 Method 2026  Polarity: Color band denotes cathode  Mounting Position: Any » Maximum Ratings and Electrical Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specifoed. Single phase half wave 60HZ. resistive or inductive load. For capacitive load current derate by 20% SYMBOLS SS82 SS84 SS86 SS88 SS810 SS815 SS820 Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=110 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 8.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical thermal resistance (NOTE 1) Operating junction and storage temperature range NOTE: VRRM VRMS VDC 20 14 40 21 40 20 60 28 80 56 100 70 150 105 200 150 60 80 100 150 200 UNITS VOLTS VOLTS VOLTS I(AV) 8.0 Amp IFSM 150.0 Amps VF 0.70 0.55 IR RθJA TJ,TSTG 0.85 0.95 Volts 10.0 0.1 2.0 mA 0.5 20.0 80 -55 to +150 C/W C 1. Measured at 1.0MHZ and applied reverse voltage of 4.0V DC. Revision 2018 www.born-tw.com 1/3 SS82-SS820 »Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted)) AVERAGE FORWARD RECTIFIED CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 150 PEAK FORWARD SURGE CURRENT, AMPERES 10.0 8.0 6.0 Single Phase Half Wave 60Hz Resistive or inductive Load 4.0 SS82-SS86 SS88-SS820 2.0 120 90 60 30 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 0 0 2 0.0 10 1 AMBIENT TEMPERATURE, C 100 NUMBER OF CYCLES AT 60 Hz FIG. 4-TYPICAL REVERSE CHARACTERISTICS FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 100 50 INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES TJ=25 C 10.0 1 SS82-SS84 SS86 SS88-SS810 SS815-SS820 0.1 0.01 0 10 TJ=100 C 1 0.1 TJ=25 C 0.01 0. 0 0.001 0 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 30 60 90 12 PERCENT OF PEAK REVERSE VOLTAGE,% TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0. 0.1 t,PULSE DURATION,sec. Revision 2018 www.born-tw.com 2/3 SS82-SS820 »Package Information SMC B D A C F H L G Z X Y SMC Dimension Inches MIN NOM Millimeters MAX MIN NOM MAX A 0.22 0.245 5.59 6.22 B 0.305 0.32 7.75 8.13 C 0.114 0.126 2.9 3.2 D 0.26 0.28 6.6 7.11 F 0.006 0.012 0.15 0.305 G H L X Y Z 0.087 0.03 0.008 0.11 0.06 2.2 0.76 0.203 2.8 1.52 0.15 0.119 0.151 3.82 3.03 3.84 »Ordering information Part Number SS82 SS84 SS86 SS88 SS810 SS815 SS820 Marking SS82 SS84 SS86 SS88 SS810 SS815 SS820 Base qty 3K 3K 3K 3K 3K 3K 3K Revision 2018 www.born-tw.com 3/3
SS82 SMC 价格&库存
很抱歉,暂时无法提供与“SS82 SMC”相匹配的价格&库存,您可以联系我们找货
SS82 SMC
  • 1+0.69520
  • 200+0.47850
  • 1500+0.43560
  • 3000+0.40700
库存:3000
SS82 SMC
    • 5+0.54080
    • 50+0.47653
    • 150+0.44440
    • 500+0.42026
    • 3000+0.38722
    • 6000+0.37757
    库存:6068
