SURFACE MOUNT FAST SWITCHING RECTIFIER
VOLTAGE RANGE
RS3A THRU RS3M
50 to 1000 Volts
CURRENT
3.0 Ampere
Features
Plastic package has underwrites laboratory flammability Classification 94V-0
Low profile surface mount package
Built-in strain relief
Fast switching for high efficiency
Glass passivated chip junction
High temperature soldering 250℃/10 second at terminals
Mechanical Data
Case: JEDED DO-214AB molded plastic over glass passivated chip
Terminals: Solder plated, Solderable per MIL-STD-750, method 2026
Polarity: Laser band denote cathode band
Weight: 0.007 ounce, 0.21 gram
Maximum Ratings and Electrical Characteristics
Ratings at 25℃ambient temperature unless otherwise specified
Single Phase, half wave, 60Hz, resistive or inductive load
For capacitive load derate current by 20%
SYMBOL
S
RS
3A
RS
3B
RS
3D
RS
3G
RS
3J
RS
3K
RS
3M
UNITS
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
Volts
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
700
Volts
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
Volts
Maximum Average Forward Rectified Current at TL =100℃
I(AV)
3.0
Amp
Peak Forward Surge Current 8.3mS single half sine wave
superimposed on rated load (JEDEC method)
IFSM
80
Amps
Maximum Instantaneous Forward Voltage @ 3.0A
VF
1.3
Volts
2
26.8
I2t
TYPE NUMBER
2
I t Rating for fusing (1ms < t < 8.3ms)
Maximum DC Reverse Current at Rated DC
Blocking Voltage
It
TA = 25℃
5.0
IR
TA = 125℃
Typical Reverse Recovery Time (Note 3)
TRR
150
Typical Junction Capacitance (Note 1)
CJ
Typical Thermal Resistance (Note 2)
250
500
17
nS
pF
RθJA
47
RθJL
13
TJ
-55 to +150
TSTG
-55 to +150
Operating Junction Temperature Range
Storage Temperature Range
µA
100
℃/W
Notes:
1. Measured at 1.0MHz and applied reverse voltage of 4.0 Volts.
2. Thermal Resistance from Junction to Ambient at. 0.3×0.3″(8.0 × 8.0mm) copper pad areas.
3. Reverse Recovery Test Conditions:If=0.5mA,Ir=1.0mA,Irr=0.25A.
Sep-03, Rev A
CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
VOLTAGE RANGE
RS3A THRU RS3M
50 to 1000 Volts
CURRENT
3.0 Ampere
Ratings and Characteristic Curves (T =25℃ unless otherwise noted)
A
FIG.1-TYPICAL FORWARD CURRENT
FIG.2-MAXIMUM NON-REPETITIVE PEAK
FORWARD SURGE CURRENT
90
2.5
2.0
1.5
1.0
0.071×0.071"(1.8×1.8mm)
Copper Pads
0.5
80
70
CURRENT, (A)
PEAK FORWARD SURGE
3.0
(A)
AVERAGE FORWARD CURRENT,
DERATING CURVE
8.3ms Single Half Sine-Wave
(JEDEC Method) Tj = Tjmax
60
50
40
30
50
100
75
175
150
125
1 Cycle
1
2
AMBIENT TEMPERATURE, (°C)
4
6
8
10
40
100
NUMBER OF CYCLES AT 60 Hz
FIG.3-TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
0.1
0.01
TJ =25°C
Pulse Width=300us
1% Duty Cycle
100
10
(μA)
INSTANTANEOUS REVERSE CURRENT,
1.0
(A)
INSTANTANEOUS FORWARD CURRENT,
10
TJ =125°C
1.0
TJ =25℃
0.1
0.001
0.4
0.8
1.0
1.2
1.4
1.6
40
60
100
80
120
140
PERCENT OF RATED PEAK
REVERSE VOLTAGE,(%)
INSTANTANEOUS FORWARD VOLTAGE,(V)
FIG.5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
100
F1G.6-TEST CIRCUIT DIAGRAM AND
REVERSE RECOVERY TIME CHARACTERISTIC
Trr
50Ω
10Ω
NONINDUCTIVE NONINDUCTIVE
+0.5A
10
25 Vdc
(approx.)
T J =25°C
f=1MHz
Vsig=50mVp-p
1
0.1
1.0
10
REVERSE VOLTAGE,(V)
Sep-03, Rev A
100
D.U.T.
1Ω
NON
INDUCTIVE
PULSE
GENERATIOR
(NOTE 2)
OSCILLOSCOPE
(NOTE 1)
-0.25A
-1.0A
NOTES : 1.Rise Time=7ns max. Input Impedance=
1 magohm. 22pF
2.Rise time=10ns max. Source Impedance=
50 ohms
1cm
SET TIME BASE FOR
50/100ns/cm
VOLTAGE RANGE
RS3A THRU RS3M
Package Outline Dimensions
Sep-03, Rev A
CURRENT
50 to 1000 Volts
3.0 Ampere
in inches (millimeters)
VOLTAGE RANGE
RS3A THRU RS3M
50 to 1000 Volts
CURRENT
3.0 Ampere
Package Reel Information
Specifications
Ao
Bo
Ko
Po
W
t1
SMC
6.05±0.10
8.31±0.10
2.54±0.10
4.00±0.1
16.0±0.30
0.30±0.02
DEVICE TYPE
SMC
Sep-03, Rev A
13"Reel
Tape
Width Q'TY/REEL(pcs BOX/CARTOO Q'TY/CARTON Q'TY/REEL(pcs
N
(pcs)
16mm
3000
8
48000
800
07"Reel
REEL/BOX
3
N
(pcs)
8
19200
VOLTAGE RANGE
RS3A THRU RS3M
CURRENT
50 to 1000 Volts
3.0 Ampere
Reflow Profile
Reflow Condition
Pre Heat
Temperature Min.
+150°C
Temperature Max.
+200°C
Time(Min to Max)
60-180 secs.
Average ramp up rate(Liquidus Temp(TL) to peak)
3°C/sec. Max.
TS(max) to TL - Ramp-up Rate
3°C/sec. Max.
Reflow
Sep-03, Rev A
Pb-Free Assembly
Temperature (TL)(Liquidus)
+217°C
Temperature (TL)
60-150 secs.
Peak Temp (TP)
+(260+0/-5 )°C
Time within 5°C of actual Peak Temp (TP)
25 secs.
Ramp-down Rate
6°C/sec. Max.
Time 25°C to peak Temp (TP)
8 min. Max.
Do not exceed
+260°C
RS3A THRU RS3M
VOLTAGE RANGE
CURRENT
50 to 1000 Volts
3.0 Ampere
Disclaimer
The information presented in this document is for reference only. Chongqing changjie Electronic Technology Co., Ltd. reserves
the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or
design or otherwise.
The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used
with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life
(such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and
other safety devices), Changjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such
improper use of sale.
This publication supersedes & replaces all information previously supplied. For additional information, please visit our website
http:// www.czlangjie.com , or consult your nearest Langjie’s sales office for further assistance.
Sep-03, Rev A
很抱歉,暂时无法提供与“RS3MC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.26093
- 100+0.20445
- 300+0.17615
- 3000+0.15498
- 6000+0.13803
- 9000+0.12950
