SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
VOLTAGE RANGE
SS52 THRU SS520
20 to 200 Volts
CURRENT
5.0 Ampere
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed: 260 C/10 seconds at terminals
Mechanical Data
Case: Transfer molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead :Solder plated, solderable per MIL-STD-750 method 2026
Polarity: Color band denotes cathode end
Weight: 0.007 ounce, 0.21 gram
Maximum Ratings and Electrical Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load
For capacitive load derate current by 20%
SYMBOLS
SS
52
SS
54
SS
55
SS
56
SS
58
SS
510
SS
515
SS
520
UNIT
Maximum Repetitive Peak Reverse Voltage
VRRM
50
60
80
100
150
200
Volts
Maximum RMS Voltage
VRMS
14
28
35
42
56
70
105
140
Volts
Maximum DC Blocking Voltage
VDC
50
60
80
100
150
200
Volts
TYPE NUMBER
Maximum Average Forward Rectified Current at TLsee figure 1 TL
=100℃
Peak Forward Surge Current 8.3ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage @ 5.0A
Maximum DC Reverse Current at rated DC Blocking
Voltage per element
Typical Thermal Resistance (Note 1)
I(AV)
5.0
Amps
IFSM
125
Amps
VF
TA = 25℃
TA = 125℃
0.70
0.85
0.1
IR
20.0
10.0
46
RθJL
12
CJ
Operating Junction Temperature
TJ
TSTG
0.90
0.01
RθJA
Diode junction capacitance (Note 2)
Storage Temperature Range
0.55
300
2.0
Volts
mA
℃/W
200
-55 to +150
-55 to +150
pF
-65to+175
Notes:
1.
Thermal resistance from Junction to ambient and from junction to lead mounted on PCB. with 0.3×0.3″(8.0 × 8.0mm)copper
pad areas.
2.
f=1MHz and applied 4V DC reverse voltage.
Sep-03, Rev A
CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
VOLTAGE RANGE
SS52 THRU SS520
20 to 200 Volts
CURRENT
5.0 Ampere
Ratings and Characteristic Curves (T =25℃ unless otherwise noted)
4.5
4.0
3.5
3.0
S S52-SS510
S S515-SS520
2.5
2.0
1.5
1.0
0.5
P .C.B .M O UNTED
0.20X 0.20″(5.0X 5.0m m )
COP PE R PA D AREAS
60
70
80
90
100
110
120
130
140
150
160
F1G .2-M AXIM UM N O N -R EPETITIVE PEAK
FO R W ARD SUR G E C URRENT
200
T L =100℃
8.3m s S ingle Half Sine-W ave
(JE DE C M ethod)
180
160
140
AMPERES
5.0
AMPERES
AVERAGE FORWARD CURRENT
F1G .1-FO R W ARD C UR RENT
D ER ATIN G CURVE
PEAK FORWARD SURGE CURRENT,
A
120
100
80
60
40
F1G .3-TYPIC AL INSTANTANEO US
FO R W ARD C HARACTER ISTICS
100
1.0
0.1
S S52-SS54
S S55-SS56
S S58-SS515
SS520
100
T J =100℃
10
MICROAMPERES
INSTANTANEOUS REVERSE CURRENT,
F1G .4-TYPIC AL R EVER SE C HARACTERISTICS
10
AMPERES
INSTANTANEOUS FORWARD CURRENT,
10
N UM BER O F C YC LES AT 60 Hz
LEAD TEM PER ATUR E,(℃ )
1.0
T J =75℃
0.1
T J =25℃
0.01
0.001
0.4
0.6
0.8
1.0
1.2
1.4
INSTANTAN EO US FO R W ARD VO LTAG E, VO LTS
60
80
100
PER CENT O F RATED PEAK
R EVERSE VO LTAG E,(% )
F1G .5-TYPIC AL JUN CTIO N CAPACITANCE
JUNCTION CAPACITANCE,(pF)
200
100
T J =25℃
f=1M Hz
V sig=50m Vp-p
10
S S52-SS54
S S55-SS520
1.0
1.0
10
100
R EVR ESE VO LTAG E, VO LTS
Sep-03, Rev A
VOLTAGE RANGE
SS52 THRU SS520
Package Outline Dimensions
Sep-03, Rev A
CURRENT
20 to 200 Volts
5.0 Ampere
in inches (millimeters)
VOLTAGE RANGE
SS52 THRU SS520
20 to 200 Volts
CURRENT
5.0 Ampere
Package Reel Information
Specifications
Ao
Bo
Ko
Po
W
t1
SMC
6.05±0.10
8.31±0.10
2.54±0.10
4.00±0.1
16.0±0.30
0.30±0.02
DEVICE TYPE
SMC
Sep-03, Rev A
13"Reel
Tape
Width Q'TY/REEL(pcs BOX/CARTOO Q'TY/CARTON Q'TY/REEL(pcs
N
(pcs)
16mm
3000
8
48000
800
07"Reel
REEL/BOX
3
N
(pcs)
8
19200
SS52 THRU SS520
VOLTAGE RANGE
CURRENT
20 to 200 Volts
5.0 Ampere
Marking Code
Part Number Code
Sep-03, Rev A
VOLTAGE RANGE
SS52 THRU SS520
CURRENT
20 to 200 Volts
5.0 Ampere
Reflow Profile
Reflow Condition
Pre Heat
Temperature Min.
+150°C
Temperature Max.
+200°C
Time(Min to Max)
60-180 secs.
Average ramp up rate(Liquidus Temp(TL) to peak)
3°C/sec. Max.
TS(max) to TL - Ramp-up Rate
3°C/sec. Max.
Reflow
Sep-03, Rev A
Pb-Free Assembly
Temperature (TL)(Liquidus)
+217°C
Temperature (TL)
60-150 secs.
Peak Temp (TP)
+(260+0/-5 )°C
Time within 5°C of actual Peak Temp (TP)
25 secs.
Ramp-down Rate
6°C/sec. Max.
Time 25°C to peak Temp (TP)
8 min. Max.
Do not exceed
+260°C
SS52 THRU SS520
VOLTAGE RANGE
CURRENT
20 to 200 Volts
5.0 Ampere
Disclaimer
The information presented in this document is for reference only. Chongqing changjie Electronic Technology Co., Ltd. reserves
the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or
design or otherwise.
The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used
with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life
(such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and
other safety devices), Changjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such
improper use of sale.
This publication supersedes & replaces all information previously supplied. For additional information, please visit our website
http:// www.czlangjie.com , or consult your nearest Langjie’s sales office for further assistance.
Sep-03, Rev A
很抱歉,暂时无法提供与“SS54C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40932
- 100+0.32066
- 300+0.27638
- 3000+0.24311
- 6000+0.21654
- 9000+0.20315
