830-A-111-THR/03
830-A-111-THR/03
    WECO(威克德诺)
    弯插,P=3.5mm
    接线端子 间距:3.50mm 每排针脚数:3
830-A-111-THR/03 数据手册
TECHNICAL DATA SHEET 830-A-111-THR PCB connector for SMD Push-In connection 12,3 10,6 0,8 0,35 3,5 5,5 2,5 7 L 3,5 GENERAL INFORMATION 3,5 mm 2+3 Lighting technology, devices Rated Cross Section Wire Stripping Length Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Soldering process Hole in PCB solid / stranded / AWG 0,2 - 1,0 mm² / 0,2 - 0,75 mm² / 24 - 18 AWG 1 mm² (starr / solid) / 0,75 mm² 7,5 mm ± 0,5 mm III 3 160 V 2,5 kV III 2 160 V 2,5 kV ø 1,9 TECHNICAL DATA Clamping Range 10,6 ø 1,1 L PCB LAYOUT (RECOMMENDATION) 5,5 3,5 Pitch No. of poles Areas of application 3,5 L = (No. of poles) x pitch L1 = (No. of poles - 1) x pitch Solder paste thickness: 0,15 - 0,2 mm solder pad, outside diameter: ø 1,9 mm ✱= Both solder pads of each pole can be connected together. II 2 320 V 2,5 kV MATERIAL Moulding Comparative Tracking Index Insulating Group Temperature Range 130 V acc. to EN 60998-1 13,5 A apply to 1 mm² solid 9 A apply to 0,75 mm² Reflow solder ø 1,1 mm Terminal body Spring PA HT, white, V-0 CTI ≥ 600 I -40°C up to 120°C; reflow solder temperature peak max. 255°C acc. to DIN EN 61760-1 Tin plated copper alloy Stainless steel APPROVALS Current [A] Voltage [V] Group AWG 6 300 B 24 - 18 [Nm] OPTIONS / ACCESSORIES • • • • Consecutive numbering Special marking according to drawing Black colour on request Tape-on-Reel on request CONFIGURATIONS Poles Part number 2 3 830-A-111-THR/02 830-A-111-THR/03 Article number 10.813.052 10.813.053 Length (L) 6,90 mm 10,40 mm Packaging PU Box Box 250 250 11.17 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
830-A-111-THR/03 价格&库存
很抱歉,暂时无法提供与“830-A-111-THR/03”相匹配的价格&库存,您可以联系我们找货
