T936-H419-80.00MHz
T936-H419-80.00MHz
    DAPU(大普)
    SMD4_14.5x9.6mm
    温度补偿晶体振荡器(TCXO) 3.3V 80MHz SMD4_14.5x9.6mm ±1ppm
T936-H419-80.00MHz 数据手册
W/DP RD-Q4187-01-A1 Customer Code : DATASHEET DAPU P/N : T936-H419-80.00MHz P/N : DAPU Drew Audited Customer Approval Approved Stamp, please! Thanks! Date:2023.04.17 Guangdong Dapu Telecom Technology Co.,Ltd Building 5, No.24, Industrial East Road, Songshanhu Park, Dongguan, Guangdong, P.R. China The ParameterFAX:0086-0769-81800098 of Product TEL:0086-0769-88010888 Specification No.: 1.0 Customer Signature : Page: 1/6 Guangdong Dapu Telecom Technology Co., Ltd http://www.dptel.com Building 5, No.24, Industrial East Road, Songshanhu Park, Dongguan, Guangdong, P.R. China TEL:0086-0769-88010888 FAX:0086-0769-81800098 Table of amendment Version Revision contents Prepared by Revised date 1.0 The first issued Amway 2023.04.17 Specification No.: 1.0 Customer Signature : Page: 2/6 Guangdong Dapu Telecom Technology Co., Ltd http://www.dptel.com Building 5, No.24, Industrial East Road, Songshanhu Park, Dongguan, Guangdong, P.R. China TEL:0086-0769-88010888 FAX:0086-0769-81800098 1. Electrical Parameters MODEL: T936-H419-80.00MHz Parameters Item Description Unit Min. Frequency Output Sine Wave 4 dBm Harmonics Suppression -30 dBc Spurious Suppression -60 dBc Load Initial Frequency Tolerance Frequency Stabilities Power Supply MHz 8 Frequency Tolerance vs. Operating Temperature Range Frequency Tolerance vs. Supply Voltage 6 Ω 50 -1 ×10-6 TA varied from-30℃to 60℃, measurement referenced to frequency observed with fref = (fmax+fmin )/2, Vcc=3.3V, Oload=50Ω, temperature variable speed less than 2℃ per minute. +1 ×10-6 Measurement referenced to frequency observed with TA=25℃, Vcc=3.3V, and after 15 minutes of operation,within 30 days after ex-works. +0.1 ×10-6 measurement referenced to frequency observed TA=25℃, Vcc varied from 3.13V to 3.47V, and OLoad=50Ω . 5% load change measurement referenced to frequency observed with TA=25℃, Vcc=3.3V, OLoad=50Ω. +1 -1 -0.1 Frequency Tolerance vs. Load -0.1 +0.1 ×10-6 Aging Tolerance Per Day -10 +10 ×10-9 Aging Tolerance 1 Year -1 +1 ×10-6 Aging Tolerance 10 Year -4.6 +4.6 ×10-6 40 mA 3.47 V Current Consumption Supply Voltage Specification No.: 1.0 Test Condition Max. 80.00 Output Waveform Level Typ. 3.13 3.3 Customer Signature : TA=25℃, Vcc=3.3V, and after 1h of operation. @25℃,Vcc=3.3V, OLoad=50Ω. @25℃ Page: 3/6 Guangdong Dapu Telecom Technology Co., Ltd http://www.dptel.com Building 5, No.24, Industrial East Road, Songshanhu Park, Dongguan, Guangdong, P.R. China TEL:0086-0769-88010888 FAX:0086-0769-81800098 -110 Phase Noise 100Hz -140 Phase Noise @25℃ 1KHz dBc/Hz -155 10KHz -160 100KHz Operable Temperature -30 +60 ℃ Storage Temperature -55 +105 ℃ Human Body Model,class2:2000V to 4000V; ANSI/ESDA/JEDEC JS-001-2010. ESD Level Environmental Conditions Machine Model, class B: 200V to 400V; JEDEC JESD22-A115C. Moisture Sensitivity Level Level 2. Vibration Test Condition: 0.75mm ;acceleration:10g;10Hz~2000Hz, one cycle per 30 min, test 2 hour. (3 times for each 3 directions X ,Y , Z) .IEC 68-2-06 Test Fc. Shock 100g;6ms;half sine wave (3 times for each 3 directions X ,Y, Z ),IEC 68-2-27 Test Ea/Severity 50A. Specification No.: 1.0 Customer Signature : Page: 4/6 Guangdong Dapu Telecom Technology Co., Ltd http://www.dptel.com Building 5, No.24, Industrial East Road, Songshanhu Park, Dongguan, Guangdong, P.R. China TEL:0086-0769-88010888 FAX:0086-0769-81800098 2. Mechanical Structure(mm) Note1: Tolerance ±0.2mm without mark Note2: Referential weight 2.2g Note3: NC is not connect Note4: The first two xx representative: week After two xx representative: year Specification No.: 1.0 Customer Signature : Page: 5/6 Guangdong Dapu Telecom Technology Co., Ltd http://www.dptel.com Building 5, No.24, Industrial East Road, Songshanhu Park, Dongguan, Guangdong, P.R. China TEL:0086-0769-88010888 FAX:0086-0769-81800098 3. Test circuit 4. Reflow Soldering Curve (RoHS) Specification No.: 1.0 Customer Signature : Page: 6/6
T936-H419-80.00MHz 价格&库存
很抱歉,暂时无法提供与“T936-H419-80.00MHz”相匹配的价格&库存,您可以联系我们找货
