YXT-BB390K-10S14A0
YXT-BB390K-10S14A0
    YXT(益鑫通)
    SMD,P=0.35mm
    板对板连接器 SMD,P=0.35mm 10Pin 母座
YXT-BB390K-10S14A0 数据手册
0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 产品规格书(外部使用) Product Specification (For External Use) 版本 描述 制表/日期 审核/日期 核准/日期 Rev. Description Written/Date Checked/Date Approved/Date 新版本 Tyler Jason Jason New release 09-20-2021 09-20-2021 09-20-2021 电源 pin 通流变更 Tyler Jason Jason Power pin Current change 12-01-2021 12-01-2021 12-01-2021 增加 50 PIN Tyler Jason Jason Add 50 PIN 05-11-2022 05-11-2022 05-11-2022 更新 2D 图纸 Tyler Jason Jason Update the CAD drawings 11-16-2022 11-16-2022 11-16-2022 A B C D 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 额定电流 信号引脚 0.3A/PIN 电源引脚 7A/PIN 额 额定值 定电压 50V 交流/直流 Rated current signal pin: 0.3A /PIN Power pin: 7A/PIN Rated voltage 50V AC/DC Rating 项目 Item 工作温度范围: -40C 至+85C 存储温度范围: -10C 至+45C 工作湿度范围: 20%到 80% 存储湿度范围: 20%到 80% Operating temperature range : -40°C to +85°C Operating humidity range : 20% to 80% Storage temperature range: -10°C to +45°C Storage humidity range : 20% to 80% 规格 Specification 条件 Conditions 1.绝缘阻抗 1000 MΩ最小 150V直流/一分钟 1.Insulation resistance 1000 MΩ min. 150V DC /one minute 2.耐压测试 2.Withstanding voltage 没有击穿或电火花 No flashover or insulation breakdown. 250V交流/一分钟 250V AC /one minute 组装在胶芯上互配的端子,通过最大 20mV 开路电 压最大 100mA 的电流 3.接触阻抗 3.Contact resistance 信号pin:50 mΩ最大 电源pin 30 mΩ 最大 Signal pin:50 mΩ max mΩ max Power pin: 30 Subject mated contacts assembled in housing to 20mV maximum open circuit at 100mA max 4.振动测试 4.Vibration 5.耐潮湿 5.Humidity 6.温度循环 6.Temperature Cycling 瞬断不超过1微秒 No momentary disconnections of 1 micro-sec/min. And meet 没有物理损伤和满足要求 1. (绝缘阻抗) 2. (承受耐压) 3. (接触阻抗) No physical damage and meet 1. ( Insulation Resistance ) 2. ( Dielectric Withstanding Voltage ) 3. ( Contact Resistance ) 没有物理损伤和满足要求 1. (绝缘阻抗) 2. (承受耐压) 3. (接触阻抗) No physical damage and meet 1. ( Insulation Resistance ) 2. ( Dielectric Withstanding Voltage ) 3. ( Contact Resistance ) 频率:10-50 Hz,单振幅0.75毫米,三个方向,每个方 向10次,每次5分钟 Frequency :10Hz to 50Hz Half amplitude of 0.75mm 10 cycles in each of 3 axis directions for 5 minutes/cycle 配对连接器并应用以下测试条件。 温度:+ 40±2°C 持续时间:240 小时 Mated Connector and apply the following test condition. Temperature:+40±2°C Duration:240 Hours 配对连接器并应用以下测试条件。周期:10 个周期 温度:+25(-10)~ 65°C 湿度:90 ~ 98%RH Mated Connector and apply the following test condition. Cycle:10 cycles Temperature : +25 ( -10 ) ~ 65°C Humidity : 90~98%RH 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 7.耐久 7.Durability 无物理损伤,并能满足要求(接触阻抗) No physical damage and meet .(Contact Resistance) 8.耐焊接性 无变形或其他功能影响 8.Resistance to soldering heat No deformation of components affecting performance. 9.盐雾测试 无物理损伤,并能满足要求(接触阻抗) 30次 30 cycles 回流焊:推荐的温度曲线 手动焊接:350±10°C 5±1 s 使用次数:3次 Reflow: At the recommended temperature profile Manual soldering: 350±10°C for 5±1 s Application : 3 times 配对连接器并应用以下测试条件。 温度:+ 35±2°C 浓度:5±1% 持续时间:48 小时 No physical damage and meet .(Contact Resistance) Mated Connector and apply the following test condition. Temperature:+35±2°C Salt water density : 5±1% Duration:48 Hours 10.插拔力 插入力 1.00N / pin 最大 拔出力 0.30N / pin 最小 测试最大速度25±3毫米/分钟 周期:耐久 30 次 10.Mating&Unmating Force Mating force : 1.00N / pin max. Unmating force : 0.30N / pin min. Operation Speed:25 ± 3 mm Durability Cycles:30 Cycles. 9.Salt water spray 10 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 材料和表面处理 Materials and Finishes 连接器 Connectors 组件 Component 材料 Material 胶芯 液晶高分 子聚合物 Insulator 完成 Finish 颜色:黑色 LCP 接触区域:镀金 4u〞最小 镀镍:80-150 u〞 端子 Contacts 磷青铜 Phosphor bronze 备注 Remarks Color : Black 母座 Socket 有害成分信息 Harmful component information 电镀 plating Contact area:Au 4u〞 Min,Ni 80-150u〞 符合ROHS2.0及无 卤要求 UL94V-0 ROHS 2.0+HF 焊脚区域:闪金 镀镍:80-150 u〞 Solder area:GOLD FLASH ,Ni 80-150u〞 胶芯 Insulator 液晶高分 子聚合物 颜色:黑色 Color : Black LCP 接触区域:镀金 4u〞最小 镀镍:80-150 u〞 Contact area:Au 4u〞 公座 Plug 端子 Contacts 磷青铜 Phosphor bronze 电镀 plating Min,Ni 80-150u〞Min 焊脚区域:闪金 镀镍:80-150 u〞 Solder area:GOLD FLASH,Ni 80-150u〞 符合ROHS2.0及无 卤要求 ROHS 2.0+HF UL94V-0 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 订购信息(母座) Ordering information (Socket) YXT-BB 390K- XX S 1 4 A 0 1 2 3 456 78 1.BB:板对板 1.BB: Board to Board 2.系列名称:390K 系列 连接器 2.Series name: 390K Series Connectors 3.PIN数: 10 24 30 40 50 PIN 3.Number of positions: 10 24 30 40 50 PIN 4.类型:S-母座 4.Type:S -Socket 5.包装:1(10K/盘) 5.Packing: 1 (10K/R) 6.电镀:4(接触区域镀金4u〞最小 镍80-150u〞最小) 6.Plating: 4 (Contact area Au 4u〞min Ni 80-150u〞Min ) 7.HD(HD是电源PIN) 7.Hold Down: A (With hold down power) 8.序列号:0 8.Serial number: 0 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 订购信息(公座) Ordering information (Plug) YXT-BB 390K- XX P 1 4 A 0 1 2 3 456 78 1.BB:板对板 1.BB: Board to Board 2.系列名称:390K 系列 连接器 2.Series name: 390K Series Connectors 3.PIN数:10 24 30 40 50 PIN 3.Number of positions: 10 24 30 40 50 PIN 4.类型:P-公座 4.Type:P -Plug 5.包装:1(10K/盘) 5.Packing: 1 (10K/R) 6.电镀:4(接触区域镀金4u〞最小 镍80-150u〞最小) 6.Plating: 4 (Contact area Au 4u〞min Ni 80-150u〞Min ) 7.HD(HD是电源PIN) 7.Hold Down: A (With hold down power) 8.序列号:0 8.Serial number: 0 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 母座(2D图 单位:毫米) Socket (CAD Data Unit:mm) General tolerance:±0.10 推荐焊盘 Recommended PCB mounting pattern D 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 推荐钢网 钢网厚度0.08毫米 Recommended Metal Mask Dimensions Mask Thickness : 0.08mm D 尺寸表(单位:毫米) Dimention table (Unit: mm) Part Number Number of positions DIM A DIM B DIM C DIM D YXT-BB390K-10S14A0 10 4.30 1.40 3.50 3.26 YXT-BB390K-24S14A0 24 6.75 3.85 5.95 5.71 YXT-BB390K-30S14A0 30 7.80 4.90 7.00 6.76 YXT-BB390K-40S14A0 40 9.55 6.65 8.75 8.51 YXT-BB390K-50S14A0 50 11.30 8.40 10.50 10.26 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 公座(2D图 单位:毫米) Plug (CAD Data Unit:mm) General tolerance:±0.10 推荐PCB Recommended PCB mounting pattern 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 推荐钢网 钢网厚度0.08毫米 Recommended Metal Mask Dimensions Mask Thickness : 0.08mm 尺寸表(单位:毫米) Dimention table (Unit: mm) Part Number Number of positions DIM A DIM B DIM C DIM D DIM E YXT-BB390K-10P14A0 10 3.39 3.35 1.40 2.15 2.19 YXT-BB390K-24P14A0 24 5.84 5.80 3.85 4.60 4.64 YXT-BB390K-30P14A0 30 6.89 6.85 4.90 5.65 5.69 YXT-BB390K-40P14A0 40 8.64 8.60 6.65 7.40 7.44 YXT-BB390K-50P14A0 50 10.39 10.35 8.40 9.15 9.19 D 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 温度 建议回流焊曲线条件 RECOMMENDED INFRARED REFLOW CONDITION 预热时间 开始 时间(秒) 焊接时间 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 包装规范 母座载体尺寸 Packing Specification Embossed Carrier Tape Dimensions-Socket 包装盘尺寸-母座 Reel Dimensions--Socket 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 尺寸表(单位:毫米) Dimention table (Unit: mm) Part Number A B C D Quantity(PC/REEL) YXT-BB390K-10S14A0 12 5.5 4 2 10000 YXT-BB390K-24S14A0 16 7.5 4 2 10000 YXT-BB390K-30S14A0 16 7.5 4 2 10000 YXT-BB390K-40S14A0 24 11.5 4 2 10000 YXT-BB390K-50S14A0 24 11.5 4 2 10000 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 包装规范 公座载体尺寸 Packing Specification Embossed Carrier Tape Dimensions-Plug 包装盘尺寸-公座 Reel Dimensions--Plug 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 尺寸表(单位:毫米) Dimention table (Unit: mm) Part Number A B C D Quantity(PC/REEL) YXT-BB390K-10S14A0 12 5.5 4 2 10000 YXT-BB390K-24S14A0 16 7.5 4 2 10000 YXT-BB390K-30S14A0 16 7.5 4 2 10000 YXT-BB390K-40S14A0 24 11.5 4 2 10000 YXT-BB390K-50S14A0 24 11.5 4 2 10000 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 产品组装的操作说明 Instruction of application to usage 组装插头时注意事项 Notes when mating connector 1. 将插头与导轨对齐 连接器上设有与导轨配合的导向结构。保持公座侧和母座侧平衡后,请按下连接器。 1.Align the connector with the guide rail. The connector is equipped with a guide structure to cooperate with the guide. Please press the connector after keeping the balance between the male seat side and the female seat side. 保持水平 Keep level 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 2. 扣合连接器 正确对准时,插头略微降低,通过在X和Y方向移动连接器确认正确位置。 2.Crimp the connector. When correctly aligned, the plug is slightly lowered and the correct position is confirmed by moving the connector in the X and Y directions. 调整位置 Adjust position 扣合到位 调整位置 Adjust position Press in place 扣合到位 Press in place 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 拆卸插头注意事项 Notes when unmating connector 1. 垂直方向 拆卸接头时,请垂直拆卸插头。(当FPC的厚度等因素可能导致难以垂直拆卸时,轻轻摇晃接头,同时垂直拆卸) 1.Vertical direction When removing the connector, remove it vertically. ( When the thickness of FPC or other factors may make it difficult to disassemble vertically, gently shake the connector and disassemble vertically at the same time ) OK OK 轻轻摇晃接头,同时垂直取下 Gently shake the connector and remove it vertically at the same time 0.35mm Pitch,0.60mm Height,Board-to-Board/Board-to-FPC Connectors (BB390K Series ) 2. 纵向 倾斜的拔下插头 2.Longitudinal removal Pull off the connector in an inclined manner OK 3. 横向 沿垂直方向拔出FPC的插头。 水平地施加一个较大的力可能会使接触点变形。 3.Lateral removal Pull out the plug of the FPC in a vertical direction. Applying a large force horizontally may deform the contact. OK × NG
YXT-BB390K-10S14A0 价格&库存
很抱歉,暂时无法提供与“YXT-BB390K-10S14A0”相匹配的价格&库存,您可以联系我们找货
