1700V SiC N-Channel MOSFET
Features
CI72N170SM
Package
High Blocking Voltage with Low On-Resistance
High Speed Switching with Low Capacitance
Easy to Parallel and Simple to Drive
Benefits
Higher System Efficiency
Reduced Cooling Requirements
Increased Power Density
Increased System Switching Frequency
TO-247-3
Applications
Solar Inverters
High Voltage DC/DC Converters
Motor Drives
Switch Mode Power Supplies
Pulsed Power applications
Maximum Ratings (TC=25℃ unless otherwise specified)
Symbol
Parameter
Value
Unit
Test Conditions
VDSmax
Drain-Source Voltage
1700
V
VGS=0V, ID=100μA
VGSmax
Gate-Source Voltage
-10/+25
V
Absolute maximum values
VGSop
Gate-Source Voltage
-5/+20
V
Recommended operational values
ID
ID(pulse)
PD
TJ, TSTG
72
Continuous Drain Current
48
A
VGS=20V, Tc=25℃
VGS=20V, Tc=100℃
Pulsed Drain Current
160
A
Pulse width tp limited by TJmax
Power Dissipation
520
W
Tc=25℃, TJ=150℃
-55 to +150
Operating Junction and Storage Temperature
www.tokmas.com
Note
CI72N170SM
Electrical Characteristics (TC=25℃ unless otherwise specified)
Symbol
Parameter
V(BR)DSS
Drain-Source Breakdown Voltage
VGS(th)
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
1700
V
2.0
2.6
4.0
1.8
V
Test Conditions
VGS=0V, ID=100μA
VDS=VGS, ID=18mA
VDS=VGS, ID=18mA, TJ=150℃
IDSS
Zero Gate Voltage Drain Current
1
100
µA
VDS=1700V, VGS=0V
IGSS+
Gate-Source Leakage Current
10
250
nA
VDS=0V, VGS=25V
IGSS-
10
250
nA
VDS=0V, VGS=-10V
45
70
90
25.8
27.0
RDS(on)
Drain-Source On-State Resistance
gfs
Transconductance
Ciss
Input Capacitance
3550
Coss
Output Capacitance
165
Crss
Reverse Transfer Capacitance
6.1
Eoss
Coss Stored Energy
101
EON
Turn-On Switching Energy
3.1
EOFF
Turn-Off Switching Energy
1.1
td(on)
Turn-On Delay Time
27
Rise Time
32
Turn-Off Delay Time
36
Fall Time
10
Internal Gate Resistance
2.6
QGS
Gate to Source Charge
54
QGD
Gate to Drain Charge
25
QG
Total Gate Charge
193
Typ.
Max.
4.5
4.2
tr
td(off)
tf
RG(int)
mΩ
S
VGS=20V, ID=50A, TJ=150℃
VDS=20V, ID=50 A
VDS=20V, ID=50A, TJ=150℃
mJ
ns
Ω
Fig.
4,5,6
Fig.
VDS=1000V
15,16
f=1MHz
µJ
Fig. 11
VGS=20V, ID=50A
VGS=0V
pF
Note
VAC=25mV
VDS=1200V, VGS=-5V/20V
ID=30A, RG(ext)=2.5Ω, L=100μH
VDS=1200V, VGS=-5V/20V, ID=30A
RG(ext)=2.5Ω, RL=20Ω
f=1MHz, VAC=25mV
VDS=1200V
nC
VGS=-5V/20V
ID=50A
Reverse Diode Characteristics
Symbol
VSD
Parameter
Diode Forward Voltage
Unit
V
IS
Continuous Diode Forward Current
72
A
trr
Reverse Recover Time
55
ns
Qrr
Reverse Recovery Charge
220
nC
Irrm
Peak Reverse Recovery Current
6.7
A
Typ.
Max.
0.24
40
Test Conditions
VGS=-5V, ISD=25A
VGS=-5V, ISD=25A, TJ=150℃
Note
Fig.
8,9,10
TC=25℃
VR=1200V, ISD=50A
Thermal Characteristics
Symbol
Parameter
RθJC
Thermal Resistance from Junction to Case
RθJA
Thermal Resistance from Junction to Ambient
www.tokmas.com
Unit
℃/W
Test Conditions
Note
CI72N170SM
Typical Performance
Figure 1. Output Characteristics TJ = -40 ºC
Figure 3. Output Characteristics TJ = 150 ºC
Figure 5. On-Resistance vs. Drain Current
Figure 2. Output Characteristics TJ = 25 ºC
Figure 4. Normalized On-Resistance vs. Temperature
Figure 6. On-Resistance vs. Temperature
For Various Temperatures
For Various Gate Voltage
www.tokmas.com
CI72N170SM
Typical Performance
Figure 7. Transfer Characteristic for
Figure 8. Body Diode Characteristic at -40 ºC
Various Junction Temperatures
Figure 9. Body Diode Characteristic at 25 ºC
Figure 11. Threshold Voltage vs. Temperature
Figure 10. Body Diode Characteristic at 150 ºC
Figure 12. 3rd Quadrant Characteristic at -40 ºC
www.tokmas.com
CI72N170SM
Typical Performance
Figure 13. 3rd Quadrant Characteristic at 25 ºC
Figure 14. 3rd Quadrant Characteristic at 150 ºC
Figure 15. Capacitances vs. Drain-Source
Figure 16. Capacitances vs. Drain-Source
Voltage (0 - 200V)
Voltage (0 - 1000V)
Figure 17. Gate Charge Characteristic
Figure 18. Output Capacitor Stored Energy
www.tokmas.com
CI72N170SM
Package Dimensions
Package TO-247-3
DIMENSIONS IN
MILLMETERS
SYMBOLS
MIN
NOM
MAX
A
4.9
5
5.1
A1
2.9
3
3.1
A2
2.31
2.36
2.41
b
1.16
1.2
1.26
b1
2.05
2.2
b2
3.05
3.2
c
0.58
0.6
0.66
D
20.9
21
21.1
D1
16.46
16.56
16.76
D2
1.17
d1
6.05
6.15
6.25
d2
2.2
2.3
2.4
E
15.7
15.8
15.9
E1
10.5
E2
14.02
e
1.27bcs
L
19.82
19.92
20.02
L1
1.88
1.98
2.08
θ
0°
7°
8°
R1
2.7
R2
2.5
Ф1
Ф2
www.tokmas.com
3.6
7.19
很抱歉,暂时无法提供与“CI72N170SM”相匹配的价格&库存,您可以联系我们找货
